Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17.07.2002 09:20:56
ahead WinASPI: File 'C:\Programme\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16.12.2003 19:18:06
Nero Version: 6.3.1.6
Recorder: < Mein Netzwerkbrenner> Version: Nicht verfügbar - HA -2 TA 1 - 6.3.1.6
Adapter driver: <Virtual Device> HA -2
Drive buffer :
CD-ROM: <AOPEN DVD1648/LKY >Version: DSA4 - HA 0 TA 2 - 6.3.1.6
Adapter driver: <nvatabus> HA 0
=== Scsi-Device-Map ===
DiskPeripheral : ST380011A nvatabus Port 0 ID 0 DMA: Off
CdRomPeripheral : AOPEN DVD1648/LKY nvatabus Port 0 ID 2 DMA: Off
CdRomPeripheral : PLEXTOR DVDR PX-712A nvatabus Port 0 ID 3 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a xmasscsi Port 1 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a xmasscsi Port 1 ID 1 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a xmasscsi Port 1 ID 2 DMA: Off
=== CDRom-Device-Map ===
AOPEN DVD1648/LKY F: CDRom0
PLEXTOR DVDR PX-712A G: CDRom1
AXV CD/DVD-ROM K: CDRom2
AXV CD/DVD-ROM L: CDRom3
AXV CD/DVD-ROM M: CDRom4
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 682MB (699316kB)
Memory in use : 33 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.9.2004
CD-ROM (ISO)
14:11:11 #1 Text 0 File Isodoc.cpp, Line 6062
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:11:11 #2 Text 0 File Reader.cpp, Line 118
Reader running
14:11:11 #3 Text 0 File Writer.cpp, Line 124
Writer Mein Netzwerkbrenner running
14:11:11 #4 ISO9660GEN -11 File geniso.cpp, Line 3898
First writeable address = 0 (0x00000000)
14:11:11 #5 Text 0 File Burncd.cpp, Line 3198
Turn on Disc-at-Once, using CD-R/RW media
14:11:11 #6 Text 0 File DlgWaitCD.cpp, Line 244
Last possible write address on media: 2147483646 (477218:37.21)
Last address to be written: 187001 ( 41:35.26)
14:11:11 #7 Text 0 File DlgWaitCD.cpp, Line 249
Write in overburning mode: FALSE
14:11:11 #8 Text 0 File DlgWaitCD.cpp, Line 2107
Recorder: Mein Netzwerkbrenner;
CD type reading failed
ATIP Data: ?
14:11:11 #9 Text 0 File DlgWaitCD.cpp, Line 410
>>> Protocol of DlgWaitCD activities: <<<
14:11:11 #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 187002 (187002) = #187002/41:33.27
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 187002 blocks [ Mein Netzwerkbrenner]
14:11:11 #11 Text 0 File ThreadedTransferInterface.cpp, Line 982
Prepare recorder [ Mein Netzwerkbrenner] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 383287296, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
187002 | lead-out | 1 | 0x00 | 0x41
14:11:11 #12 Phase 137 File dlgbrnst.cpp, Line 1841
Image transfer started
14:11:11 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2342
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:11:58 #14 Text 0 File WriterStatus.cpp, Line 115
< Mein Netzwerkbrenner> start writing Lead-Out at LBA 187002 (2DA7Ah), lenght 0 blocks
14:11:58 #15 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
14:11:59 #16 Phase 138 File dlgbrnst.cpp, Line 1841
Image transfer completed successfully
14:11:59 #17 Phase 150 File dlgbrnst.cpp, Line 1841
Network transfer failed
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 17.07.2002 08:53:02
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28.10.2003 12:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\nvatabus.sys': Ver=5.10.2600.0446 built by: WinDDK, size=79360 bytes, created 03.06.2004 10:40:46 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
