Muss es denn C# sein? Eine Batch-Datei sollte das auch können. Hier was von Stackoverflow.
Following works on Win 7 from a cmd prompt with admin privileges:
To Disable:
netsh interface set interface "Wireless Network Connection" Disable
To Enable:
netsh interface set interface "Wireless Network Connection" Enable
To get the interface names:
C:\Users\nirmal>netsh interface show interface
Admin State State Type Interface Name
Enabled Connected Dedicated Wireless Network Connection
Disabled Disconnected Dedicated Local Area Connection
