Hanskult
- Mai 2005
Der Treiber ist jetzt draußen!
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/Catalyst_513_release_notes.html
Issues Resolved in Catalyst® Software Suite 5.13
The following section provides a summary of the issues that have been resolved in the latest version of Catalyst®. These include:
* F.E.A.R: Slow game performance is no longer noticed when using CrossFire. Further information on this resolved issue can be found in topic number 737-21270
* The Video Preview no longer fails to change to its default settings when swapping the display mappings using the Catalyst® Control Center. Further information on this resolved issue can be found in topic number 737-21174
* Attempting to stretch the display horizontally using the Catalyst® Control Center, no longer results in the horizontal stretch mode failing to be applied unless the display is stretched vertically first. Further information on this resolved issue can be found in topic number 737-21175
* The PowerPlay™ option found in the Catalyst® Control Center no longer defaults to the enabled state after initial install of the display driver for systems containing an ATI Radeon® Xpress 200 series product. Further information on this resolved issue can be found in topic number 737-21180
* Auto-detect no longer fails to be applied as the default setting for the Deinterlacing option when first entering the Video aspect page of the Catalyst® Control Center. Currently the option is set as Weave. Further information on this resolved issue can be found in topic number 737-21185
* Catalyst® Control Center: Attempting to extend the desktop display when using a CRT, TV and DFP display devices no longer results in display corruption being noticed on the primary display adapter. Further information on this resolved issue can be found in topic number 737-20982
* Attempting to set the CRT as the primary display device after hot-plugging a DFP display device and enabling extended desktop mode, no longer results in the CRT failing to be set as the primary. Further information on this resolved issue can be found in topic number 737-21269
* Catalyst® Control Center: Entering the Overdrive™ aspect and changing the GPU setting to 509 and the memory setting to 505 no longer results in color corruption and the Windows XP operating system rebooting. Further information on this resolved issue can be found in topic number 737-21229
