TdrLevel: REG_DWORD. The initial level of recovery. The possible values are:
TdrLevelOff (0). – Detection disabled.
TdrLevelBugcheck (1) – Bug check on detected timeout, for example, no recovery.
TdrLevelRecoverVGA (2) – Recover to VGA (not implemented).
TdrLevelRecover(3) – Recover on timeout. This is the default value.
TdrDelay: REG_DWORD. The number of seconds that the GPU is allowed to delay the preempt request from the scheduler. This is effectively the timeout threshold. The default value is 2.
TdrDdiDelay: REG_DWORD. The number of seconds that the operating system allows threads to leave the driver. After a specified time, the operating system bug checks the system with the code VIDEO_TDR_FAILURE (0x116). The default value is 5.
TdrTestMode: REG_DWORD: Internal test usage.
TdrDebugMode: REG_DWORD: The debugging-related behavior of the TDR process.
TDR_DEBUG_MODE_OFF (0) breaks to kernel debugger before the recovery to allow investigation of the timeout.
TDR_DEBUG_MODE_IGNORE_TIMEOUT (1) ignores any timeout.
TDR_DEBUG_MODE_RECOVER_NO_PROMPT (2) recovers without break into the debugger. This is the default value.
TDR_DEBUG_MODE_RECOVER_UNCONDITIONAL (3) recovers even if some recovery conditions are not met (for example, recovers on consecutive timeouts).
TdrLimitTime: REG_DWORD (Windows Vista SP1 and later versions only): The default time within which a "TdrLimitCount" number of TDRs are allowed without crashing the system.
TdrLimitCount: REG_DWORD (Windows Vista SP1 and later versions only): The default number of TDRs (0x117) that are allowed in "TdrLimitTime" without crashing the system.
