COMPLETE CHANGELOG (only fixes, no performance improvements listed):
Scenery
SCENERY: Night textures not appearing on Vancouver's Canada Place
SCENERY: Drop-out of night textures occurring on many generic buildings
SCENERY:Mission Paris Airshow at LFPB
SCENERY: Nijubashi bridge is on the wrong place.
SCENERY :3 disconnected jetways at airport: EGCC
SCENERY : Airport LCEN (Ercan) in Cyprus should be closed or removed
SCENERY:EGNV airport elevation sloped to the wrong value causing severe visual anomalies
SCENERY: Water sloping and boundary resolution issues Danube River
SCENERY:Water sloping issue (missing data due to export issue) Vistula River (Largest river in Poland)
SCENERY :Water Sloping issue at the Humbar Bridge (UK)
SCENERY :Water Sloping issues with the River Avon
SCENERY :Water Sloping issues with the River Thames
SCENERY: Autogen buildings clipping into Dodger Stadium
SCENERY: Detached shoreline seen snaking through water well offshore for 100 miles near Tijuana
SCENERY: Dodger stadium in Los Angeles is inside of a crater
SCENERY: Elevation of terrain around SAOC (Area De Material) differs by about 1300' from elevation of airport
SCENERY: Elevation of terrain around SAVE (Esquel) differs by about 2500' from elevation of airport
SCENERY: Elevation of terrain around SUSO (Salto Nueva Hesperides Intl) differs significantly from elevation of airport
SCENERY: FVFA (Victoria Falls) is sitting in a hole
SCENERY: Gaps seen in taxiways and apron at KSAV (Savannah/Hilton Head Intl)
SCENERY: Horrendous problems with slivers and slabs of land splitting up the bay in Lisbon, Portugal
SCENERY: Last character ("u") in name of Montreal/Pierre-Elliott-Trudeau airport has been dropped from airport name in the geodatabase
SCENERY: Mismatched elevations on adjacent water polygons near MNSC (San Carlos)
SCENERY: Road comprising Brooklyn Battery Tunnel in New York is not attributed as tunnel, runs across Buttermilk Channel
SCENERY: Runway elevation at MNBL (Bluefields) is significantly higher than the airport flattening polygon
SCENERY: Taxiway B at KSAV (Savannah/Hilton Head Intl) is doing the drunken sailor dance
SCENERY: Water sloping issues in Danube River
SCENERY: Yukon River missing from Galena, AK all the way to the ocean
SCENERY:Havana Harbor in Cuba is missing from FSX. It was present in FS9
LIVING WORLD: Traffic driving on the wrong side of the road in Japan
Aircraft
A/C Airbus A321 - Panel - Backup Altimeter: 10,000's feet digit does not scroll properly
A/C Airbus A321 - Panel - ECAMS: FF per engine should not be labelled "%", but rather "lbs/hour"
A/C A321 - Panel - The wind value is not being displayed correctly on the Nav Display
A/C Airbus A321 - Panel - PFD: MCP-selected altitude not be displayed fully when 5 digits. (First digit is cut off)
A/C C172 - Panel ---Middle and Inner marker lights are mis-aligned when illuminated
A/C Cessna 172 - Panel - The placard for the call sign is poorly located - covers up screws when there's lots of blank panel space to the right of it
A/C DeHavilland Beaver - VC elevator trim indicator not in sync with 2D version
A/C Default Beaver's exterior's doors are just basic plain color.
A/C Baron 58 G1000: Instrumental panel is not localizable. Need to add panel.cfg
A/C Boeing 737-800 - Panel - The True Airspeed (TAS) value displayed on the Nav Display is actually Indicated Airspeed (KIAS)
A/C Maule M7 - VSI has a limit of +/- 1100 fpm
A/C Maule Flap Initialization
A/C Get door open and exit sounds working again.
A/C Sort Order of Aircraft Manufacturers is broken for extended characters
Missions
MISSIONS: Monsoon Approach: Rain is missing
MISSIONS: Swedish Championship Soaring Course: Thermals are not showing in mission (schematic)
MISSIONS: Swedish Championship Soaring Course: When User gets the Club Record time they are not getting the trophy for it
MISSIONS: Austrian Alpine Soaring Course: Flight Plan cruising altitudes are extremely high (41,000 feet)
MISSIONS: Austrian Alpine Soaring: Crossing over the airport (the final checkpoint) does not stop the timer (counter, waypoint)
MISSIONS: Austrian Alpine Soaring: When User passes finish line and successfully lands on runway they fail the mission
MISSIONS: Flour Power gets a green check when Sitka Approach is completed (reward, check mark)
MISSIONS: Caribbean landing reward not being displayed on success
MISSIONS: Mission Compass displays too many directional arrows (pointer)
MISSIONS: 747 Test Flight has ambulances placed incorrectly
MISSIONS: 747 Test flight reveals terrible shadow problems on the compass rose.
MISSIONS: Completing the Oil Rig Rescue mission doesn't result in a 'You've Succeeded' status or reward
MISSIONS: Telluride missing the runway without crashing leaves you in unending state
Multiplayer
MP: banned list ineffective in preventing repeated friend request
MP: mp needs boot functionality both in game player and at the host screen
MP: UI: Hard to chat with all these users in the main lobby with a lot of users logging in and out
MP: Join Friends Game should not be a selectable option with friends who are already in your session.
MP: unexpected error message pop up after user logon with gamespy.
MP:Connection errors, including exiting out of session kicks player out of GameSpy and gives "you may have logged in on another computer" error
MP missions: Things are broken when you try to host a session and then end the mission and then host another session
MP:Cannot make a connection: We believe we have reduced the occurrence of this, and we have reports of better success on GameSpy ahead of SP1 so they may have fixed something on their end too.
MP: Shared Cockpit - Reverse Thrust - Reverse Thrust is not a synchronized component
Misc
Thermals : Default thermals as defined in ThermalsDescriptions.xml far too big and strong for most landclasses
ATC: ATIS - Pressure displayed & spoken in inches when Int'l setting is Hybrid (feet, millibars)
DisabledTrafficAirports persist to flights/missions that have no disabled traffic airports
