Admirale
- März 2003
hi, wollte mal fragen ob ich Barton CPU´s bis 3000+ auf meinem Board kloppen kann??
mein System:
Mein herzallerliebstes System
hier ne Auflistung der Updates meines Mobo! ist auf dem aktuellsten Stand! (ganz unten)
K7NCR18D Series Mother Board BIOS update history
K7NCR18D Series mother board include:
K7NCR18D PRO
K7NCR18D
K7NCR18DM
BIOS VERSION 11/21/2002
1. Supports 48Bits Harddisk.
2. Supports 204MHZ,207MHZ,211MHZ FSB.
3. Default disable smart card interface
4. AGP aperture size 64MB instead of 32MB.
BIOS VERSION 12/09/2002
1. Fixed system sometime hung up at "Detecting IDE drivers" or Post code
63H,65H or 75H .
2. Fixed FAN speed incorrect in BIOS setup when use ATI7500 or ATI8500 VAG Card
BIOS VERSION 12/14/2002
1. Fixed when you are using Duron CPU and flash BIOS using Awdflash
then must clear CMOS to boot up system .
2. Disable Fast_write feature when use G400 VGA Card .
BIOS VERSION 12/25/2002
1. AGP aperture size default size set to ->128M.
2. LAN is set to Auto when "load Basic default"
3. Fixed KingMAX RAM Module P/N MPXB62D-68KMAA unstable when memory is 400MHZ
BIOS VERSION 12/30/2002
1. Don't support Memory Frequency item is below 100% Because when FSB=133 and
memory below 100MHZ that will cause system hung up .
2. Fix Game Port (Joystick) device with yellow mark '!' under Windows 98 SE ?
BIOS VERSION 01/08/2003
1. Supports FSB clock up to 266MH
2. Fixed DDR400 can't be selected when use expert in BIOS setup in
WinFast K7NCR18G series
3. When FSB clock above 145MHZ then enable user to select memory clock under
83% of FSB in BIOS setup.
BIOS VERSION 01/27/2003
1. Supports Athlon XP 3000+ (PID#21922).
2. Fixed Seagate 160GB 48Bit HDD (ST3160021A)
cannot work in CHS access type mode issue
3. LAN Led is turned off when disabled .
BIOS VERSION 02/14/2003
1.Enable C1/C2 disconnect function for NB A3 later version
2.Improves KingMax Model no:MPXB62D-68KX3-MBA compatiblity.
3.Disable Com2 when use K7NCR18G series Mother board.
BIOS VERSION 03/26/2003
Note:Since this date code BIOS that can't be used in K7NCR18G series mother board.
1.Fixed user password can't be used .
2.Supports FSB 200 select in optimal item in BIOS setup
3.Supports Barton CPU up to 3200+
4.Supports S.M.A.R.T. of HD.
5.BIOS will tell user whether Dual memory is enabled during POWER ON.
6.Fixed overclock sometime will cause system BIOS crash intermittent.
BIOS VERSION 03/27/2003
1.Disable C1 when SPP is version A2 .
BIOS VERSION 04/01/2003
1.Fixed W/O CPU FAN POWER waring is disabled in BIOS Setup
BIOS VERSION 04/18/2003
1.USB keyboard support and USB mouse keyboard support is enabled in BIOS setup
to let USB bootable device can be used.
2.Improves Kingmax RAM module P/N MPXB62D-68KX3-MB compatibility issue .
3.Supports Athlon XP 2800+ for FSB 266 & L2 cache 512K(133*16)
4.Fixed when plug 3 DIMM RAM Module "Dual bank mmeory enabled" don't display
during POST code .
5.S.M.A.R.T. of HD default is disabled in BIOS setup CMOS
BIOS VERSION 04/24/2003
1.Support Athlon XP 2600+/2700+ for FSB333(166MHz) & L2 cache 512K
mein System:
K7NCR18D PRO
K7NCR18D
K7NCR18DM
63H,65H or 75H .
during POST code .
