EtreCheck version: 2.9.11 (264)
Report generated 2016-04-16 22:57:26
Download EtreCheck from https://etrecheck.com
Runtime 2:09
Performance: Excellent
Click the [Support] links for help with non-Apple products.
Click the [Details] links for more information about that line.
Problem: Computer is restarting
Hardware Information: ⓘ
iMac (Retina 5K, 27-inch, Late 2015)
[Technical Specifications] - [User Guide] - [Warranty & Service]
iMac - model: iMac17,1
1 3,2 GHz Intel Core i5 CPU: 4-core
32 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
8 GB DDR3 1867 MHz ok
BANK 0/DIMM1
BANK 1/DIMM0
BANK 1/DIMM1
Bluetooth: Good - Handoff/Airdrop2 supported
Wireless: Unknown
Video Information: ⓘ
AMD Radeon R9 M380 - VRAM: 2048 MB
iMac 5120 x 2880
System Software: ⓘ
OS X El Capitan 10.11.4 (15E65) - Time since boot: about one hour
Disk Information: ⓘ
APPLE HDD ST1000DM003 disk0 : (1 TB) (Rotational)
EFI (disk0s1) <not mounted> : 210 MB
Recovery HD (disk0s3) <not mounted> [Recovery]: 650 MB
Macintosh HD (disk1) / : 998.98 GB (617.03 GB free)
Core Storage: disk0s2 999.35 GB Online
USB Information: ⓘ
VIA Labs, Inc. USB3.0 Hub
VIA Labs, Inc. USB2.0 Hub
Broadcom Corp. Bluetooth USB Host Controller
Apple Inc. FaceTime HD Camera (Built-in)
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Gatekeeper: ⓘ
Mac App Store and identified developers
Kernel Extensions: ⓘ
/Applications/Parallels Desktop.app
[not loaded] com.parallels.kext.hypervisor (11.1.3 32521 - SDK 10.9 - 2016-03-02) [Support]
[not loaded] com.parallels.kext.netbridge (11.1.3 32521 - SDK 10.9 - 2016-03-02) [Support]
[not loaded] com.parallels.kext.usbconnect (11.1.3 32521 - SDK 10.9 - 2016-03-02) [Support]
[not loaded] com.parallels.kext.vnic (11.1.3 32521 - SDK 10.9 - 2016-03-02) [Support]
/Applications/ReadyCLOUD.app
[loaded] foo.tap (20111101 - 2016-01-18) [Support]
[loaded] foo.tun (20111101 - 2016-01-18) [Support]
/Library/Extensions
[not loaded] com.wacom.kext.ftdi (1.0 - SDK 10.10 - 2016-04-06) [Support]
/System/Library/Extensions
[not loaded] com.Cycling74.driver.Soundflower (1.6.6 - SDK 10.6 - 2016-04-06) [Support]
[not loaded] com.devguru.driver.SamsungComposite (1.4.37 - SDK 10.6 - 2016-04-06) [Support]
[not loaded] com.wacom.kext.wacomtablet (Wacom Tablet 6.3.11-3 - SDK 10.10 - 2016-04-06) [Support]
/System/Library/Extensions/ssuddrv.kext/Contents/PlugIns
[not loaded] com.devguru.driver.SamsungACMControl (1.4.37 - SDK 10.6 - 2015-12-15) [Support]
[not loaded] com.devguru.driver.SamsungACMData (1.4.37 - SDK 10.6 - 2015-12-15) [Support]
[not loaded] com.devguru.driver.SamsungMTP (1.4.37 - SDK 10.5 - 2015-12-15) [Support]
[not loaded] com.devguru.driver.SamsungSerial (1.4.37 - SDK 10.6 - 2015-12-15) [Support]
Startup Items: ⓘ
TuxeraNTFSUnmountHelper: Path: /Library/StartupItems/TuxeraNTFSUnmountHelper
Startup items are obsolete in OS X Yosemite
System Launch Agents: ⓘ
[not loaded] 7 Apple tasks
[loaded] 156 Apple tasks
[running] 75 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 46 Apple tasks
[running] 86 Apple tasks
Launch Agents: ⓘ
[failed] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a...plist (2015-10-16) [Support]
[loaded] com.google.keystone.agent.plist (2016-03-01) [Support]
[loaded] com.oracle.java.Java-Updater.plist (2016-02-15) [Support]
[running] com.wacom.wacomtablet.plist (2014-12-22) [Support]
[loaded] org.macosforge.xquartz.startx.plist (2014-08-11) [Support]
Launch Daemons: ⓘ
[running] com.VTechLLNService.plist (2015-02-28) [Support]
[loaded] com.adobe.ARMDC.Communicator.plist (2015-10-16) [Support]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (2015-10-16) [Support]
[running] com.adobe.adobeupdatedaemon.plist (2015-07-27) [Support]
[loaded] com.adobe.fpsaud.plist (2016-04-05) [Support]
[loaded] com.google.keystone.daemon.plist (2016-03-01) [Support]
[loaded] com.macpaw.CleanMyMac3.Agent.plist (2016-01-18) [Support]
[loaded] com.microsoft.office.licensing.helper.plist (2012-11-05) [Support]
[running] com.netgear.leafd.plist (2015-09-16) [Support]
[loaded] com.oracle.java.Helper-Tool.plist (2016-02-15) [Support]
[loaded] com.teamviewer.Helper.plist (2015-01-15) [Support]
[loaded] org.macosforge.xquartz.privileged_startx.plist (2014-08-11) [Support]
User Launch Agents: ⓘ
[running] com.amazon.music.plist (2016-03-07) [Support]
[not loaded] com.apple.serveralertproxy.plist - Executable not found!
[loaded] com.macpaw.CleanMyMac3.Scheduler.plist (2016-02-02) [Support]
[running] com.spotify.webhelper.plist (2016-04-16) [Support]
[loaded] com.valvesoftware.steamclean.plist (2016-03-20) [Support]
User Login Items: ⓘ
Spotify Programm Hidden (/Applications/Spotify.app)
Android File Transfer Agent Programm (~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app)
fuspredownloader Programm Hidden (~/Library/Application Support/.FUS/fuspredownloader.app)
Other Apps: ⓘ
[running] OpenObject.fuspredownloader.88032
[loaded] com.google.Chrome.49632
[running] com.google.android.mtpagent.85792
[running] com.macpaw.CleanMyDrive.115232
[loaded] com.macpaw.CleanMyDrive.Helper
[loaded] com.spotify.client.302752
[running] com.wacom.TabletDriver.94432
[running] com.wacom.WacomTouchDriver.87712
[loaded] 405 Apple tasks
[running] 199 Apple tasks
Internet Plug-ins: ⓘ
JavaAppletPlugin: Java 8 Update 77 build 03 (2016-04-01) Check version
Unity Web Player: UnityPlayer version 4.6.4f1 - SDK 10.6 (2015-12-05) [Support]
Default Browser: 601 - SDK 10.11 (2016-03-21)
WacomTabletPlugin: WacomTabletPlugin 2.1.0.6 - SDK 10.9 (2015-12-05) [Support]
AdobeAAMDetect: 3.0.0.0 - SDK 10.9 (2015-12-05) [Support]
FlashPlayer-10.6: 21.0.0.213 - SDK 10.6 (2016-04-08) [Support]
AdobePDFViewerNPAPI: 15.010.20060 - SDK 10.8 (2016-03-09) [Support]
Silverlight: 5.1.41212.0 - SDK 10.6 (2016-03-16) [Support]
QuickTime Plugin: Unknown (2015-09-21)
Flash Player: 21.0.0.213 - SDK 10.6 (2016-04-08) [Support]
SharePointBrowserPlugin: 14.4.3 - SDK 10.6 (2015-12-05) [Support]
AdobePDFViewer: 15.010.20060 - SDK 10.8 (2016-03-09) [Support]
MeetingJoinPlugin: Unknown - SDK 10.6 (2015-12-05) [Support]
Safari Extensions: ⓘ
Open in Internet Explorer - Parallels - http://www.parallels.com (2015-10-17)
3rd Party Preference Panes: ⓘ
Flash Player (2016-04-05) [Support]
Java (2016-04-01) [Support]
Tuxera NTFS (2016-02-02) [Support]
WacomTablet (2016-02-02) [Support]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
30% mdworker(14)
3% kernel_task
3% WindowServer
2% Mail
1% fontd
Top Processes by Memory: ⓘ
1.62 GB kernel_task
1.25 GB Google Chrome Helper(7)
295 MB com.apple.WebKit.WebContent(3)
295 MB Mail
262 MB Spotify Helper(2)
Virtual Memory Information: ⓘ
24.00 GB Free RAM
7.84 GB Used RAM (2.50 GB Cached)
0 B Swap Used
Diagnostics Information: ⓘ
Apr 16, 2016, 09:30:41 PM Self test - passed
Mar 23, 2016, 07:23:45 PM /Library/Logs/DiagnosticReports/Kernel_2016-03-23-192345_[redacted].panic [Details]
