GTX 260 + Be Quiet = Absturz?
elan-eo-akin
Feb. 2008
Hallo liebe Gemeinde,
ich habe in meinem System ein Be Quiet! Straight Power 700 Watt zusammen mit der MSI GTX 260 OC (620er Standardtakt), nach Internetrecherchen macht diese Kombination wohl bei einigen Leuten Mukken, musste ich auch gestern am eigenen Leib erleben.
Folgender Minidump nach einem Auto-Reset in C&C AR3:
_____________________________________________________
Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\Mini103008-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008 Kernel Version 6001 (Service Pack 1) MP (4 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6001.18145.x86fre.vistasp1_gdr.080917-1612
Kernel base = 0x81e07000 PsLoadedModuleList = 0x81f1ec70
Debug session time: Thu Oct 30 22:42:09.551 2008 (GMT+1)
System Uptime: 0 days 0:53:30.412
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 116, {87a02510, 8e20fe80, 0, 2}
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+be80 )
Followup: MachineOwner
1: kd> !analyze -v
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: 87a02510, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: 8e20fe80, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 00000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 00000002, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
nvlddmkm+be80
8e20fe80 55 push ebp
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
8bb1dbc0 8e988d76 00000116 87a02510 8e20fe80 nt!KeBugCheckEx+0x1e
8bb1dbe4 8e989a68 8e20fe80 00000000 00000002 dxgkrnl!TdrBugcheckOnTimeout+0x8d
8bb1dc04 8e926ed1 00000000 00000102 87d638b8 dxgkrnl!TdrIsRecoveryRequired+0xa1
8bb1dc6c 8e937ef4 87d638b8 00032353 00000000 dxgkrnl!VidSchiReportHwHang+0x2f5
8bb1dc98 8e937c54 87d638b8 00000000 00000000 dxgkrnl!VidSchiCheckHwProgress+0x69
8bb1dcc4 8e914a4c 00000002 87d642b0 87c74218 dxgkrnl!VidSchiWaitForSchedulerEvents+0x13f
8bb1dd54 8e937f9b 87d638b8 81e58645 87d638b8 dxgkrnl!VidSchiScheduleCommandToRun+0xac
8bb1dd68 8e975053 87d638b8 00000000 87d27030 dxgkrnl!VidSchiRun_PriorityTable+0xf
8bb1dd7c 81fdcb18 87d638b8 4a812651 00000000 dxgkrnl!VidSchiWorkerThread+0x62
8bb1ddc0 81e35a2e 8e974ff1 87d638b8 00000000 nt!PspSystemThreadStartup+0x9d
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
nvlddmkm+be80
SYMBOL_NAME: nvlddmkm+be80
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 48d14495
FAILURE_BUCKET_ID: 0x116_IMAGE_nvlddmkm.sys
Die Grafikkarte hatte ich mal wegen ähnlicher Probleme (bunter Bilderschirm etc.) getauscht, ist also schon die 2. Karte. Nun habe ich vom Be Quiet Support folgendes gelesen:
"[...] für die von Ihnen genannte Grafikkarte benötigen Sie ein Dark Power P7 Pro mit mindestens 850 Watt. Der Betrieb mit „kleineren“ Netzteilen ist im Einzelfall zwar möglich, führt aber in absehbarer Zeit zum Ausfall des Netzteils."
Kann das Netzteil derartige Probleme (Minidump) hervorrufen?
Also ich hatte ne gtx260 mitn nem 650w be quiet ne woche am laufen und gab keine probleme.Jetzt hab ich ein dark power mit 850w und zwei gtx260.
Also ich hab ne GTX260 (Standart) + BeQuiet DP7 550W und alles läuft schon seit über 4Wochen..
es liegt definitiv am netzteil.die straightreihe hat probleme bei hohen spannungsschwankungen.viele haben probleme mit der gtx260 und gtx280 und bequiet netzteilen.ich würde ein enermax netzteil empfehlen. enermax modu 82 + 525watt.
... anbetracht der Tatsache, das BeQuiet die 2xx er Reihe nicht in den Watt-Bedarfsrechner (PSU Calculator) aufgenommen hat bzw. diese Reihe wieder raus genommen hat, kann man davon ausgehen, dass selbst BeQuiet sich der Probleme bewusst ist.
Ich würde nun auch sagen das es das NT ist... kannst wie ich und broesel81 die DarkPower-Serie ausprobieren (ab 550W)
Wenn du die Suchfunktion genutzt hättest wer dir aufgefallen das es dazu dutzende trheat gibt viele habe sich mit der Hotline auseinader gesetzt und nichts ist dabei herrausgekommen.
Einmal für dich: Einige BeQuiet NT`s haben massive probleme mit den Geforce 260GTX/280GTX Karten dieses lässt sich leider nicht verhindern. Du solltest also wenn du kannst dein NT zurückgeben aber aufjedenfall ein neues kaufen. Tagan, Enermax kann ich dir nur emfpehlen.
ich denke bequiet netzteile kann man nicht mehr empfehlen.die sind einfach schlecht.
enermax,seasonic oder corsair.
@westcoast,
ganz so schlimm sehe ich das nicht. BeQuiet wird sicher schon am Problem arbeiten, aber für die 2xxer Reihe ist ein anderer Hersteller sich angeraten.
Am Netzteil liegt es wohl eher nicht, besitze ein Straigt Power E5 600W von BeQuiet und betreibe eine Gtx280 damit. Eine übertaktete Quadcore CPU hängt auch noch dran.
"... die sind einfach schlecht ..."
Ja man kann es sich auch ganz einfach machen. :freak:
In diesem speziellen Fall ist ein anderes NT wohl aber die einzige Rettung, wenn du an der GTX festhälst, was ich verstehen kann.
Btw habe ich ebenfalls ein BQSP(450W)-GTX260-OC+Quadcore-OC-Gespann problemlos in Betrieb.
wenn ich die wahl hätte, würde ich eine andere marke in betracht ziehen.
jedem das seine ,aber ich persönlich halte nichts von bequiet.
Danke für die Anteilnahme ;-)
Ist die obenstehende Fehlermeldung (also Blackscreen + Autoreboot) sowie plötzlicher bunter Pixelsalat denn mit der NT-Diagnose vereinbar?
wenn die karte nicht genug saft bekommt,schaltet sich die karte ab .danach kommt ein blackscreen und ein reboot.ob man die pixelfehler dem netzeil zuordnen kann ,weiss ich nicht.
das netzteil ist überfordert mit der grafikarte.
ich habe momentan ein LC Green Power 550. Läuft bestens mit 2 x 8800GT. Scheisse, kann man die Schrift nicht noch mehr verkleinern..?
@westcoast
Man kann BeQuiet aber auch hassen ;) ?
@Threatsteller
Würde sagen es liegt am NT, ausser die Karte ist defekt kannst die ja mal in einem anderen Rechner mit genug Power (ab 500W) testen ;)
Hi, habe seit kurzem eine XFX GTX 260 666M und bei mir stürzen auch regelmäßig 3d Anwendungen ab. Mein Netzteil ist aber ein BQ DarkPower 620W. Kann mir jemand beschreiben wie sich die inkompatibilität bei euch äußert? Bei mir ist dann mitten im Game ein komplett lilaner Bildschirm mit komischen Muster zu sehen. PC kann dann nurnoch resettet werden.
MfG panopticum
Das dürfte interessant sein:
https://www.computerbase.de/forum/threads/xfx-gtx-260-friert-ein.510651/
https://www.computerbase.de/forum/t...260gtx-black-edition-werd-des-spielen.511445/
https://www.computerbase.de/forum/threads/bequiet-netzteile-und-gtx-karten.507911/
Meine XFX GTX260 Black Edition ging wieder zurück. Die OC-Werte konnte die Karte nicht dauerhaft stabil umsetzen. Erst hatte ich mein BQ Netzteil im Verdacht, woraufhin ich 3 weitere Marken-NT´s bis hin zu 720W getestet habe. Als das keine Besserung ergab, Karte runtergetaktet, und siehe da, selbst mit meinem 550W BQ Straight Power lief´s dann. Die XFX war also zu krass übertaktet - mein persönliches Fazit jedenfalls. Vielleicht haben wir alle eine Montags-Charge erwischt?
Jetzt werkelt wieder meine 8800GTX, die mir seit 2 Jahren treue Dienste leistet :)
