@ rIQ hier die config mit der ich nur max 20kb/s hab
# General settings:
HOSTNAME='fli4l' #name of fli4l router
PASSWORD='1' #password for telnetd, ftpd and sshd
MOUNT_BOOT='rw' #mount boot device (floppy): ro, rw, no
RAMSIZE='2048' #size of ramdisk for unzipped opt.tgz
# the variables MOUNT_OPT, PART_OPT and UPDATE_MODE will be ignored if
# RAMSIZE is not empty. see docu
MOUNT_OPT='ro' #mount opt device: ro, rw
PART_OPT='hda2' #location of opt-files? ram1 or disk-partition
UPDATE_MODE='full' #add, cfg, full, none, see documentation
# Ethernet card drivers:
# uncomment your ethernet card
ETH_DRV_N='2' #number of ethernet drivers to load, usually 1
ETH_DRV_1='3c59x' # PCI: 3COM Vortex/Boomerang 3c59x,3c900,3c905
ETH_DRV_1='sis900' #ISA: NE2000 ISA clone (eg. Realtek 8019,
ETH_DRV_1_OPTION=''
ETH_DRV_2_OPTION=''
# Ether networks used with IP protocol:
IP_ETH_N='1' #number of ip ethernet networks, usually 1
IP_ETH_1_NAME='' #optional: other device name than ethX
IP_ETH_1_IPADDR='192.168.0.1' #IP address of your nth ethernet card
IP_ETH_1_NETWORK='192.168.0.0' #network of your LAN
IP_ETH_1_NETMASK='255.255.255.0' #netmask of your LAN
# Additional routes, optional
IP_DEFAULT_GATEWAY='' #normally not used, read documentation!
IP_ROUTE_N='0' #number of additional routes
IP_ROUTE_1='192.168.7.0 255.255.255.0 192.168.6.99'# network netmask gateway
# Masquerading:
MASQ_NETWORK='192.168.0.0/24' #networks to masquerade (e.g. our LAN)
MASQ_MODULE_N='1' #load n masq modules (default: only ftp)
MASQ_MODULE_1='ftp' #ftp
MASQ_MODULE_2='h323' #h323 (netmeeting)
MASQ_MODULE_3='icq' #icq (use with caution!)
MASQ_MODULE_4='irc' #irc
MASQ_MODULE_5='raudio' #raudio
MASQ_MODULE_6='vdolive' #vdolive
MASQ_MODULE_7='quake' #quake
MASQ_MODULE_8='cuseeme' #cuseeme
MASQ_MODULE_9='mms' #MSN-Filetransfer
MASQ_MODULE_10='pptp' #pptp
MASQ_MODULE_11='ipsec' #ipsec
MASQ_MODULE_12='dplay' #dplay (direct play)
MASQ_MODULE_13='msn-0.02' #msn zone (use version 0.01 or 0.02)
MASQ_MODULE_14='udp_dloose' #pseudo mod: some internet games need it
MASQ_FTP_PORT_N='0' #using ftp masq-module on different ports
MASQ_FTP_PORT_1='21' #standard ftp port
MASQ_FTP_PORT_2='2021' #additional port
# Optional package: PORTFW
# If you set OPT_PORTFW='yes', you can also edit opt/etc/portfw.sh
OPT_PORTFW='yes' #install port forwarding tools/modules
PORTFW_N='0' #how many portforwardings to set up
PORTFW_1='8080 192.168.6.15:80 tcp' #sample 1: forward ext. port 8080 to int.
# host 192.168.6.15 to port 80 (use tcp)
PORTFW_2='3000-3010 192.168.6.15 tcp' #sample 2: forward portrange to int. host
# 192.168.5.15 (use tcp)
# Routing without masquerading
ROUTE_NETWORK='' #optional: route from/to network, no masq
# Routing: internal hosts to deny forwarding
FORWARD_DENY_HOST_N='0' #number of denied hosts
FORWARD_DENY_HOST_1='192.168.6.5' #optional: 1st denied host
FORWARD_DENY_HOST_2='192.168.6.6' #optional: 2nd denied host
# Routing: ports to reject/deny forwarding (from inside and outside!)
FORWARD_DENY_PORT_N='1' #no. of ports to reject/deny forwarding
FORWARD_DENY_PORT_1='137:139 REJECT' #deny/reject forwarding of netbios
FORWARD_TRUSTED_NETS='' #but allow forwarding between LANs
# Firewall: ports to reject/deny from outside (all served ports)
# here we leave two ports untouched:
# 53 dns
# 113 auth
FIREWALL_DENY_PORT_N='6' #no. of ports to reject/deny
FIREWALL_DENY_PORT_1='0:52 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_2='54:112 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_3='114:1023 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_4='5000:5001 REJECT' #imond/telmond ports: reject or deny
FIREWALL_DENY_PORT_5='8000 REJECT' #proxy access: reject or deny
FIREWALL_DENY_PORT_6='20012 REJECT' #vbox server access: reject or deny
FIREWALL_DENY_ICMP='no' #deny icmp (ping): yes or no
FIREWALL_LOG='yes' #log access to rejected/denied ports
# Domain configuration:
START_DNS='no' #start dns server: yes or no
DNS_FORWARDERS='192.76.144.66' #DNS servers of your provider, e.g. MSN
DNS_VERBOSE='no' #log queries in /usr/local/ens/ens.log
DOMAIN_NAME='Puff9' #your domain name
DNS_FORBIDDEN_N='0' #number of forbidden domains
DNS_FORBIDDEN_1='foo.bar' #1st forbidden domain
DNS_FORBIDDEN_2='bar.foo' #2nd forbidden domain
HOSTS_N='3' #number of hosts in your domain
HOST_1='192.168.0.1 fli4l' #1st host: ip and name
HOST_1='192.168.0.2 client2' #2st host: ip and name
HOST_1='192.168.0.3 client3' #3st host: ip and name
# Special DNS configuration
DNS_N='0' #number of special dns servers, normally 0
#DNS_1='firma.de 192.168.1.12' # 1st special dns server for firma.de
#DNS_2='lan.firma.de 192.168.2.12' # 2nd special dns server for lan.firma.de
# imond configuration:
START_IMOND='yes' #start imond: yes or no
IMOND_PORT='5000' #TCP-Port, see also FIREWALL_DENY_PORT_x!
IMOND_PASS='rofl' #imond-password, may be empty
IMOND_ADMIN_PASS='lol' #imond-admin-password, may be empty
IMOND_LED='' #tty for led: com1 - com4 or empty
IMOND_BEEP='no' #beep if connection going up/down
IMOND_LOG='no' #log /var/log/imond.log: yes or no
IMOND_LOGDIR='/var/log' #log-directory, e.g. /var/log
IMOND_ENABLE='yes' #accept "enable/disable" commands
IMOND_DIAL='yes' #accept "dial/hangup" commands
IMOND_ROUTE='yes' #accept "route" command
IMOND_REBOOT='yes' #accept "reboot" command
# Generic circuit configuration:
IP_DYN_ADDR='yes' #use dyn. ip addresses (most providers do)
DIALMODE='auto' #standard dialmode: auto, manual, or off
# optional package: syslogd
OPT_SYSLOGD='no' #start syslogd: yes or no
SYSLOGD_DEST_N='1' #number of destinations
SYSLOGD_DEST_1='*.* /dev/console' #nth prio & destination of syslog msgs
SYSLOGD_DEST_2='*.* @192.168.6.2' #example: loghost 192.168.6.2
SYSLOGD_DEST_3='kern.info /var/log/dial.log'# example: log infos
# optional package: klogd
OPT_KLOGD='no' #start klogd: yes or no
# optional package: y2k correction
OPT_Y2K='no' #y2k correction: yes or no
Y2K_DAYS='' #correct hardware Y2K-Bug: add x days
# Optional package: PNP
OPT_PNP='no' #install isapnp tools: yes or no
# Optional package: DHCP server
OPT_DHCP='yes' #install DHCP server: yes or no
DHCP_LS_TIME_DYN='3600' #default time for dynamic leases: 1 hour
DHCP_MAX_LS_TIME_DYN='7200' #max time for dynamic leases: 2 hours
DHCP_LS_TIME_FIX='86400' #default time for fix leases: 1 day
DHCP_MAX_LS_TIME_FIX='604800' #max time for fix leases: 1 week
DHCP_RANGE_1='192.168.6.2 192.168.6.100'#range of nth ethnet, see ETH_N !
DHCP_WINSSERVER_1='' #!)
DHCP_WINSSERVER_2='' #!)
# Optional package: DHCP client
OPT_DHCLIENT='no' #install DHCP client: yes or no
DHCLIENT_INTERFACES='eth1' #listen on interfaces, e.g. 2nd(!) NIC
DHCLIENT_USEPEERDNS='no' #use dns server of your provider: yes or no
# Optional package: DHCPCD ------- EXPERIMENTAL --------
OPT_DHCPCD='no' #install DHCPCD: yes or no
DHCPCD_INTERFACES='eth1' #listen on interfaces, e.g. 2nd(!) NIC
DHCPCD_USEPEERDNS='no' #use dns server of your provider: yes or no
@Morgoth die CPU auslastung ist immer minimal so zwischen 10% und 15% daran glaub ich liegts nicht.
mfg destru
