SQL Umlaute bei Umwandlung von RTF zu Plain Text
cr0wfir3
Cadet 1st Year
Sep. 2008
Hallo.
Ich habe eine Funktion gefunden die RTF's in Plain Text umwandelt.
Mein Problem ist jetzt, dass Umlaute nicht Korrekt übernommen werden :(
Mein Programm: Microsoft SQL Server Management Studio.
Den Code für die Funktion hab ich hier gefunden:
Code:
CREATE FUNCTION	dbo.fnParseRTF
	@rtf VARCHAR(8000)
RETURNS VARCHAR(8000)
AS
BEGIN
	DECLARE	@Stage TABLE
			Chr CHAR(1),
			Pos INT
	INSERT		@Stage
				Chr,
				Pos
	SELECT		SUBSTRING(@rtf, Number, 1),
			Number
	FROM		master..spt_values
	WHERE		Type = 'p'
			AND SUBSTRING(@rtf, Number, 1) IN ('{', '}')
	DECLARE	@Pos1 INT,
		@Pos2 INT
	SELECT	@Pos1 = MIN(Pos),
		@Pos2 = MAX(Pos)
	FROM	@Stage
	DELETE
	FROM	@Stage
	WHERE	Pos IN (@Pos1, @Pos2)
	WHILE 1 = 1
		BEGIN
			SELECT TOP 1	@Pos1 = s1.Pos,
					@Pos2 = s2.Pos
			FROM		@Stage AS s1
			INNER JOIN	@Stage AS s2 ON s2.Pos > s1.Pos
			WHERE		s1.Chr = '{'
					AND s2.Chr = '}'
			ORDER BY	s2.Pos - s1.Pos
			IF @@ROWCOUNT = 0
				BREAK
			DELETE
			FROM	@Stage
			UPDATE	@Stage
			SET	Pos = Pos - @Pos2 + @Pos1 - 1
			WHERE	Pos > @Pos2
			SET @rtf = STUFF(@rtf, @Pos1, @Pos2 - @Pos1 + 1, '')
		END
	SET	@Pos1 = PATINDEX('%\cf[0123456789][0123456789 ]%', @rtf)
	WHILE @Pos1 > 0
		SELECT	@Pos2 = CHARINDEX(' ', @rtf, @Pos1 + 1),
			@rtf = STUFF(@rtf, @Pos1, @Pos2 - @Pos1 + 1, ''),
	SELECT	@rtf = REPLACE(@rtf, '\pard', ''),
		@rtf = REPLACE(@rtf, '\par', ''),
		@rtf = LEFT(@rtf, LEN(@rtf) - 1)
	SELECT	@rtf = REPLACE(@rtf, '\b0 ', ''),
		@rtf = REPLACE(@rtf, '\b ', '')
	SELECT	@rtf = STUFF(@rtf, 1, CHARINDEX(' ', @rtf), '')
	RETURN	@rtf
END
Ein RTF-Beispiel:
{\rtf1\ansi\ansicpg1252\uc1\deff0{\fonttbl {\f0\fswiss\fcharset0\fprq2 Arial;} {\f1\froman\fcharset2\fprq2 Symbol;}} {\colortbl;\red0\green0\blue0;\red255\green255\blue255;} {\stylesheet{\s0\itap0\nowidctlpar\f0\fs24 [Normal];}{\*\cs10\additive Default Paragraph Font;}} {\*\generator TX_RTF32 14.0.520.503;}{\info{\*\hlinkbase C:\'5cProgram Files\'5cOrdner\'5cProgramm.net\'5c}} \deftab1134\paperw11894\paperh16834\margl720\margt720\margr720\margb720\widowctrl\formshade\sectd \headery720\footery720\pgwsxn11894\pghsxn16834\marglsxn720\margtsxn720\margrsxn720\margbsxn720\pard\itap0\nowidctlpar\plain\f0\fs20 Ist das M\loch\f0\hich\f0\'f6glich \'e4\'fc\'f6\par\par }
Und das sollte eigentlich ausgegeben werden:
Ist das Möglich äüö
Aber ausgegeben wird folgendes:
Kann mir jemand sagen ob es möglich ist die richtigen Umlaute auszugeben?
LG
Ist ja nur als Parser gekennzeichnet. RTF kann aber auch mit verschiedenen Codepages umgehen. Wenn die nicht abgefangen werden, dann sieht das Ergebnis so wie bei dir aus.
Kannst Du eventuell die Quelle in reinen Text umwandeln oder brauchst Du z.B. die Formatierungen?
