System Information (local)
Computer name: STEFANS-PC
Windows version: Windows 7 Service Pack 1, 6.1, build: 7601
Windows dir: C:\Windows
Hardware: ECT, Gigabyte Technology Co., Ltd., GA-78LMT-S2P
CPU: AuthenticAMD AMD FX(tm)-4300 Quad-Core Processor AMD586, level: 21
4 logical processors, active mask: 15
RAM: 8587370496 bytes total
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 13.12.2015 09:31:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121315-15132-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4B29EC)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007F79038, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sun 13.12.2015 02:09:52 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121315-17238-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007E2D6A8, 0x0, 0x0)
On Sun 13.12.2015 01:23:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121315-19047-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007F67038, 0x0, 0x0)
On Sun 13.12.2015 00:01:16 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121315-20904-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007C048F8, 0x0, 0x0)
On Sat 12.12.2015 14:18:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121215-14835-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007F92038, 0x0, 0x0)
