CORSAIR Marcus
Corsair Support
- Dabei seit
- Okt. 2021
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen inkl. download.
Software Enhancements
- The following legacy products are now supported:
- KATAR RGB
- SCIMITAR RGB
- Mic Boost option is now available for all iCUE supported headsets – to increase the gain on your microphone, go to the device settings and adjust the slider for ‘Mic Boost’ to your preference
- Audio driver has been updated – this will require a system restart after iCUE finishes the installation process
- Notifications have been added for the successful importing and exporting of profiles
HID Product Enhancements
- K65 MINI macros that are configured for trigger on release will properly work for key combinations with the FN and FN2 keys
- Quick Lighting Zones now have a 255 character limit to avoid text runoff issues
- For devices in multipoint mode (2:1 or 3:1), there is now a 10ms delay between character inputs for Text actions – this was to resolve characters missing or registering inaccurately when the action is
- triggered
- SABRE PRO and SABRE PRO RGB will now properly report the last DPI stage the device was using to iCUE instead of always defaulting back to DPI stage 1
DIY Product Enhancements
- Variable Speed for pumps is now available as a pump speed option for Hydro Series ELITE coolers
- Resolved a graphical issue with the sixth fan tile when using the wizard with Commander Core
