Himmelsrand
- Nov. 2011
ich habe mir einige Themen zu Minidump gelesen und bin soweit, dass ich es öffnen kann. Nur weiß ich einfach nicht weiter. Kann einer mir vllt. helfen?
Hier der Auszug:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\111411-27175-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`02c17000 PsLoadedModuleList = 0xfffff800`02e5c670
Debug session time: Mon Nov 14 09:49:25.926 2011 (UTC + 1:00)
System Uptime: 0 days 0:16:52.441
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 24, {1904fb, fffff88008f37c78, fffff88008f374d0, fffff880012fa527}
Probably caused by : Ntfs.sys ( Ntfs!NtfsFindPrefixHashEntry+1fe )
Followup: MachineOwner
1: kd> !analyze -v
NTFS_FILE_SYSTEM (24)
If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
parameters are the exception record and context record. Do a .cxr
on the 3rd parameter and then kb to obtain a more informative stack
trace.
Arguments:
Arg1: 00000000001904fb
Arg2: fffff88008f37c78
Arg3: fffff88008f374d0
Arg4: fffff880012fa527
Debugging Details:
EXCEPTION_RECORD: fffff88008f37c78 -- (.exr 0xfffff88008f37c78)
ExceptionAddress: fffff880012fa527 (Ntfs!NtfsFindPrefixHashEntry+0x00000000000001fe)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: fffff88008f374d0 -- (.cxr 0xfffff88008f374d0)
rax=fffff8a0048d3000 rbx=3f3b90fa3f800000 rcx=0000000000000044
rdx=0000000000000002 rsi=fffff8a000284bc0 rdi=fffffa8004acc350
rip=fffff880012fa527 rsp=fffff88008f37eb0 rbp=0000000000000002
r8=000000002ede1422 r9=0000000000000000 r10=0000000000000005
r11=fffff88008f37ef8 r12=fffff88008f381b0 r13=fffff88008f38460
r14=0000000000000022 r15=0000000000001422
iopl=0 nv up ei pl nz na pe nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010202
Ntfs!NtfsFindPrefixHashEntry+0x1fe:
fffff880`012fa527 44394310 cmp dword ptr [rbx+10h],r8d ds:002b:3f3b90fa`3f800010=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: rundll32.exe
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002ec6100
ffffffffffffffff
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR: 0x24
LAST_CONTROL_TRANSFER: from fffff880012f8fd2 to fffff880012fa527
STACK_TEXT:
fffff880`08f37eb0 fffff880`012f8fd2 : fffffa80`0441f010 fffffa80`04acc350 fffff8a0`00284bc0 00000000`00000001 : Ntfs!NtfsFindPrefixHashEntry+0x1fe
fffff880`08f37fe0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : Ntfs!NtfsFindStartingNode+0x452
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: Ntfs!NtfsFindPrefixHashEntry+1fe
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Ntfs
IMAGE_NAME: Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4d79997b
STACK_COMMAND: .cxr 0xfffff88008f374d0 ; kb
FAILURE_BUCKET_ID: X64_0x24_Ntfs!NtfsFindPrefixHashEntry+1fe
Hier der Auszug:
Machine Name:
1: kd> !analyze -v
trace.
Arguments:
Debugging Details:
NumberParameters: 2
CURRENT_IRQL: 0
ffffffffffffffff
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR: 0x24
STACK_TEXT:
MODULE_NAME: Ntfs
