Xopex
- Sep. 2002
Hallo ich wollte eben mal den Beep Media Player installieren und bekam fogende Fehlermeldung:
[evil@rekv beep-media-player-1.0.0-pre5]$ ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for pkg-config... /usr/bin/pkg-config
checking for glib-2.0 >= 2.1.0 gtk+-2.0 gthread-2.0... Package gtk+-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gtk+-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'gtk+-2.0' found
configure: error: Library requirements (glib-2.0 >= 2.1.0 gtk+-2.0 gthread-2.0) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
Was heißt das und vor allem was kann ich dagegen tun?
Meine Distribution ist Mandrake 9.1.
Ich bin für jede Hilfe dankbar....
