sck3004
- Jan. 2007
seit einigen Tagen schmiert mir mein BS immer mal wieder ab. mit einem Bluescreen.
Hoffe jemand kann helfen und mir den Text im debugger erklären.. bzw. sagen was los ist derzeit, danke
________________
Windows NT Version 6.0 Build: 6002 Service Pack 2
Product (0x1): Windows Vista (TM) Ultimate
Edition: Ultimate
BuildString: 6002.18005.x86fre.lh_sp2rtm.090410-1830
Flavor: Multiprocessor Free
Architecture: X86
LCID: 1031
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: dxgkrnl
FAULTING_MODULE: 81a47000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 49e01b4f
FAULTING_THREAD: 87179c78
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_FAULT
CUSTOMER_CRASH_COUNT: 4
BUGCHECK_STR: 0xEA
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 8ed21e28 to 81b14b0d
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
8b7ca954 8ed21e28 000000ea 87179c78 00000000 nt+0xcdb0d
8b7ca998 8ed1a381 8b7ca9e4 00000000 8ed193d7 dxgkrnl+0x15e28
8b7ca9c0 8e82def4 8b7ca9e4 00000000 00000000 dxgkrnl+0xe381
8b7caa10 8e82809c 8e9bf36f 8b7caaac 00000bb8 atikmdag+0x27ef4
8b7caa30 8e9c747c 855c3001 8b7caa48 8e9bf36f atikmdag+0x2209c
8b7caa88 8e9ce23c 86d977c8 8e9bf36f 8b7caaac atikmdag+0x1c147c
8b7caabc 8e9cee7a 86d977c8 0000000a 8ec1cd50 atikmdag+0x1c823c
8b7caae8 8e9d523f 86d977c8 86d977c8 86d97900 atikmdag+0x1c8e7a
8b7caafc 8e9ce12e 86d977c8 8ec1cd50 0000000a atikmdag+0x1cf23f
8b7cab10 8e9bc8aa 86d977c8 00000000 86d977c8 atikmdag+0x1c812e
8b7cab24 8e9c6a93 86d977c8 00000000 86d57010 atikmdag+0x1b68aa
8b7cab40 8e9bce60 86d977c8 8b7cab60 8e80960d atikmdag+0x1c0a93
8b7cab4c 8e80960d 86d977c8 855ba008 00000000 atikmdag+0x1b6e60
8b7cab60 8e8144d2 00000000 c0000001 855ba008 atikmdag+0x360d
8b7cab90 8e815631 8690d260 8690d420 00000000 atikmdag+0xe4d2
8b7caba4 8ed81f94 00000000 84532510 8690d260 atikmdag+0xf631
8b7cabc4 8ed82fe7 8567d8b8 84532510 00000000 dxgkrnl+0x75f94
8b7cabec 8ed88ce0 84532510 84532510 00000302 dxgkrnl+0x76fe7
8b7cac04 8ed2538f 00000000 00000102 8567d8b8 dxgkrnl+0x7cce0
8b7cac6c 8ed41ec8 8567d8b8 000127c8 00000000 dxgkrnl+0x1938f
8b7cac98 8ed41c28 8567d8b8 00000000 00000000 dxgkrnl+0x35ec8
8b7cacc4 8ed135b0 00000002 87149d18 87149e18 dxgkrnl+0x35c28
8b7cad54 8ed41f6f 8567d8b8 81a8b906 8567d8b8 dxgkrnl+0x75b0
8b7cad68 8ed775d1 8567d8b8 00000000 87179c78 dxgkrnl+0x35f6f
8b7cad7c 81c1cc42 8567d8b8 40e57d3d 00000000 dxgkrnl+0x6b5d1
8b7cadc0 81a85efe 8ed7756f 8567d8b8 00000000 nt+0x1d5c42
00000000 00000000 00000000 00000000 00000000 nt+0x3eefe
STACK_COMMAND: .thread 0xffffffff87179c78 ; kb
FOLLOWUP_IP:
dxgkrnl+15e28
8ed21e28 ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: dxgkrnl+15e28
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: dxgkrnl.sys
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
________________
Edition: Ultimate
Architecture: X86
LCID: 1031
*** work. ***
BUGCHECK_STR: 0xEA
CURRENT_IRQL: 0
STACK_TEXT:
FOLLOWUP_IP:
dxgkrnl+15e28
8ed21e28 ?? ???
