Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\symbols*
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6002.18005.x86fre.lh_sp2rtm.090410-1830
Machine Name:
Kernel base = 0x81e47000 PsLoadedModuleList = 0x81f5ec70
Debug session time: Sat Sep 5 13:48:37.353 2009 (GMT-7)
System Uptime: 0 days 0:00:33.947
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 7ffdb00c). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {99820464, 0, 81e8c560, 2}
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Page 57f7e not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : nvlddmkm.sys ( nvlddmkm+874e4 )
Followup: MachineOwner
1: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: 99820464, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: 81e8c560, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000002, (reserved)
Debugging Details:
READ_ADDRESS: 99820464
FAULTING_IP:
nt!READ_REGISTER_ULONG+4
81e8c560 8b02 mov eax,dword ptr [edx]
MM_INTERNAL_CODE: 2
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: csrss.exe
CURRENT_IRQL: 0
TRAP_FRAME: 8d65598c -- (.trap 0xffffffff8d65598c)
ErrCode = 00000000
eax=00408119 ebx=00020000 ecx=98800000 edx=99820464 esi=99820464 edi=01000460
eip=81e8c560 esp=8d655a00 ebp=901fd798 iopl=0 nv up ei pl nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010202
nt!READ_REGISTER_ULONG+0x4:
81e8c560 8b02 mov eax,dword ptr [edx] ds:0023:99820464=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from 81e94db4 to 81edf36d
STACK_TEXT:
8d655974 81e94db4 00000000 99820464 00000000 nt!MmAccessFault+0x10a
8d655974 81e8c560 00000000 99820464 00000000 nt!KiTrap0E+0xdc
8d6559fc 8b68e4e4 99820464 9055d878 8b754e97 nt!READ_REGISTER_ULONG+0x4
WARNING: Stack unwind information not available. Following frames may be wrong.
8d655a08 8b754e97 85eb07d8 901fd798 01020464 nvlddmkm+0x874e4
8d655a18 8b708641 901fd798 9055d878 00000000 nvlddmkm+0x14de97
8d655a3c 8b708bdc 00001400 00000460 0000000b nvlddmkm+0x101641
8d655a64 8b72cd0a 00000000 8d655a94 901fd798 nvlddmkm+0x101bdc
8d655a94 8b6af768 901fd798 901fd798 8b68e4e4 nvlddmkm+0x125d0a
8d655aa0 8b68e4e4 9882000c 901fd798 8b754e97 nvlddmkm+0xa8768
8d655aac 8b754e97 85eb07d8 901fd798 0002000c nvlddmkm+0x874e4
8d655abc 8b754f27 901fd798 9055d878 00000000 nvlddmkm+0x14de97
8d655ae0 8b7188b9 901fd798 80c06b60 00000002 nvlddmkm+0x14df27
8d655b00 8b6b017f 80c06b60 905613d8 00000002 nvlddmkm+0x1118b9
8d655b10 8b6b1adb 80c23ac8 85eb0ac8 85eb07d8 nvlddmkm+0xa917f
8d655b28 8b68df0c 901fd798 00000000 85edd000 nvlddmkm+0xaaadb
00000000 00000000 00000000 00000000 00000000 nvlddmkm+0x86f0c
STACK_COMMAND: kb
FOLLOWUP_IP:
nvlddmkm+874e4
8b68e4e4 5e pop esi
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nvlddmkm+874e4
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 45b147f7
FAILURE_BUCKET_ID: 0x50_nvlddmkm+874e4
