Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini062807-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700
Debug session time: Thu Jun 28 19:19:39.765 2007 (GMT+2)
System Uptime: 0 days 9:28:28.533
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image nv4_disp.dll, Win32 error 2
*** WARNING: Unable to verify timestamp for nv4_disp.dll
*** ERROR: Module load completed but symbols could not be loaded for nv4_disp.dll
ERROR: FindPlugIns 8007007b
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E,
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : nv4_disp.dll ( nv4_disp+2cd0bc )
Followup: MachineOwner
Dieser Bluescreen ereilte mich mal wieder. Ich hatte diesen in der letzten Zeit schon öfter, weiß aber nie so wirklich woran es lag. Laut Log-File liegt es ja an der nv4_disp.dll. In Foren ist dann immer nur von einem Update des nVidia Treibers zulesen, nur ist dies der aktuellste.
Jemand einen Ahnung??? Danke im Vorraus.
BugCheck 1000007E,
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
