Hast du die Boot CD erstellt nachdem der RAID 5 Verbund am laufen war?
Acronis.de FAQ Seite
The standalone version of Acronis True Image uses embedded Linux drivers for RAID arrays. There is a probability that Linux drivers for a specific RAID array have not been included yet. In this case you should try to use a special plug-in for the BartPE instead of the standalone version. This plug-in allows you to use Windows drivers for the RAID array when running Acronis True Image from BartPE bootable CD. You may also contact Acronis Support Team and report that the standalone version doesn't recognize your RAID array. Our Development Team will add drivers as soon as possible.
