VM nach Update kaputt
Prinzenrolle_
Sep. 2007
Hallo
Ich hab ein Update (dist-upgrade) bei einer VM gemacht. Nun, nach dem Restart ist putt...
In Virsh ist die VM noch sichtbar und State ist running. Destroy und Start bringt leider nichts...
Snapshot habe ich natuerlich keinen :(
Hier noch die XML:
Code:
<domain type='kvm'>
  <name>media</name>
  <uuid>9c4b87d8-dc1e-11e3-ad2f-74d02b9213b3</uuid>
  <description>9c4b87d8-dc1e-11e3-ad2f-74d02b9213b3@lucy.sook.ch::::d8uSFcvPCLzSoogqgWjESIC48OZwzmUE</description>
  <memory unit='KiB'>4194304</memory>
  <currentMemory unit='KiB'>4194304</currentMemory>
  <vcpu placement='static'>4</vcpu>
  <os>
    <type arch='x86_64' machine='pc-0.13'>hvm</type>
    <boot dev='hd'/>
    <bootmenu enable='no'/>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  <clock offset='utc'/>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/bin/kvm-spice</emulator>
    <disk type='file' device='disk'>
      <driver name='qemu' type='qcow2' cache='writeback'/>
      <source file='/vm//drives/9c4b87d8-dc1e-11e3-ad2f-74d02b9213b3/media.qcow2'/>
      <target dev='hda' bus='ide'/>
      <address type='drive' controller='0' bus='0' target='0' unit='0'/>
    </disk>
    <controller type='pci' index='0' model='pci-root'/>
    <controller type='ide' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
    </controller>
    <controller type='usb' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <interface type='bridge'>
      <mac address='de:ad:19:a2:43:54'/>
      <source bridge='br1'/>
      <bandwidth>
      </bandwidth>
      <model type='e1000'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/>
    </interface>
    <input type='tablet' bus='usb'/>
    <input type='mouse' bus='ps2'/>
    <input type='keyboard' bus='ps2'/>
    <graphics type='vnc' port='-1' autoport='yes' keymap='en-us'/>
    <video>
      <model type='cirrus' vram='9216' heads='1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/>
    </video>
    <memballoon model='virtio'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
    </memballoon>
  </devices>
</domain>
Console funktioniert leider auch nicht mehr. Bekomme folgenden Fehler:
virsh # console media
Connected to domain media
Escape character is ^]
error: internal error: cannot find character device <null>
Im XML habe ich folgende Zeile mal rein gemacht gehabt:
Code:
 <serial type='pty'>
   <target port='0'/>
 </serial>
 <console type='pty'>
   <target type='serial' port='0'/>
 </console>
Danach kam einfach dies:
und Freeze
Kann mir da jemand weiter helfen?
Hast du beim Host oder dem Gast (die VM) ein dist-upgrade gemacht?
Mounte das Dateisystem der VM und sieh dir den Bootloader an?
Hallo HominiLupus
Beim Gast... Ok, ich vermute, dass da das img im boot kaputt ist. Mounte mal :)
Also ich konnte jetzt mal den boot folder mounten
der sieht aber eigentlich nicht schlecht aus...
Auf was soll ich achten?
push
