das ergebnis von cpuz:
CPU-Z version 1.23
CPUID Output
Number of CPUs 1
APIC ID 0
Name Intel Pentium 4 540
Code name Prescott
Specification Intel(R) Pentium(R) 4 CPU 3.20GHz
Family/Model/Stepping F34
Extended Family/Model 0/0
Package LGA775
Core Stepping D0
Technology 0.09µ
Instructions Sets MMX, SSE, SSE2, SSE3
Clock Speed 3211.4 MHz
Clock multiplier x16.0
Front Side Bus Frequency 200.7 MHz
Bus Speed 802.9 MHz
L1 Data Cache 16 KBytes, 8-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 1024 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3211.4 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
Chipset
Northbridge Intel i915P/i915G rev. B1
Southbridge Intel 82801 (ICH6) rev. 3
Memory Type DDR
Memory Size 512 MBytes
Memory Frequency 200.7 MHz (1:1)
CAS# 3.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 8
Memory SPD
Module #1
General
Memory type DDR-SDRAM
Manufacturer (ID) (7F7F7FDA00000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number SDU06464H1B72MT-50
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge 2 3 3
TRAS# 6 7 8
Monitoring
Sensor Chip Winbond W83627EHF
PCI Device List
CPU to PCI Bridge
vendor ID 0x8086 (Intel)
device ID 0x2580
revision 0x4
sub vendor ID 0x8086 (Intel)
sub device ID 0x2580
class code 0x6
sub class code 0x0
bus 0, device 0, function 0
PCI to PCI Bridge
device ID 0x2581
revision 0x4
sub vendor ID 0x0 (unknown)
sub device ID 0x0
class code 0x6
sub class code 0x4
bus 0, device 1, function 0
Multimedia controller
device ID 0x2668
revision 0x3
sub vendor ID 0x1043 (AsusTek)
sub device ID 0x814E
class code 0x4
sub class code 0x3
bus 0, device 1B, function 0
PCI to PCI Bridge
device ID 0x2660
revision 0x3
sub device ID 0x0
class code 0x6
sub class code 0x4
bus 0, device 1C, function 0
DMI BIOS
BIOS #1
vendor American Megatrends Inc.
version 1003.004
date 10/05/2004
DMI System Information
System #1
manufacturer Actebis
product P5GD1
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID 00020003-00040005-00060007-00080009
DMI Baseboard
Baseboard #1
vendor ASUSTeK Computer INC.
model P5GD1
revision Rev 1.xx
serial MB-1234567890
DMI System Enclosure
System enclosure #1
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
CPU #1
manufacturer Intel
model Intel(R) Pentium(R) 4 CPU 3.20GHz
clock speed 3200.0MHz
FSB speed 200.0MHz
multiplier 16.0x
DMI Memory Controller
Memory Controller #1
correction unknown
Max module size 1024MBytes
DMI Memory Module
Memory Module #1
designation DIMM0
size 512MBytes (double bank)
Memory Module #2
designation DIMM1
Memory Module #3
designation DIMM2
Memory Module #4
designation DIMM3
DMI Extension Slot
Slot #1
designation PCIEX16
type PCI-X
width 32 bits
populated yes
Slot #2
designation PCI_1
type PCI
width 32 bits
populated no
Slot #3
designation PCI_2
type PCI
width 32 bits
populated no
Slot #4
designation PCI_3
type PCI
width 32 bits
populated yes
Slot #5
designation PCIEX1_1
type PCI-X
width 32 bits
populated no
Slot #6
designation PCIEX1_2
type PCI-X
width 32 bits
populated no
Slot #7
designation PCIEX1_3
type PCI-X
width 32 bits
populated no
DMI Physical Memory Array
Physical Memory Array #1
location Motherboard
usage System Memory
correction None
max capacity 4096MBytes
max# of devices 4
DMI Memory Device
Memory Device #1
designation DIMM0
format DIMM
type SDRAM
total width 64bits
data width 64bits
size 512MBytes
Memory Device #2
designation DIMM1
format DIMM
type unknown
Memory Device #3
designation DIMM2
format DIMM
type unknown
Memory Device #4
designation DIMM3
format DIMM
type unknown
Software
Windows Version Microsoft Windows XP Workstation Service Pack 1 (Build 2600)
DirectX Version 9.0b
kannst damit was anfangen??
bei cpuz hab ich nich direkt ne temperatur gesehn!hab halt nur im bios was von 70° celsius gelesen,bei cpu temperatur!
