Hallo, ich hab eine Frage. kann ich mit meiner onboard grafikkarte amd 760g hd 3000 serie "denke ich" mit afterburner aufnehmen und dabei mit der r270x battlefield 4 spielen ? sonst muss es leider ne gtx 660 ti werden wegen shadowplay.
Added Loop Recording for Bluesky Video Capture, it can record up to the last 30 minutes (max)
Reduced CPU usage when converting video stream from Bluesky Video Capture using AMD VCE H.264 Encoder
Fixed conversion failure issue of AMD VCE H.264 Encoder when convert video stream from Bluesky Video Capture with Full Screen Direct3D Capture Mode
Default output filename changed from "Capture" to DirectShow Capture Filter's name (or Target Window Title if use Bluesky Video Capture)
Changed "Other" to "Recording Mode" on Capture Setting Form
Removed "Move to Waite state" setting on Capture Setting Form
Added "/icap" for command line option (add capture source and press covert button)
Added support to stop transcode for each process
Fixed conversion error when using Intel QSV H.264 Encoder x64
Fixed issue when using DXVA Preprocessor
Changed "Enable frame rate conversion" to "Double Framerate" on DXVA Preprocessor Setting Form
Minor changes and fixes
Anstelle des kostenpflichtigen "Bluesky Video Capture" kann du jeden anderen Screencapture nehmen,
zb. die free version xsplit.com oder VH Screen Capture.
