falsch, ist schon vorgestern released worden, hier der changelog:
FEATURE: added some more actions customizable by shortcut management for Download window [DonGato]
FEATURE: added downloading file rename and cleanup box customizable by shortcut management [netwolf]
FEATURE: expand/collapse sources by pressing +/- key [netwolf]
FEATURE: added a debug message for files before they start to be hashed [DonGato]
FEATURE: added keyboard DEL and INS actions to Friends list for easy operation [DonGato]
FEATURE: auto priority is now available for completed files using complete sources values [DonGato]
FEATURE: display own userhash in log at startup [SyruS]
FEATURE: added unique setting on Queue and Known lists to set the autoupdate option (high CPU usage) [DonGato]
FEATURE: Rich Edit Log, Serverinfo & Debug log (added color to the logs) [katsyonak]
FEATURE: added Keep-Alive option for server connections (from official) [DonGato]
FEATURE: Rich Edit IRC/Messages (added copy text to clipboard & save logs as RTF) [katsyonak]
CHANGE: statusbar is now erased when log or debuglog are erased [KuSh]
CHANGE: some code optimizations [Aw3/KuSh]
CHANGE: MD4 calculation optimization [Aw3]
CHANGE: caseinsensitive handling of community-sharing [SyruS]
CHANGE: added ed2k-link to .txtsrc files so in case of .part.met corruption you know what to search for [netwolf]
CHANGE: added Queue Full (QF) to sources information in tooltips [netwolf]
CHANGE: update the way Limitless download is enabled in preferences [DonGato]
CHANGE: new complete/completing icons [Psy]
BUGFIX: fixed string format buffer overflow with status command line argument [KuSh]
BUGFIX: category column sorting bug fix [KuSh]
BUGFIX: prevent from connect to the same server every time [KuSh]
BUGFIX: localization fixes [KuSh]
BUGFIX: some problems with InfoListCtrl (File/Source details in Download Window) [Eklmn]
BUGFIX: files weren't added to shared files if all blocks recovered by ICH [BavarianSnail]
BUGFIX: wrong values in categories because completed files weren't counted [DonGato]
BUGFIX: having non existing directories in shareddir.dat inhibits setting drive letter bold [DonGato]
BUGFIX: close of chat by button now sets focus on the last tab (for multiple closing) [DonGato]
BUGFIX: data transfer after cancel request [Eklmn]
BUGFIX: memleak in UDP socket [Eklmn]
BUGFIX: fix to limit requests to block borders [BavarianSnail]
BUGFIX: fixed command line server link loading (server was removed) [DonGato]
BUGFIX: fixed cumulative statistics totals for uploads and downloads [DonGato]
BUGFIX: fixed document filtered search [DonGato]
BUGFIX: fixed unknown sources due to addition of already known clients [Eklmn/DonGato]
BUGFIX: fixed precedence of category selection on WebServer and Search over Auto Cat feature [DonGato]
BUGFIX: removed FPU optimizations for non-MMX CPUs because of 100% corruption on downloads [DonGato]
BUGFIX: fix for statistics tree update delay not being obeyed [netwolf]
BUGFIX: fixed wrong server duration times (current and total) [netwolf]
BUGFIX: fixed the packet handling [Eklmn]
BUGFIX: added second sort to avoid jumping of non-eMule clients when sources are sorted by QR [DonGato]
BUGFIX: fixed change of sort by preferences in search list when a search is going on [DonGato]
BUGFIX: fixed sort for double columns in server list [morevit/DonGato]
BUGFIX: corrected tooltip font color [DropF]
BUGFIX: corrected SF Ratio on queue list [DonGato]
BUGFIX: corrected type switching in InfoList [Eklmn]
BUGFIX: fixed Search sorting by size [DonGato]
BUGFIX: force update of status categories when files are paused, stopped, resumed or completed [DonGato]
BUGFIX: fixed queue filtering reseting some values [DonGato]
BUGFIX: fixed cleanup on File Details when the whole file name is selected [DonGato]
BUGFIX: fixed A4AF icon showing without file status icons enabled [DonGato]
BUGFIX: integer size of transferred bytes in WebServer is too small for files over 2 Gb [BavarianSnail]
BUGFIX: WebServer: fixed some Javascript errors when using localizations [DonGato]
Quelle:
http://emuleplus.sourceforge.net/
