lalanunu
- Nov. 2007
hi,
hier mal das, was ich mir im internet zusammengesucht hab, doch leider geht da irgendwas net... bzw ich bin einfach zu dumm für ^^
wenn ich die datei auf dem server öffne, sagt der browser mir folgende fehlermeldung:
Fatal error: Cannot redeclare fputcsv() in /usr/export/www/vhosts/funnetwork/hosting/...homepageadresse.../form2csv1.php on line 203
Da ich mich damit gar nich auskenn, frag ich euch
PHP:
<?php
* form2csv.php - Form Data Logger
* Copyright (c) 2003-08-18 by The M.I.P. <the_mip (at) gmx.fr>
* $Id: form2csv.php,v 1.3 2003/08/19 00:21:43 djoe Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
// BEGIN Config
$formpage = 'testen.html'; // File name of HTML form - form action has to point towards this script
$exitpage = 'danke.html'; // File name of HTML exit page
$include_authinfo = true; // Set to false to not include $PHP_AUTH_USER and $PHP_AUTH_PW
$include_timestamp = true; // Set to false to not include current time
$timeformat = 'U'; // Time format as used by date() - see also http://php.net/date
$dedupe = 'PHP_AUTH_USER'; // Form field to check for dupes
$dupe = 'update'; // 'ignore', 'update' or 'append' dupe entries
$datadir = 'data/'; // Directory to hold the CSV files - must be writable by the webserver (chmod 0777)
$csvname = ''; // Common prefix for CSV files - might also be supplied e.g. via a hidden form field
// END Config
// BEGIN Main
//error_reporting(E_ALL);
error_reporting(7);
// Merge $_POST and $_GET vars into an array - $_REQUEST would'nt fit here as cookie data can be annoying
$formvars = array_merge($_POST, $_GET);
$prefix = 'data';
$bufsize = 32768; // Size of line buffer
if (empty($formvars)) {
if (is_file($formpage) && is_readable($formpage)) {
include($formpage);
exit;
} else {
// Spit out a small test form
<title>form2csv Test Form</title>
<form action="form2csv.php" method="post">
<input type="hidden" name="csvname" value="form2csvtest"/>
<input type="text" name="foo" /><br />
<input type="text" name="bar[2]" /><br />
<input type="text" name="bar[1]" /><br />
<input type="text" name="foobar" /><br />
<input type="submit" />
</form>
<?php
exit;
if ($include_authinfo && isset($PHP_AUTH_USER) && isset($PHP_AUTH_PW)) {
$formvars['PHP_AUTH_USER']=$PHP_AUTH_USER;
$formvars['PHP_AUTH_PW']=$PHP_AUTH_PW;
if ($include_timestamp) {
$formvars['time']=date($timeformat,time());
if (!empty($formvars['csvname']) && empty($csvname)) {
// Make a sane csv data file prefix when csvname is supplied via form
$csvname = substr(urlencode(strtr($formvars['csvname'], ' ./\?&', '______')), 0, 32);
unset($formvars['csvname']);
if (!empty($csvname)) {
$prefix = $csvname;
$csvname .= '-';
// Reformat or display array
// Derived from a function found at http://www.devdump.com/phpxml.php
function flat_a($obj, $prefix='data', $ksort = 1, $outputmode = 0) {
static $__level_deep, $flatarr;
if (!isset($__level_deep) || $obj==='clear') {
$__level_deep = array();
if (!isset($flatarr) || $obj==='clear') {
$flatarr = array();
if ($obj==='clear') {
return;
if (is_object($obj)) {
if ($outputmode == 1) {
print '[obj]';
return $flatarr;
} elseif (is_array($obj)) {
if ($ksort > 0) {
ksort($obj);
foreach(array_keys($obj) as $keys) {
array_push($__level_deep, "[".$keys."]");
flat_a($obj[$keys], $prefix, $ksort, $outputmode);
array_pop($__level_deep);
return $flatarr;
} else {
print $prefix.implode("",$__level_deep)." = $obj\n";
$flatarr_key = $prefix.implode("",$__level_deep);
$flatarr_val = $obj;
if (isset($flatarr_val)) {
$flatarr[]["{$flatarr_key}"] = $flatarr_val;
return $flatarr;
// Return flat array as csv
function flat_a2csv($arr, $header = 0) {
$line = '';
if ($header == 0) {
foreach(array_values($arr) as $vals) {
foreach(array_values($vals) as $keys) {
if (!empty($line)) {
$line .=',';
$line .= '"'.addslashes($keys).'"';
} else {
foreach(array_keys($vals) as $keys) {
$line .=',';
return $line."\n";
// Generate a name which is unique for every different HTML form dataset
function arrayname($arr, $prefix='data') {
global $dedupe, $dedupe_num;
flat_a('clear');
$narr = flat_a($arr, $prefix);
unset($arr);
flat_a('clear');
$arrname = '';
$i=0;
foreach(array_values($narr) as $vals) {
$arrname .= $keys;
if ($keys == "{$prefix}[{$dedupe}]") {
// Index of field to dedupe
$dedupe_num = $i;
$i++;
return md5($arrname);
// Based on a function posted on http://php.net/manual/de/function.fgetcsv.php
function fputcsv ($fp, $array, $deliminator=',', $enclosure='"') {
$alwaysenc = 1; // Always add enclosure
$line = '';
foreach($array as $val) {
// remove any windows new lines,
// as they interfere with the parsing at the other end
$val = str_replace("\r\n", "\n", $val);
if ($alwaysenc) {
$line .= $enclosure.addslashes($val).$enclosure.$deliminator;
} else {
// if a deliminator char, a double quote char or a newline
// are in the field, add quotes
if (ereg("[$deliminator\"\n\r]", $val)) {
$val = $enclosure.str_replace($enclosure, $enclosure.$enclosure, $val).$enclosure;
$line .= $val.$deliminator;
// strip the last deliminator
$line = substr($line, 0, (strlen($deliminator) * -1));
$line .= "\n";
// we don't care if the file pointer is invalid,
// let fputs take care of it
return fputs($fp, $line);
if (!is_dir($datadir) || !is_writable($datadir)) {
die("Error: Data dir '{$datadir}' is not writable!");
flat_a('clear');
$fla = flat_a($formvars, $prefix);
$csvname .= arrayname($formvars).'.csv';
$newfile = 0;
// Shared lock on source csv data file
$old = @fopen($datadir.'/'.$csvname, 'r') or $newfile = 1;
if ($newfile == 0) {
$oldstat = stat($datadir.'/'.$csvname);
if ($oldstat[8] == 0) {
// CSV exists, but contains no data
$newfile = 1;
} else {
flock($old, 1) or die("Error: Could not lock source file '".$datadir.'/'.$csvname."'");
// Exclusive lock on destination csv data file
$new = @fopen($datadir.'/'.$csvname.'.new', 'w');
flock($new, 2) or die("Error: Could not lock destination file '".$datadir.'/'.$csvname."'");
if ($newfile == 1) {
// Prepend header with field names
fputs($new, flat_a2csv($fla,1));
$dupe_found = 0;
$i = 0;
while($flb = @fgetcsv($old, $bufsize)) {
if ($i == 0) {
if (!strstr($flb[0], $prefix.'[')) {
// Prepend header with field names if first line does'nt contain it already
if (($dupe == 'update' || $dupe == 'ignore')
&& isset($dedupe_num)
&& $flb["{$dedupe_num}"] == $fla["{$dedupe_num}"]["{$prefix}[{$dedupe}]"]) {
$dupe_found = 1;
if ($dupe=='update') {
continue;
fputcsv($new, $flb);
$i++; // Increment line counter
if (($dupe_found == 1 && $dupe == 'update') || $dupe == 'append' || !isset($dedupe_num)) {
// Update dupe or append
fputs($new, flat_a2csv($fla));
@fclose($old); // Releases lock automatically
@unlink($datadir.'/'.$csvname); // Delete old csv data file
fclose($new);
rename($datadir.'/'.$csvname.'.new', $datadir.'/'.$csvname);
if (is_file($exitpage) && is_readable($exitpage)) {
include($exitpage);
exit;
} else {
<title>form2csv</title>
Form data logged - Thx for your submission!
<?php
exit;
PHP:
zeile 174 // Based on a function posted on [url]http://php.net/manual/de/function.fgetcsv.php[/url]
$line = '';
if ($alwaysenc) {
} else {
$line .= "\n";
zeile 203 }
