win.doof
- März 2005
hu
also mein Problem ist mal wieder Windows XP . Ich weiß nicht warum aber irgend ein Treiber scheint mein Pc dazu zu bringen , dass es instabil läuft. Nach einem plötzlichen Restart habe ich aufjedenfall mal das Minidump File mit dem Windows-Tool ausgewertet.
Microsoft (R) Windows Debugger Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini0 30605-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
Debug session time: Sun Mar 6 20:29:10.437 2005 (GMT+1)
System Uptime: 0 days 1:17:43.993
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
Unable to load image kmixer.sys, Win32 error 2
*** ERROR: Module load completed but symbols could not be loaded for kmixer.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E, {c0000005, b87b5916, b7faac00, b7faa8fc}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Probably caused by : kmixer.sys ( kmixer+916 )
Followup: MachineOwner
naja daraus werde ich auch nicht gerade schlauer außer , dass es an der Datei kmixer.sys gelegen hat Vielleicht könnt ihr mir ja helfen ... Ich habe schon alles ausprobiert
Mein System:
Amd 3000 + (Clawnhammer)
1024mb Twin-Mos Ram
Abit kv8-max3
9800 pro von Sapphire
und der Rest halt ....
kann es an der Hardware vielleicht auch liegen ? Verstehen sich irgendwelche Treiber nicht ?
Edit: Alle Treiber sind auf dem neusten Stand ! Sowie das BIOS
Mein System:
1024mb Twin-Mos Ram
Abit kv8-max3
