ich versuch erstmal das Aktivieren. warte.
Geht auch nicht!
Hier die Zeilen die der Client anzeigt
Command: USER test
Response: 331 Password required for test
Command: PASS ****
Response: 230 Logged on
Command: SYST
Response: 215 UNIX emulated by FileZilla
Command: FEAT
Response: 211-Features:
Response: MDTM
Response: REST STREAM
Response: SIZE
Response: MLST type*;size*;modify*;
Response: MLSD
Response: UTF8
Response: CLNT
Response: MFMT
Response: 211 End
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/" is current directory.
Command: TYPE A
Response: 200 Type set to A
Command: PASV
Response: 227 Entering Passive Mode (85,214,38,148,203,61)
Command: LIST
Response: 425 Can't open data connection.
Error: Could not retrieve directory listing
Und das zeigt der Server an:
(000013) 29.08.2008 18:02:04 - (not logged in) (91.22.235.8)> 220 Please visit
http://sourceforge.net/projects/filezilla/
(000013) 29.08.2008 18:02:04 - (not logged in) (91.22.235.8)> USER test
(000013) 29.08.2008 18:02:04 - (not logged in) (91.22.235.8)> 331 Password required for test
(000013) 29.08.2008 18:02:04 - (not logged in) (91.22.235.8)> PASS ****
(000013) 29.08.2008 18:02:04 - test (91.22.235.8)> 230 Logged on
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> SYST
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> 215 UNIX emulated by FileZilla
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> FEAT
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> 211-Features:
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> MDTM
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> REST STREAM
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> SIZE
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> MLST type*;size*;modify*;
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> MLSD
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> UTF8
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> CLNT
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> MFMT
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> 211 End
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> PWD
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> 257 "/" is current directory.
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> TYPE A
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> 200 Type set to A
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> PASV
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> 227 Entering Passive Mode (85,214,38,148,203,61)
(000013) 29.08.2008 18:02:05 - test (91.22.235.8)> LIST
(000013) 29.08.2008 18:02:15 - test (91.22.235.8)> 425 Can't open data connection.
(000013) 29.08.2008 18:02:30 - test (91.22.235.8)> PWD
(000013) 29.08.2008 18:02:30 - test (91.22.235.8)> 257 "/" is current directory.
(000013) 29.08.2008 18:02:57 - test (91.22.235.8)> TYPE I
(000013) 29.08.2008 18:02:57 - test (91.22.235.8)> 200 Type set to I
(000013) 29.08.2008 18:03:22 - test (91.22.235.8)> REST 0
(000013) 29.08.2008 18:03:22 - test (91.22.235.8)> 350 Rest supported. Restarting at 0
(IP Geändert)
Gruß Mo
