simpel1970
Fleet Admiral
- Apr. 2009
Dann sage ich ebenfalls vorsichtig und optimistisch: Bitteschön
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\112111-44803-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`03049000 PsLoadedModuleList = 0xfffff800`0328e670
Debug session time: Mon Nov 21 16:22:43.113 2011 (GMT+1)
System Uptime: 0 days 2:50:36.097
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff88006385507, fffff880082c5c30, 0}
Probably caused by : dxgmms1.sys ( dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+17f )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88006385507, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff880082c5c30, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
fffff880`06385507 488908 mov qword ptr [rax],rcx
CONTEXT: fffff880082c5c30 -- (.cxr 0xfffff880082c5c30)
rax=fffdf8a017cd0548 rbx=fffffa800b6e2d80 rcx=fffff8a017cd0548
rdx=fffffa80084ac000 rsi=fffff8a017db9610 rdi=fffffa8009156000
rip=fffff88006385507 rsp=fffff880082c6610 rbp=0000000000000001
r8=fffffa80091573c0 r9=0000000000000001 r10=0000000000000018
r11=fffff880082c65e0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=fffff8a0126ca140
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010286
dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+0x17f:
fffff880`06385507 488908 mov qword ptr [rax],rcx ds:002b:fffdf8a0`17cd0548=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: SC2.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff88006385507
STACK_TEXT:
fffff880`082c6610 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+0x17f
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+17f
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME: dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce799c1
STACK_COMMAND: .cxr 0xfffff880082c5c30 ; kb
FAILURE_BUCKET_ID: X64_0x3B_dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+17f
0: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
BUGCHECK_STR: 0x3B
CURRENT_IRQL: 0
STACK_TEXT:
FOLLOWUP_IP:
Heißt das ich soll nen Riegel rausnehmen, auch wenn es fehlerfrei läuft?simple1970 schrieb:unabhängig davon überprüfe die ram mit memtest86+ auf fehler. Sollten keine fehler gefunden werden (prüfung mind. 3-4 std. Laufen lassen), baue einen ram riegel aus, so dass das board mit der "normalen" ram bestückung läuft (tripple-channel -> drei riegel). Läuft das system dann fehlerfrei?
Leider nein, dennoch fingen die Probleme erst nach der Instalaltion von Skyrim richtig an.simple1970 schrieb:Wenn das Problem erst seit Kurzem auftritt...Hast du irgendwelche Änderungen vorgenommen, die das Problem erklären würden?
Nein, auch das nicht. Jedenfalls nichts was er bei anderen Bluescreens nicht auch getan hat, d.h. das Bild wird verzerrt und ist dann zu 25% blau und 25% weiß. Das war aber bis jetzt bei jedem Bluescreen so (anderer Bluescreen heißt, dass es nicht durch dxgmms1.sys ausgelöst wurde).simple1970 schrieb:Treten bei den Abstürzen Bildfehler (z.B. rote Punkte oder Streifen) auf?
Ich meinte das so, falls alles andere nichts mehr hilft.simple1970 schrieb:Nicht gleich neu kaufen
Loading Dump File [D:\112111-44803-01.dmp]
Machine Name:
0: kd> !analyze -v lm
Arguments:
Debugging Details:
FAULTING_IP:
BUGCHECK_STR: 0x3B
CURRENT_IRQL: 0
STACK_TEXT:
FOLLOWUP_IP:
Das hat viel kürzer gedauert als das Normalesimple1970 schrieb:Edit: Nimm dir bitte die Minidump noch mal mit dem Debugger vor und tippe nach dem "!analyze -v" noch ein "lm" (ohne "") ein. Poste dann erneut den Ausgabetext (dauert ne weile bis das fertig ist).
!analyze -v
Paralor schrieb:Heißt das ich soll nen Riegel rausnehmen, auch wenn es fehlerfrei läuft?
Paralor schrieb:Das hat viel kürzer gedauert als das Normale
Paralor schrieb:Das Problem ist bis jetzt nicht wieder aufgetaucht, aber nun freezt mein PC selten für 1-2sek und läuft danach aber problemlos weiter
Sollte nicht, es ging ja 2 Jahre problemlos.simple1970 schrieb:Wenn das System fehlerfrei läuft, brauchst du nichts ändern. Da aber Fehler auftreten, wäre es interessant zu wissen, ob evtl. das Board mit der "Überbelegung" Probleme hat.
Kann passieren.simple1970 schrieb:Weil ich Trottel auch die Häflte vergessen habe. Sorry, war wohl etwas geistesabwesend. Ich meinte den Befehl "lmtsm" um die geladenen Treiber (incl. Versionsdatum) sehen zu können.
Systemplatte ist eine Western Digital(nummer weiß ich nicht auswendig, das muss ich mal schauen) mit 1TB Speicher. Nein, es ist keine SSD. Und letzteres: Nein, ist nicht installiert. Es kam mal ne Meldung dass ich es entweder nicht installiert habe, oder dass keine Kopatibilität zwischen IRS und irgendetwas Anderem herzustellen sei.simple1970 schrieb:Was für eine Systemplatte ist installiert? Sofern eine SSD...Firmware aktuell?
Ist der Intel Rapid Storage installiert?
Hab mich geirrt. Es handelte sich um den JMB36X Raid Configurator, sorry.Paralor schrieb:keine Kopatibilität zwischen IRS und irgendetwas Anderem herzustellen sei.
Machine Name:
0: kd> !analyze -v lmtsm
Arguments:
Debugging Details:
FAULTING_IP:
BUGCHECK_STR: 0x3B
CURRENT_IRQL: 0
STACK_TEXT:
FOLLOWUP_IP:
0: kd> lmtsm
start end module name
fffff880`08d55000 fffff880`08d80000 000 Fri Sep 26 15:11:22 2008 (48DCDF7A)
fffff880`04a00000 fffff880`04a3e000 1394ohci Sat Nov 20 11:44:56 2010 (4CE7A6A8)
fffff880`04a8c000 fffff880`04ad9000 a0m89mks Mon Mar 28 17:41:57 2011 (4D90AC45)
fffff880`0116e000 fffff880`011c5000 ACPI Sat Nov 20 10:19:16 2010 (4CE79294)
fffff880`06a65000 fffff880`06ade000 ADIHdAud Thu Sep 17 05:04:09 2009 (4AB1A729)
fffff880`01272000 fffff880`012fb000 afd Mon Apr 25 04:33:58 2011 (4DB4DD96)
fffff880`052a7000 fffff880`052bd000 AgileVpn Tue Jul 14 02:10:24 2009 (4A5BCCF0)
fffff880`00ddc000 fffff880`00de7000 amdxata Fri Mar 19 17:18:18 2010 (4BA3A3CA)
fffff880`04a5c000 fffff880`04a7f000 AnyDVD Wed Dec 01 20:06:20 2010 (4CF69CAC)
fffff880`05800000 fffff880`05808000 ASACPI Thu May 14 03:25:17 2009 (4A0B72FD)
fffff880`0424d000 fffff880`04253000 AsIO Mon Apr 06 09:21:08 2009 (49D9AD64)
fffff880`06bf0000 fffff880`06bf9000 aswFsBlk Tue May 10 13:59:36 2011 (4DC928A8)
fffff880`06bb6000 fffff880`06bf0000 aswMonFlt Tue May 10 13:59:47 2011 (4DC928B3)
fffff880`04578000 fffff880`04582000 aswRdr Tue May 10 13:59:58 2011 (4DC928BE)
fffff880`04417000 fffff880`044af000 aswSnx Tue May 10 14:04:06 2011 (4DC929B6)
fffff880`04200000 fffff880`0424d000 aswSP Tue May 10 14:04:06 2011 (4DC929B6)
fffff880`04568000 fffff880`04578000 aswTdi Tue May 10 14:02:40 2011 (4DC92960)
fffff880`0a1d8000 fffff880`0a1e3000 asyncmac Tue Jul 14 02:10:13 2009 (4A5BCCE5)
fffff880`00c3c000 fffff880`00c45000 atapi Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`00c45000 fffff880`00c6f000 ataport Sat Nov 20 10:19:15 2010 (4CE79293)
fffff880`06a27000 fffff880`06a65000 AtihdW76 Tue Jun 07 12:34:39 2011 (4DEDFEBF)
fffff880`05820000 fffff880`06276000 atikmdag Wed Oct 26 03:59:06 2011 (4EA7696A)
fffff880`04aec000 fffff880`04b41000 atikmpag Wed Oct 26 03:21:58 2011 (4EA760B6)
fffff960`008d0000 fffff960`00931000 ATMFD Sat Feb 19 10:00:32 2011 (4D5F86B0)
fffff880`044b8000 fffff880`044bf000 Beep Tue Jul 14 02:00:13 2009 (4A5BCA8D)
fffff880`043cd000 fffff880`043de000 blbdrive Tue Jul 14 01:35:59 2009 (4A5BC4DF)
fffff880`07560000 fffff880`0757e000 bowser Wed Feb 23 05:55:04 2011 (4D649328)
fffff960`00680000 fffff960`006a7000 cdd Sat Nov 20 13:55:34 2010 (4CE7C546)
fffff880`018b6000 fffff880`018e0000 cdrom Sat Nov 20 10:19:20 2010 (4CE79298)
fffff880`00e40000 fffff880`00f00000 CI Sat Nov 20 14:12:36 2010 (4CE7C944)
fffff880`01850000 fffff880`01880000 CLASSPNP Sat Nov 20 10:19:23 2010 (4CE7929B)
fffff880`00d22000 fffff880`00d80000 CLFS Tue Jul 14 01:19:57 2009 (4A5BC11D)
fffff880`01200000 fffff880`01272000 cng Sat Nov 20 11:08:45 2010 (4CE79E2D)
fffff880`04ad9000 fffff880`04ae9000 CompositeBus Sat Nov 20 11:33:17 2010 (4CE7A3ED)
fffff880`06af8000 fffff880`06b06000 crashdmp Tue Jul 14 02:01:01 2009 (4A5BCABD)
fffff880`0432c000 fffff880`043af000 csc Sat Nov 20 10:27:12 2010 (4CE79470)
fffff880`043af000 fffff880`043cd000 dfsc Sat Nov 20 10:26:31 2010 (4CE79447)
fffff880`0431d000 fffff880`0432c000 discache Tue Jul 14 01:37:18 2009 (4A5BC52E)
fffff880`0183a000 fffff880`01850000 disk Tue Jul 14 01:19:57 2009 (4A5BC11D)
fffff880`043de000 fffff880`04400000 drmk Tue Jul 14 03:01:25 2009 (4A5BD8E5)
fffff880`06b12000 fffff880`06b1b000 dump_atapi Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`06b06000 fffff880`06b12000 dump_dumpata Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`06b1b000 fffff880`06b2e000 dump_dumpfve Tue Jul 14 01:21:51 2009 (4A5BC18F)
fffff880`06aec000 fffff880`06af8000 Dxapi Tue Jul 14 01:38:28 2009 (4A5BC574)
fffff880`06276000 fffff880`0636a000 dxgkrnl Sat Nov 20 10:50:50 2010 (4CE799FA)
fffff880`0636a000 fffff880`063b0000 dxgmms1 Sat Nov 20 10:49:53 2010 (4CE799C1)
fffff880`04311000 fffff880`0431d000 ElbyCDIO Thu Dec 16 23:58:13 2010 (4D0A9985)
fffff880`017c6000 fffff880`017fc000 fastfat Tue Jul 14 01:23:28 2009 (4A5BC1F0)
fffff880`063f2000 fffff880`063ff000 fdc Tue Jul 14 02:00:54 2009 (4A5BCAB6)
fffff880`01349000 fffff880`0135d000 fileinfo Tue Jul 14 01:34:25 2009 (4A5BC481)
fffff880`053d1000 fffff880`053dc000 flpydisk Tue Jul 14 02:00:54 2009 (4A5BCAB6)
fffff880`012fd000 fffff880`01349000 fltmgr Sat Nov 20 10:19:24 2010 (4CE7929C)
fffff880`01411000 fffff880`0141b000 Fs_Rec Tue Jul 14 01:19:45 2009 (4A5BC111)
fffff880`01800000 fffff880`0183a000 fvevol Sat Nov 20 10:24:06 2010 (4CE793B6)
fffff880`01ae8000 fffff880`01b32000 fwpkclnt Sat Nov 20 10:21:37 2010 (4CE79321)
fffff880`04a7f000 fffff880`04a8c000 GEARAspiWDM Mon May 18 14:17:04 2009 (4A1151C0)
fffff800`03000000 fffff800`03049000 hal Sat Nov 20 14:00:25 2010 (4CE7C669)
fffff880`0538b000 fffff880`05396000 hamachi Thu Feb 19 11:36:41 2009 (499D3639)
fffff880`063b0000 fffff880`063d4000 HDAudBus Sat Nov 20 11:43:42 2010 (4CE7A65E)
fffff880`0a00e000 fffff880`0a027000 HIDCLASS Sat Nov 20 11:43:49 2010 (4CE7A665)
fffff880`0a027000 fffff880`0a02f080 HIDPARSE Tue Jul 14 02:06:17 2009 (4A5BCBF9)
fffff880`0a000000 fffff880`0a00e000 hidusb Sat Nov 20 11:43:49 2010 (4CE7A665)
fffff880`052bd000 fffff880`052d6000 HssDrv Thu Sep 02 19:46:48 2010 (4C7FE308)
fffff880`07497000 fffff880`07560000 HTTP Sat Nov 20 10:24:30 2010 (4CE793CE)
fffff880`01be2000 fffff880`01beb000 hwpolicy Sat Nov 20 10:18:54 2010 (4CE7927E)
fffff880`04a3e000 fffff880`04a5c000 i8042prt Tue Jul 14 01:19:57 2009 (4A5BC11D)
fffff880`04279000 fffff880`0428f000 intelppm Tue Jul 14 01:19:25 2009 (4A5BC0FD)
fffff880`00c6f000 fffff880`00c8c000 jraid Fri Jun 26 09:13:37 2009 (4A447521)
fffff880`053ae000 fffff880`053bd000 kbdclass Tue Jul 14 01:19:50 2009 (4A5BC116)
fffff880`0a046000 fffff880`0a054000 kbdhid Sat Nov 20 11:33:25 2010 (4CE7A3F5)
fffff800`00b9a000 fffff800`00ba4000 kdcom Sat Feb 05 17:52:49 2011 (4D4D8061)
fffff880`0525e000 fffff880`052a1000 ks Sat Nov 20 11:33:23 2010 (4CE7A3F3)
fffff880`015df000 fffff880`015fa000 ksecdd Sat Nov 20 10:21:15 2010 (4CE7930B)
fffff880`01780000 fffff880`017ab000 ksecpkg Sat Nov 20 11:10:34 2010 (4CE79E9A)
fffff880`052a1000 fffff880`052a6200 ksthunk Tue Jul 14 02:00:19 2009 (4A5BCA93)
fffff880`0a030000 fffff880`0a046000 LHidFilt Sat Apr 30 13:51:39 2011 (4DBBF7CB)
fffff880`01880000 fffff880`01895000 lltdio Tue Jul 14 02:08:50 2009 (4A5BCC92)
fffff880`0a061000 fffff880`0a075000 LMouFilt Sat Apr 30 13:51:45 2011 (4DBBF7D1)
fffff880`06b93000 fffff880`06bb6000 luafv Tue Jul 14 01:26:13 2009 (4A5BC295)
fffff880`06ade000 fffff880`06aec000 MCfilt64 Fri Jul 31 05:40:32 2009 (4A7267B0)
fffff880`00cbf000 fffff880`00d0e000 mcupdate_GenuineIntel Sat Nov 20 14:03:51 2010 (4CE7C737)
fffff880`06b85000 fffff880`06b93000 monitor Tue Jul 14 01:38:52 2009 (4A5BC58C)
fffff880`05808000 fffff880`05817000 mouclass Tue Jul 14 01:19:50 2009 (4A5BC116)
fffff880`0a054000 fffff880`0a061000 mouhid Tue Jul 14 02:00:20 2009 (4A5BCA94)
fffff880`00e10000 fffff880`00e2a000 mountmgr Sat Nov 20 10:19:21 2010 (4CE79299)
fffff880`0757e000 fffff880`07596000 mpsdrv Tue Jul 14 02:08:25 2009 (4A5BCC79)
fffff880`07596000 fffff880`075c3000 mrxsmb Wed Apr 27 04:40:38 2011 (4DB78226)
fffff880`07400000 fffff880`0744e000 mrxsmb10 Sat Jul 09 04:46:28 2011 (4E17C104)
fffff880`0744e000 fffff880`07472000 mrxsmb20 Wed Apr 27 04:39:37 2011 (4DB781E9)
fffff880`0451d000 fffff880`04528000 Msfs Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`011ce000 fffff880`011d8000 msisadrv Tue Jul 14 01:19:26 2009 (4A5BC0FE)
fffff880`0135d000 fffff880`013bb000 msrpc Sat Nov 20 10:21:56 2010 (4CE79334)
fffff880`04306000 fffff880`04311000 mssmbios Tue Jul 14 01:31:10 2009 (4A5BC3BE)
fffff880`01bd0000 fffff880`01be2000 mup Tue Jul 14 01:23:45 2009 (4A5BC201)
fffff880`0162d000 fffff880`01720000 ndis Sat Nov 20 10:23:30 2010 (4CE79392)
fffff880`052fa000 fffff880`05306000 ndistapi Tue Jul 14 02:10:00 2009 (4A5BCCD8)
fffff880`05306000 fffff880`05335000 ndiswan Sat Nov 20 11:52:32 2010 (4CE7A870)
fffff880`053dc000 fffff880`053f1000 NDProxy Sat Nov 20 11:52:20 2010 (4CE7A864)
fffff880`04400000 fffff880`0440f000 netbios Tue Jul 14 02:09:26 2009 (4A5BCCB6)
fffff880`04582000 fffff880`045c7000 netbt Sat Nov 20 10:23:18 2010 (4CE79386)
fffff880`01720000 fffff880`01780000 NETIO Sat Nov 20 10:23:13 2010 (4CE79381)
fffff880`04528000 fffff880`04539000 Npfs Tue Jul 14 01:19:48 2009 (4A5BC114)
fffff880`042fa000 fffff880`04306000 nsiproxy Tue Jul 14 01:21:02 2009 (4A5BC15E)
fffff800`03049000 fffff800`03632000 nt Thu Jun 23 04:53:23 2011 (4E02AAA3)
fffff880`0143c000 fffff880`015df000 Ntfs Fri Mar 11 04:39:39 2011 (4D79997B)
fffff880`044af000 fffff880`044b8000 Null Tue Jul 14 01:19:37 2009 (4A5BC109)
fffff880`045d0000 fffff880`045f6000 pacer Sat Nov 20 11:52:18 2010 (4CE7A862)
fffff880`011e5000 fffff880`011fa000 partmgr Sat Nov 20 10:20:00 2010 (4CE792C0)
fffff880`00fb3000 fffff880`00fe6000 pci Sat Nov 20 10:19:11 2010 (4CE7928F)
fffff880`01000000 fffff880`01007000 pciide Tue Jul 14 01:19:49 2009 (4A5BC115)
fffff880`00e00000 fffff880`00e10000 PCIIDEX Tue Jul 14 01:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`01411000 pcw Tue Jul 14 01:19:27 2009 (4A5BC0FF)
fffff880`08c61000 fffff880`08d07000 peauth Tue Jul 14 03:01:19 2009 (4A5BD8DF)
fffff880`013bb000 fffff880`013f8000 portcls Tue Jul 14 02:06:27 2009 (4A5BCC03)
fffff880`00d0e000 fffff880`00d22000 PSHED Tue Jul 14 03:32:23 2009 (4A5BE027)
fffff880`052d6000 fffff880`052fa000 rasl2tp Sat Nov 20 11:52:34 2010 (4CE7A872)
fffff880`05335000 fffff880`05350000 raspppoe Tue Jul 14 02:10:17 2009 (4A5BCCE9)
fffff880`05350000 fffff880`05371000 raspptp Sat Nov 20 11:52:31 2010 (4CE7A86F)
fffff880`05371000 fffff880`0538b000 rassstp Tue Jul 14 02:10:25 2009 (4A5BCCF1)
fffff880`042a9000 fffff880`042fa000 rdbss Sat Nov 20 10:27:51 2010 (4CE79497)
fffff880`053a3000 fffff880`053ae000 rdpbus Tue Jul 14 02:17:46 2009 (4A5BCEAA)
fffff880`04502000 fffff880`0450b000 RDPCDD Tue Jul 14 02:16:34 2009 (4A5BCE62)
fffff880`0450b000 fffff880`04514000 rdpencdd Tue Jul 14 02:16:34 2009 (4A5BCE62)
fffff880`04514000 fffff880`0451d000 rdprefmp Tue Jul 14 02:16:35 2009 (4A5BCE63)
fffff880`01b96000 fffff880`01bd0000 rdyboost Sat Nov 20 10:43:10 2010 (4CE7982E)
fffff880`01895000 fffff880`018ad000 rspndr Tue Jul 14 02:08:50 2009 (4A5BCC92)
fffff880`0428f000 fffff880`0429d000 ScreamingBAudio64 Thu Jul 01 20:54:32 2010 (4C2CE468)
fffff880`00c8c000 fffff880`00cbb000 SCSIPORT Sat Nov 20 11:34:01 2010 (4CE7A419)
fffff880`08d07000 fffff880`08d12000 secdrv Wed Sep 13 15:18:38 2006 (4508052E)
fffff880`01b8e000 fffff880`01b96000 spldr Mon May 11 18:56:27 2009 (4A0858BB)
fffff880`01008000 fffff880`0116e000 sptd Sun Feb 27 20:29:52 2011 (4D6AA630)
fffff880`0a09e000 fffff880`0a136000 srv Fri Apr 29 05:06:06 2011 (4DBA2B1E)
fffff880`08d80000 fffff880`08de9000 srv2 Fri Apr 29 05:05:46 2011 (4DBA2B0A)
fffff880`08d12000 fffff880`08d43000 srvnet Fri Apr 29 05:05:35 2011 (4DBA2AFF)
fffff880`053bd000 fffff880`053be480 swenum Tue Jul 14 02:00:18 2009 (4A5BCA92)
fffff880`05396000 fffff880`053a3000 taphss Tue Sep 15 21:58:23 2009 (4AAFF1DF)
fffff880`018e4000 fffff880`01ae8000 tcpip Thu Sep 29 05:43:04 2011 (4E83E948)
fffff880`08d43000 fffff880`08d55000 tcpipreg Sat Nov 20 11:51:48 2010 (4CE7A844)
fffff880`0455b000 fffff880`04568000 TDI Sat Nov 20 10:22:06 2010 (4CE7933E)
fffff880`04539000 fffff880`0455b000 tdx Sat Nov 20 10:21:54 2010 (4CE79332)
fffff880`01beb000 fffff880`01bff000 termdd Sat Nov 20 12:03:40 2010 (4CE7AB0C)
fffff960`005e0000 fffff960`005ea000 TSDDD unavailable (00000000)
fffff880`04253000 fffff880`04279000 tunnel Sat Nov 20 11:51:50 2010 (4CE7A846)
fffff880`053bf000 fffff880`053d1000 umbus Sat Nov 20 11:44:37 2010 (4CE7A695)
fffff880`0a1e3000 fffff880`0a1fdc80 usbaudio Sat Nov 20 11:43:52 2010 (4CE7A668)
fffff880`06b2e000 fffff880`06b4b000 usbccgp Fri Mar 25 04:29:14 2011 (4D8C0C0A)
fffff880`06b4b000 fffff880`06b4cf00 USBD Fri Mar 25 04:28:59 2011 (4D8C0BFB)
fffff880`063e1000 fffff880`063f2000 usbehci Fri Mar 25 04:29:04 2011 (4D8C0C00)
fffff880`05200000 fffff880`0525a000 usbhub Fri Mar 25 04:29:25 2011 (4D8C0C15)
fffff880`04b41000 fffff880`04b97000 USBPORT Fri Mar 25 04:29:12 2011 (4D8C0C08)
fffff880`06b5e000 fffff880`06b6a000 usbprint Tue Jul 14 02:38:18 2009 (4A5BD37A)
fffff880`06b4d000 fffff880`06b5e000 usbscan Tue Jul 14 02:35:32 2009 (4A5BD2D4)
fffff880`06b6a000 fffff880`06b85000 USBSTOR Fri Mar 11 05:37:16 2011 (4D79A6FC)
fffff880`063d4000 fffff880`063e1000 usbuhci Fri Mar 25 04:29:03 2011 (4D8C0BFF)
fffff880`011d8000 fffff880`011e5000 vdrvroot Tue Jul 14 02:01:31 2009 (4A5BCADB)
fffff880`044bf000 fffff880`044cd000 vga Tue Jul 14 01:38:47 2009 (4A5BC587)
fffff880`044cd000 fffff880`044f2000 VIDEOPRT Tue Jul 14 01:38:51 2009 (4A5BC58B)
fffff880`00c00000 fffff880`00c3c000 vmbus Sat Nov 20 10:57:29 2010 (4CE79B89)
fffff880`01b32000 fffff880`01b42000 vmstorfl Sat Nov 20 10:57:30 2010 (4CE79B8A)
fffff880`00fe6000 fffff880`00ffb000 volmgr Sat Nov 20 10:19:28 2010 (4CE792A0)
fffff880`00d80000 fffff880`00ddc000 volmgrx Sat Nov 20 10:20:43 2010 (4CE792EB)
fffff880`01b42000 fffff880`01b8e000 volsnap Sat Nov 20 10:20:08 2010 (4CE792C8)
fffff880`017ab000 fffff880`017c6000 wanarp Sat Nov 20 11:52:36 2010 (4CE7A874)
fffff880`044f2000 fffff880`04502000 watchdog Tue Jul 14 01:37:35 2009 (4A5BC53F)
fffff880`00f00000 fffff880`00fa4000 Wdf01000 Tue Jul 14 01:22:07 2009 (4A5BC19F)
fffff880`00fa4000 fffff880`00fb3000 WDFLDR Tue Jul 14 01:19:54 2009 (4A5BC11A)
fffff880`045c7000 fffff880`045d0000 wfplwf Tue Jul 14 02:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f4000 win32k Thu Sep 29 06:03:02 2011 (4E83EDF6)
fffff880`00e2a000 fffff880`00e3e000 winhv Sat Nov 20 10:20:02 2010 (4CE792C2)
fffff880`05817000 fffff880`05820000 wmiacpi Tue Jul 14 01:31:02 2009 (4A5BC3B6)
fffff880`011c5000 fffff880`011ce000 WMILIB Tue Jul 14 01:19:51 2009 (4A5BC117)
fffff880`06a00000 fffff880`06a21000 WudfPf Sat Nov 20 11:42:44 2010 (4CE7A624)
fffff880`0a136000 fffff880`0a167000 WUDFRd Sat Nov 20 11:43:32 2010 (4CE7A654)
fffff880`04b97000 fffff880`04bfc000 yk62x64 Mon Sep 28 10:19:31 2009 (4AC07193)
Unloaded modules:
fffff880`0a167000 fffff880`0a1d8000 spsys.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
fffff880`01880000 fffff880`0188e000 crashdmp.sys
Checksum: 00000000
fffff880`0188e000 fffff880`0189a000 dump_ataport
Checksum: 00000000
fffff880`0189a000 fffff880`018a3000 dump_atapi.s
Checksum: 00000000
fffff880`018a3000 fffff880`018b6000 dump_dumpfve
Checksum: 00000000
Weiß ich auswendig nicht, folgt im Nachtrag.simple1970 schrieb:An welchem Controller ist deine Systemplatte angeschossen? An einem der blauen Intel- oder dem schwarzen JMicron Port? Und wie sind die beiden Controller im Bios eingestellt (AHCI oder IDE)?
Das müsste ein Treiber von einem Cyberlink Produkt sein. Kann das sein?fffff880`08d55000 fffff880`08d80000 000 Fri Sep 26 15:11:22 2008
Macrovision Security Treiber (SafeDisk Kopierschutz)-> Windows Updates sind alle installiert?fffff880`08d07000 fffff880`08d12000 secdrv Wed Sep 13 15:18:38 2006
Ja, das ist mein nicht funktionierender BlueRay-Player.simple1970 schrieb:Das müsste ein Treiber von einem Cyberlink Produkt sein. Kann das sein?
Sagt mir so nichts, aber Windows Updates hab ich immer installiert.simple1970 schrieb:Macrovision Security Treiber (SafeDisk Kopierschutz)-> Windows Updates sind alle installiert?
Ja das muss ich noch machen, bin nur zu faul meinen PC aufzumachensimple1970 schrieb:Schau bitte auch noch nach, an welchen Ports die Festplatte hängt.
Soll ich das immernoch machen? Mein PC läuft nach der Formatierung wieder 1A.simple1970 schrieb:Und teste ohne RAM Überbelegung.
Das lässt sich nicht installieren, weil:Inzersdorfer schrieb:Zum RST:"Das Softwarepaket enthält AHCI-/SATA- und RAID-Treiber für die unterstützten Betriebssysteme."
https://www.computerbase.de/downloads/treiber/mainboards/intel-rapid-storage-technologie/
Dieses System erfüllt nicht die Mindestanforderung für die Installation der Software.
