Rechner stürzt ab...
Faramir2003
Feb. 2005
ich habe ein Problem mit meinem Rechner. Und zwar stürzt der seit neuestem immer wenn ich lange ein Online Game gezockt habe ab und ich krieg nen Bluescreen. :pcangry:
Wenn ich dann die erstellte Datei mit dem Speicherabbild über WinDebug öffne bekomme ich folgendes angezeigt:
Microsoft (R) Windows Debugger Version 6.5.0003.7
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\MEMORY.DMP]
Kernel Complete Dump File: Full address space is available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
THIS DUMP FILE IS PARTIALLY CORRUPT.
KdDebuggerDataBlock is not present or unreadable.
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to read PsLoadedModuleList
KdDebuggerDataBlock not available!
KdDebuggerData.KernBase < SystemRangeStart
Windows XP Kernel Version 2600 UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x00000000 PsLoadedModuleList = 0x8055a420
Debug session time: Mon Nov 28 18:45:31.234 2005 (GMT+1)
System Uptime: 0 days 9:22:04.892
Loading Kernel Symbols
GetContextState failed, 0xD0000147
CS descriptor lookup failed
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {e48c0d24, 0, bfa8d558, 1}
***** Debugger could not find nt in module list, module list might be corrupt.
***** Followup with Debugger team
Probably caused by : Unknown_Image
Followup: MachineOwner
Kann mir jemand sagen, was das alles zu bedeuten hat??
Zur Info hier noch mein System:
AMD Athlon XP 2800+ (@ 2200 MHz = 3000+)
MSI GeForce 6600 GT (D.O.T. @ Captain = + 3%)
MSI K7N2 Delta2
2 x 512 MB Infineon DDR Dual Channel
420 Watt Netzteil
Vielen Dank schonmal...
MEM Test und prime95 getestet ?
2200 MHZ CPU ist ein 3200+ ! Bei 11x 200MHZ !
Versuch mal lieber die Multis auf normal und den FSB (eventuell Vcore etwas mehr) hoch (200MHZ).
(Deine Sig ist zu lang!)
Hallo Hyla...
Ich habe weder an den Multis noch an dem FSB was gedreht, da es sich bei meinem Board um ein MSI handelt und es automatisch overclocked mit der D.O.T., je nach Last...
Ich kann mir also net vorstellen das es damit was zu tun hat...
Andere vorschläge?
Was genau bedeuten denn die Angaben von WinDebug??
P.S.:
Warum ist mein Sig zu lang??
Na ja: 6 Zeilen Sig sind erlaubt.
Eigentlich hätte 1x gereicht: GetContextState failed, 0xD0000147
Nun zum Thema: hast Du denn prime und MEM Test mal durchgeführt?
Wissen ist besser als glauben.
Das das System automatisch per "Knopfdruck" übertaktet, heisst nicht, dass die Komponenten das auch mögen !
Unbedingt erstmal die Systemstabilität unter den Bedingungen testen.
