Ok, sie ist leider nicht da.
Der Auszug:
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20100525/php_imagick.dll' - /usr/lib/php5/20100525/php_imagick.dll: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: phpinfo(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in Command line code on line 1
Configuration File (php.ini) Path => /etc/php5/cli
Loaded Configuration File => /etc/php5/cli/php.ini
Scan this dir for additional .ini files => /etc/php5/cli/conf.d
Additional .ini files parsed => /etc/php5/cli/conf.d/00-ioncube-loader-5.4.ini,
/etc/php5/cli/conf.d/10-pdo.ini,
/etc/php5/cli/conf.d/20-curl.ini,
/etc/php5/cli/conf.d/20-gd.ini,
/etc/php5/cli/conf.d/20-imagick.ini,
/etc/php5/cli/conf.d/20-imap.ini,
/etc/php5/cli/conf.d/20-intl.ini,
/etc/php5/cli/conf.d/20-mcrypt.ini,
/etc/php5/cli/conf.d/20-mysql.ini,
/etc/php5/cli/conf.d/20-mysqli.ini,
/etc/php5/cli/conf.d/20-pdo_mysql.ini,
/etc/php5/cli/conf.d/20-pdo_sqlite.ini,
/etc/php5/cli/conf.d/20-sqlite3.ini,
/etc/php5/cli/conf.d/20-xsl.ini,
/etc/php5/cli/conf.d/zend_extensions_psa.ini
user_ini.cache_ttl => 300 => 300
user_ini.filename => .user.ini => .user.ini
Supported handlers => cdb cdb_make db4 inifile flatfile qdbm
Classes => AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
