[Sammelthread] ATI/AMD-Treiber -> Catalyst für WinXP/ Vista/ 7/ 8(.1)
AW: [Sammelthread] ATI/AMD-Treiber -> Catalyst für WinXP/Vista/7
http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx
Last Updates: 2/1/2014 AMD Catalyst 14.1 Beta v1.6
The change-log follows:
Feature Highlights of The AMD Catalyst 14.1 Beta Driver for Windows
Support for the following new AMD Desktop APU (Accelerated Processors) products:
AMD A10-7850K
AMD A10-7700K
Mantle Beta driver
  • AMD's Mantle is a groundbreaking graphics API that promises to transform the world of game development to help bring better, faster games to the PC
  • Performance gain of up to 45%(versus the DirectX version) for Battlefield 4 on the R9 290 Series
  • Performance gain of up to 200% (versus the DirectX version) for Star Swarm on the R9 290 Series
  • AMD Catalyst 14.1 Beta must be used in conjunction with versions of these applications that support Mantle
  • It is expected that these applications will have future updates to support additional AMD Mantle features
AMD Mantle Beta driver is currently supported on:
  • AMD Radeon R9 Series GPUs
  • AMD Radeon R7 Series GPUs
  • AMD Radeon HD 7000 Series GPUs
  • AMD Radeon HD 8000 Series GPUs
  • AMD A10-7000 Series and AMD A8-7000 Series APUs
  • Enhanced AMD CrossFire frame pacing - Support for 4K panel and Eyefinity non-XDMA CrossFire solutions (including the AMD Radeon R9 280, 270 Series, 7900 Series, 7800 Series) and Dual Graphics configurations
  • Frame pacing ensures that frames rendered across multiple GPUs in an AMD CrossFire configuration will be displayed at an even and regular pace
  • Supported on 4K panels and Eyefinity configurations
  • Supported on AMD Dual Graphics configurations
  • Supported on DirectX 10 and DirectX 11 applications
  • Resolved issue highlights of AMD Catalyst 14.1 Beta
  • Resolves ground texture flickering seen in Total War: Rome 2 with high settings (and below) set in game
  • Resolves flickering texture corruption when playing Call of Duty: Ghosts (multi-player) in the space station level
Resolved Issues
  • Ground texture flickering seen in Total War: Rome 2 with high settings (and below) set in game
  • Flickering texture corruption when playing Call of Duty: Ghosts (multi-player) in the space station level
  • Blu-ray playback using PowerDVD black screen on extended mode
  • Streaming VUDU HD/HDX content on Sharp PN-K321 (DP) causes the right-side half to flicker in and out
  • Black screen happened after wake up the monitor
  • Full screen issue at rotation in DX9 mode
  • Video window black screen when using Samsung Kies to play video
  • Crysis 2 negative scaling in outdoor scene
  • Crysis 2 has insufficient CrossFire scaling in some scene
  • Red Faction: The game has no or negative crossfire scaling with DX9 and DX11
  • Age of Conan has corruption and performance issues with crossfire enabled
  • Company of Heroes shadows are corrupted when using crossfire
  • Resident Evil 5 's performance is unstable when display mode set to Window mode
  • Total War: Shogun 2 flickering menu/text
  • Frame rate drop when disabling post-processing in 3DMark06
  • Negative Crossfire scaling with game "The Secret World" in DX11 mode
  • F1 2012 Crashes to desktop
  • Tomb Raider Hair Simulation Stutters on CFX
  • Negative CrossFire scaling experienced in Call of Duty
  • Battlefield 3 performance drop on Haswell systems
  • Choppy video playback on 4k Video
  • VSync ON Tearing with 2x1 Eyefinity SLS CrossFire
  • Far Cry 3 - Game flickering while changing resolutions
  • Display corruption and BSOD occurs when extending a display after disabling Multiple GPU SLS array
  • Flickering seen when enable three 4kx2k panels at the same time
  • No Video, just a black screen when setting Chrome to run in "High Performance" when playing certain video clips
  • Image crashed on Starcraft game
Known Issues
  • Mantle performance for the AMD Radeon HD 7000/HD 8000 Series GPUs and AMD Radeon R9 280X and R9 270X GPUs will be optimized for BattleField 4 in future AMD Catalyst releases. These products will see limited gains in BattleField 4 and AMD is currently investigating optimizations for them.
  • Multi-GPU support under DirectX and Mantle will be added to StarSwarm in a future application patch
  • Intermittent stuttering or stability issues may occur when utilizing Mantle with AMD CrossFire technology in BattleField 4 - AMD recommends using the DirectX code path when playing Battlefield 4 with multiple GPUs. A future AMD Catalyst release will resolve these issues
  • Notebooks based on AMD Enduro or PowerXpress technologies are currently not supported by the Mantle codepath in Battlefield 4
  • AMD Eyefinity configurations utilizing portrait display orientations are currently not supported by the Mantle codepath in Battlefield 4
  • AMD Eyefinity technology is not currently supported in the Star Swarm application
  • AMD testing for the AMD Catalyst 14.1 Beta Mantle driver has been concentrated on the following products: AMD Radeon R9 290X, R9 290, R9 280, R9 270, R7 260X, R7 260, HD 7000 Series, HD 8000 Series, A10-7850K and A10-7700K. Future AMD Catalyst releases will include full test coverage for all AMD products supported by Mantle.
  • Graphics hardware in the AMD A10-7850K and A10-7700K may override the presence of a discrete GPU under the Mantle code path in Battlefield 4
  • Frame Pacing for Dual Graphics and non-XDMA configurations above 2560x1600 do not currently work with Battlefield 3 and Battlefield 4. An upcoming release will enable support
  • DX9 Dual graphics is not supported in AMD Catalyst 14.1 Beta. An upcoming release will enable support
...und den habe ich wieder runter gemacht, weil .... "AMD Treiber wurde wieder hergestellt" laufend Abstürze....
Also, ich habe den Treiber Catalyt für Windows 7-32 heruntergeladen und das System jetzt einmal dazu bekommen, die ATI Mobility Radeon HD 4500 für das Notebook Acer Aspire 7540G zur Kenntnis zu nehmen. Vorhaer hat das System immer VGA angenommen. Geändert hat sich aber nichts. Ich kann nur 2 Auflösungen verwenden 600 x 800 und eine mit 1056 oder sowas. In beiden Fällen stellt sich das Windows Symbol als Ei (oval) dar, das heißt das Bildseitenverhältnis stimmt nicht.
Weiß jemand, wie ich das geändert bekomme? Für einen Hinweis wäre ich dankbar.
MfG
Catalyst 14.4 Release Candidate:
Feature Highlights of The AMD Catalyst 14.4 Release Candidate Driver for Windows
    • Support for the AMD Radeon™ R9 295X
    • CrossFire™ fixes enhancements:
      • Crysis 3 – frame pacing improvements
      • Far Cry 3 – 3 and 4 GPU performance improvements at high quality settings, high resolution settings
      • Anno 2070 – Improved CrossFire scaling up to 34%
      • Titanfall – Resolved in game flickering with CrossFire enabled
      • Metro Last Light – Improved Crossfire scaling up to 10%
      • Eyefinity 3x1 (with three 4K panels) no longer cuts off portions of the application
      • Stuttering has been improved in certain applications when selecting mid-Eyefinity resolutions with V-sync Enabled
    • Full support for OpenGL 4.4
      • OpenGL 4.4 supports the following extensions:
        • ARB_buffer_storage
        • ARB_enhanced_layouts
        • ARB_query_buffer_object
        • ARB_clear_texture
        • ARB_texture_mirror_clamp_to_edge
        • ARB_texture_stencil8
        • ARB_vertex_type_10f_11f_11f_rev
        • ARB_multi_bind
        • ARB_bindless_texture
        • ARB_spare_texture
        • ARB_seamless_cubemap_per_texture
        • ARB_indirect_parameters
        • ARB_compute_variable_group_size
        • ARB_shader_draw_parameters
        • ARB_shader_group_vote
    • Mantle beta driver improvements:
      • BattleField 4: Performance slowdown is no longer seen when performing a task switch/Alt-tab
      • BattleField 4: Fuzzy images when playing in rotated SLS resolution with an A10 Kaveri system
Known Issues
    • System will TDR or BSOD when encoding with Power Director 11
    • Driver installation might result in a black screen when installing on a Dual AMD Radeon R9 295X configuration under Windows 8.1 on specific platforms (see below). The issue can be overcome by rebooting the PC; upon reboot the display driver will be installed. The remaining Catalyst components can then be installed.
      • ASUS Crosshair V Formula-Z (990FX)
      • ASUS Maximus VI Extreme (Z87
      • ASUS Rampage IV Extreme (X79)
Windows: http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx
Linux: http://support.amd.com/en-us/kb-articles/Pages/latest-linux-beta-driver.aspx
AndrewD schrieb:
"The certified versions of the 14.4 drivers will be available within the next week or two"
Quelle: https://twitter.com/CatalystCreator/status/458334211125293057
Noch immer kein offzieller Mantle support für die HD7xxx. :mad: Hauptsache Crossfire und Open GL.... als würden davon ja so viele profitieren.
Mehr als von Mantle für die 7k Reihe... Gibt ein paar mehr OpenGL Spiele als Mantle Spiele.
ja, ich sehs auch so.
Man hat nicht das Gefühl, dass AMD parallele Entwicklungslinien fährt, sondern immer nur an einem Treiber mit rumfrickelt.
Das dauert und dauert und...
Und die anderen Tool-/hardwareanbieter lassen sich auch Zeit.
Immer noch ein TDR Problem, ich glaubs nicht.
ich beruf mich mal auf Wiki, ob die Zahlen noch stimmen weiß ich nicht
nVidia hat 7.000 Mitarbeiter die sich quasi nur um GPUs kümmern
AMD hat 11.000 Mitarbeiter, aber das Feld ist viel Größer, um das sie sich kümmern müssen.
Klar ist das für uns doof, aber so is es nun mal
Ich würde mal behaupten, dass BF4 aktuell deutlich ofter und von mehr Spielern gespielt wird, als sämtliche OGL Games zusammen.
Dann soll AMD doch Leute einstellen anstatt sie zu entlassen...
Würde ich stark bezweifeln.
früher Entwickelten die Softwarehäuser die Programme/Spiele für einen Herstellertreiber....
heute werden für einzelne Spiele Treiber angepasst ...
vielleicht gibts deswegen so viele Probleme mit den Treibern
Last Updates: 6/23/2014
Article Number: RN-WIN-RC14.6
Feature Highlights of The AMD Catalyst™ 14.6 RC2 Driver for Windows
  • Plants vs. Zombies (Direct3D performance improvements):
    AMD Radeon R9 290X - 1920x1080 Ultra – improves up to 11%
    AMD Radeon R9290X - 2560x1600 Ultra – improves up to 15%
    AMD Radeon R9290X CrossFire configuration (3840x2160 Ultra) - 92% scaling
  • 3DMark Sky Diver improvements:
    AMD A4 6300 – improves up to 4%
    Enables AMD Dual Graphics / AMD CrossFire support
  • Grid Auto Sport:
    AMD CrossFire profile
  • Wildstar:
    Power Xpress profile
    Performance improvements to improve smoothness of application
  • Watch Dogs:
    AMD CrossFire – Frame pacing improvements
  • Battlefield Hardline Beta:
Known Issues
  • Running Watch Dogs with a R9 280X CrossFire configuration may result in the application running in CrossFire software compositing mode
  • Enabling Temporal SMAA in a CrossFire configuration when playing Watch Dogs will result in Flickering
  • AMD CrossFire configurations with Eyefinity enabled will see application stability with BattleField 4 or Thief when running Mantle
  • Catalyst Install Manager text is covered by Express/Custom radio button text
  • Express Uninstall does not remove C:\Program Files\(AMD or ATI) folder
naaja, nichts neues im Westen!!
Abend....:-)
gibt es denn mittlerweile wieder eine Möglichkeit unter den 14.X Treibern Downsampling bei Amd zu betreiben.
Mit dem CRU-Tool geht das ja leider nur bis 13.2.......Und ja auch nur^^ bis 2560/1600:-(
Wollt mal wieder bisschen :DFallOut zocken auf dem Büroknecht!
