Ist schon gut, habe den fehler selbst gefunden...nun macht mir nur noch mein altes NT probleme! Kabel sind überall ab aber sie sind so s**** verlegt das ich sie nicht mehr rausbekomme.
Ja, tut mir leid hatte den anderen Beitrag editiert bevor ich den neuen begonnen hatte...
Unitymedia 2 Play Plus 100 läuft noch 1,5 Jahre.
Router / Modem: Technicolor TC7200
Okay, also sollte ich nicht auf was besseres sparen?
EDIT: Weil ich ständig Verbindungsabbrüche habe...
Unitymedia meint es liegt an mir blabla^^
2 LAN Kabel ausprobiert immer noch Abbrüche...
Systemlogs des Modems:
2015-01-11 06:58:12: [Minor] DHCP RENEW WARNING - Field invalid in response v4 option;CM-M...
2015-01-08 09:17:23: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2015-01-08 09:16:35: [Info] TLV-11 - unrecognized OID;CM-MAC=88:f7:c7:c5:d3:de;CMTS-MAC=0...
--- -- --:--:--: [Warn] DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
--- -- --:--:--: [Info] Honoring MDD; IP provisioning mode = IPv4
--- -- --:--:--: [Info] WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A)...
--- -- --:--:--: [Major] No Ranging Response received - T3 time-out;CM-MAC=88:f7:c7:c5...
2014-12-18 05:29:37: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2014-12-18 05:27:24: [Major] Resetting the cable modem due to docsDevResetNow
2014-12-15 02:03:13: [Major] Unicast Ranging Received Abort Response - Re-initializing MAC...
2014-12-15 02:01:33: [Major] Unicast Ranging Received Abort Response - Re-initializing MAC...
2014-12-13 14:03:52: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2014-12-09 00:33:00: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2014-12-07 21:38:35: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2014-12-07 14:13:48: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2014-12-07 03:54:31: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2014-12-07 03:52:07: [Major] Received Response to Broadcast Maintenance Request, But no Un...
Ich möchte gerne in der nächsten zeit meinen PC endlich komplett fertig aufgerüstet haben, ich habe oben mein System nochmal zusammengefasst.
Grün würde ich nicht mehr tauschen, da ich die Teile erst letztes Jahr gekauft habe.
Ist die Grafikkarte noch ok?
Wie sieht es mit dem Laufwerk aus? Sollte ich das austauschen?
Ein neues Gehäuse und ein Lüfter müsste auch noch her...alles in allem würde ich maximal 300€ nochmal locker machen.
Ich brauche eine gute CPU Leistung da ich oft Videos bearbeite.
Ich hoffe ihr könnt mir ein paar Komponenten empfehlen
Hmm also mehr als 300 wollte ich nicht nochmal ausgeben 330 könnte ich noch akzeptieren, daher fällt die Xeon schon mal raus.
Was billigeres mit ähnlicher Leistung für meinen Gamer / Video PC gibt es nicht oder?
