Ich schätze aber du willst auch gleich noch wissen wie das geht, auch wenn das nicht die Frage war.
man route hilft dir da weiter:
Code:
EXAMPLES
route add -net 127.0.0.0 netmask 255.0.0.0 dev lo
adds the normal loopback entry, using netmask 255.0.0.0 and associated with the "lo" device (assum‐
ing this device was previously set up correctly with ifconfig(8)).
route add -net 192.56.76.0 netmask 255.255.255.0 dev eth0
adds a route to the local network 192.56.76.x via "eth0". The word "dev" can be omitted here.
route del default
deletes the current default route, which is labeled "default" or 0.0.0.0 in the destination field of
the current routing table.
route add default gw mango-gw
adds a default route (which will be used if no other route matches). All packets using this route
will be gatewayed through "mango-gw". The device which will actually be used for that route depends
on how we can reach "mango-gw" - the static route to "mango-gw" will have to be set up before.
route add ipx4 sl0
Adds the route to the "ipx4" host via the SLIP interface (assuming that "ipx4" is the SLIP host).
route add -net 192.57.66.0 netmask 255.255.255.0 gw ipx4
This command adds the net "192.57.66.x" to be gatewayed through the former route to the SLIP inter‐
face.
route add -net 224.0.0.0 netmask 240.0.0.0 dev eth0
This is an obscure one documented so people know how to do it. This sets all of the class D (multi‐
cast) IP routes to go via "eth0". This is the correct normal configuration line with a multicasting
kernel.
route add -net 10.0.0.0 netmask 255.0.0.0 reject
This installs a rejecting route for the private network "10.x.x.x."
