Syntexer
- Okt. 2004
hab ein Problem mit Nero 6 (original)
Immer wenn ich ne CD Brennen will macht er den Lead In und bricht danach mit der Fehlermedlung "Reset aufgetreten" ab.
Hier mal meine Fehler LOG:
Markus
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Programme\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26.10.2004 17:35:34
Nero Version: 6.6.0.3 (Nero Express)
Recorder: <HL-DT-ST DVDRAM GSA-4160B>Version: A301 - HA 4 TA 0 - 6.6.0.3
Adapter driver: <> HA 4
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PIONEER DVD-ROM DVD-105 >Version: 1.22 - HA 0 TA 0 - 6.6.0.3
Adapter driver: <atapi> HA 0
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-ROM DVD-105 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PHILIPS PCRW804 atapi Port 0 ID 1 DMA: On
DiskPeripheral : WDC WD1200JD-00FYB0 02.0 si3112r Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.0B axsaki Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-ROM DVD-105 H: CDRom0
PHILIPS PCRW804 F: CDRom1
AXV CD/DVD-ROM E: CDRom2
HL-DT-ST DVDRAM GSA-4160 G: CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 608MB (622932kB)
Memory in use : 40 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.12.2004
CueSheet
15:30:23 #1 Text 0 File Burncd.cpp, Line 2866
Schutz vor Pufferleerlauf aktiviert
15:30:23 #2 Text 0 File Reader.cpp, Line 127
Reader running
15:30:23 #3 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-4160B running
15:30:23 #4 Text 0 File Burncd.cpp, Line 3151
Turn on Disc-at-Once, using CD-R/RW media
15:30:24 #5 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 324353 ( 72:06.53)
15:30:24 #6 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO (enabled: CD)
15:30:24 #7 Text 0 File DlgWaitCD.cpp, Line 2309
Recorder: HL-DT-ST DVDRAM GSA-4160B;
CDRW code: 00 97 10 00; CD manufacturer unknown
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
15:30:24 #8 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
15:30:24 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
2 indices, index0 (150) provided
original disc pos #0 + 300 (300) = #300/0:4.0
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 300 blocks [HL-DT-ST DVDRAM GSA-4160B]
1: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
original disc pos #0 + 323904 (323904) = #323904/71:58.54
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 323904 blocks [HL-DT-ST DVDRAM GSA-4160B]
15:30:24 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1040
Prepare recorder [HL-DT-ST DVDRAM GSA-4160B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x20; Session Closed, disc fixated
Tracks 1 to 2:
1: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 0 352800 1058400, ISRC ""
2: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 1058400 1411200 763233408, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x61 | 0x00
0 | 1 | 1 | 0x61 | 0x00
300 | 2 | 0 | 0x61 | 0x00
450 | 2 | 1 | 0x61 | 0x00
324354 | lead-out | 1 | 0x41 | 0x00
15:30:24 #11 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
15:30:24 #12 Text 0 File Burncd.cpp, Line 4038
Cache writing successful.
15:30:24 #13 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
15:30:24 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 10x (1.500 KB/s)
15:30:24 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2596
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:30:24 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2596
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #450
15:30:24 #17 Text 0 File Mmc.cpp, Line 16285
StartDAO : CD-Text - Off
15:30:24 #18 Text 0 File Mmc.cpp, Line 21025
Set BUFE: Buffer underrun protection -> ON
15:30:24 #19 Text 0 File Mmc.cpp, Line 16572
CueData, Len=48
61 00 00 34 00 00 00 00
61 01 00 21 00 00 00 00
61 01 01 21 00 00 02 00
61 02 00 21 00 00 06 00
61 02 01 21 00 00 08 00
41 aa 01 34 00 48 06 36
15:30:31 #20 SCSI -500 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x05E40000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
15:30:32 #21 SCSI -1114 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x0B701000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x10
0x00 0x00 0x00 0x90 0x29 0x00
15:30:32 #22 CDR -1114 File Writer.cpp, Line 311
Reset occurred
15:30:32 #23 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
15:30:32 #24 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
15:30:32 #25 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 10x (1.500 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28.10.2003 11:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03.08.2004 21:59:44 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Hoffe mal ihr könnt mir helfen cya
Syntexer
Edit: Is ein externer USB 2.0 DVD Brenner
Markus
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
10.12.2004
CueSheet
Reader running
ATIP Data:
DAO infos:
MCN: ""
Tracks 1 to 2:
DAO layout:
CueData, Len=48
Sense Code: 0x26
Sense Qual: 0x02
Sense Code: 0x29
Sense Qual: 0x00
Reset occurred
Existing drivers:
Registry Keys:
Syntexer
