Details
Product: Windows Operating System
Source: System Error
Version: 5.2
Symbolic Name: ER_KRNLCRASH_LOG
Message: Error code %1, parameter1 %2, parameter2 %3, parameter3 %4, parameter4 %5.
Explanation
A blue screen (Stop error) was reported. The message contains details about the error. A matching event with Event ID 1001 might also appear in the event log. This matching event displays information about the specific error that occurred.
User Action
No user action is required.
Related Knowledge Base articles
You can find additional information on this topic in the following Microsoft Knowledge Base articles:
• You receive a "STOP: 0x000000D5" error message when you close an IP Phone connection on a Windows XP Service Pack 2-based Toshiba computer or on a Windows XP Tablet PC Edition 2005-based Tablet PC
Discusses the problem where you receive a Stop error "0x000000D5" when you try to disconnect an IP Phone on a Toshiba computer that is running Windows XP SP2.
• Command AntiVirus version 4.62.4 causes an error message on a blue screen in Windows XP Service Pack 2
Describes an issue where you receive an error message on a blue screen when you restart your computer after installing Command AntiVirus version 4.62.4 in Windows XP SP2.
• "Stop 0x000000A5 the ACPI BIOS in the system is not fully compliant with the ACPI specification" error message when the computer resumes from hibernation
You may experience any one of the following symptoms: Your computer automatically restarts. After you log on, you receive the following error message: Microsoft Windows The system has recovered from a serious error. A log of this error has been...
• A diagnostic program may immediately close and you may receive a "STOP 0x00000050" or "STOP 0x0000000A" error message in Windows Server 2003, Windows 2000, or Windows XP
Describes a problem that may occur if a computer is infected with a variant of the Sdbot virus.
• The HaxDoor virus may cause a "STOP 0x00000050" or "STOP 0x0000008e" error message
Explains that the HaxDoor virus may generate a Stop error message or restart your computer in Windows Server 2003, Windows 2000, or Windows XP. You can manually remove the variant of the HaxDoor virus to resolve this issue.
• Error Message: STOP 0x00000050 (0xffffffe0, 0x00000001, 0xf30da010, 0x00000000) PAGE_FAULT_IN_NONPAGED_AREA
You may experience any of the following symptoms: Your computer automatically restarts. After you log on, you receive the following error message: Microsoft Windows The system has recovered from a serious error. A log of this error has been...
• Windows XP Clients Cannot Connect to a Windows 2000 Terminal Services Server
When you try to connect from a Windows XP-based client to a Windows 2000-based Terminal Services server, the connection may not succeed and you may receive the following error message: Because of a security error, the client could not connect to...
• You receive a "STOP: 0x000000E3" error message when you safely remove an encrypted USB storage device from a computer that is running Windows XP Service Pack 2
Fixes a problem that may occur when you safely remove certain models of encrypted USB storage devices from Windows XP Service Pack 2-based computer. Provides a hotfix to resolve the problem.
• The computer restarts unexpectedly, or you receive an error message in Windows XP: "Stop: 0x000000D1"
Fixes a problem that may occur if the TCP/IP stack tries to access a buffer that the stack did not initialize. This problem may occur if the network uses Internet Protocol security (IPsec).
Hilft das weiter?
