habe hier wieder ein nettes Problem. (Fedora Core 4)
Samba (3.0.14a) lässt sich nicht per "/etc/init.d/smb start" starten, -> failed
Allerdings aus Swat sowie der console mit "smbd -D" startet es ohne Probleme.
Logfile /var/log/samba/log.smbd bei start über /etc/init.d/smb start:
Code:[2005/06/26 12:53:21, 1] lib/util_unistr.c:load_case_tables(78) creating lame lowcase table [2005/06/26 12:53:21, 0] smbd/server.c:main(798) smbd version 3.0.14a started. Copyright Andrew Tridgell and the Samba Team 1992-2004 [2005/06/26 12:53:21, 0] groupdb/mapping.c:init_group_mapping(134) Failed to open group mapping database [2005/06/26 12:53:21, 0] groupdb/mapping.c:get_group_map_from_gid(275) failed to initialize group mapping [2005/06/26 12:53:21, 0] lib/account_pol.c:init_account_policy(60) Failed to open account policy database [2005/06/26 12:53:21, 0] lib/account_pol.c:init_account_policy(60) Failed to open account policy database [2005/06/26 12:53:21, 0] lib/account_pol.c:init_account_policy(60) Failed to open account policy database [2005/06/26 12:53:21, 0] lib/account_pol.c:init_account_policy(60) Failed to open account policy database [2005/06/26 12:53:21, 0] lib/account_pol.c:init_account_policy(60) Failed to open account policy database [2005/06/26 12:53:21, 0] lib/account_pol.c:init_account_policy(60) Failed to open account policy database [2005/06/26 12:53:21, 0] lib/pidfile.c:pidfile_create(98) ERROR: can't open /var/run/smbd.pid: Error was File exists
In /etc/init.d/smb wird samba über "daemon smbd -D" gestartet,
wobei daemon eine Funktion aus /etc/init.d/functions ist:
Und da sehe ich nicht mehr 100% durch,Code:# A function to start a program. daemon() { # Test syntax. local gotbase= force= local base= user= nice= bg= pid= nicelevel=0 while [ "$1" != "${1##[-+]}" ]; do case $1 in '') echo $"$0: Usage: daemon [+/-nicelevel] {program}" return 1;; --check) base=$2 gotbase="yes" shift 2 ;; --check=?*) base=${1#--check=} gotbase="yes" shift ;; --user) user=$2 shift 2 ;; --user=?*) user=${1#--user=} shift ;; --force) force="force" shift ;; [-+][0-9]*) nice="nice -n $1" shift ;; *) echo $"$0: Usage: daemon [+/-nicelevel] {program}" return 1;; esac done # Save basename. [ -z "$gotbase" ] && base=${1##*/} # See if it's already running. Look *only* at the pid file. if [ -f /var/run/${base}.pid ]; then local line p read line < /var/run/${base}.pid for p in $line ; do [ -z "${p//[0-9]/}" -a -d "/proc/$p" ] && pid="$pid $p" done fi [ -n "${pid:-}" -a -z "${force:-}" ] && return # make sure it doesn't core dump anywhere unless requested ulimit -S -c ${DAEMON_COREFILE_LIMIT:-0} >/dev/null 2>&1 # if they set NICELEVEL in /etc/sysconfig/foo, honor it [ -n "$NICELEVEL" ] && nice="nice -n $NICELEVEL" # Echo daemon [ "${BOOTUP:-}" = "verbose" -a -z "$LSB" ] && echo -n " $base" # And start it up. if [ -z "$user" ]; then $nice $* else $nice runuser -s /bin/bash - $user -c "$*" fi [ "$?" -eq 0 ] && success $"$base startup" || failure $"$base startup" }
sieht jemand anderes durch ?
/edit
identisches Problem bei winbind
nmbd läuft aber wunderbar über das script obwohl es genauso mit "daemon nmbd -D" gestartet wird.
/edit v.2
samba update auf 3.0.14a-2
-> es startet jetzt auch über das init-script, aber man kann nicht auf freigaben zugreifen
Über console direkt oder swat gestartet geht alles super
dow
26.06.2005, 13:13 #1Lieutenant
- Dabei seit
- Sep 2002
- Ort
- hainewalde.de
[FC4] samba startet nicht über /etc/init.d/smb start - sonst gehts aber
Geändert von dow (26.06.2005 um 16:03 Uhr)
E-Commerce, Wawi-Schnittstellen, PHP-Entwicklung, Online-Marketing @pcwehle.de
- Anzeige
Logge dich ein, um diese Anzeige nicht zu sehen. -
26.06.2005, 16:20 #2Lieutenant
Ersteller dieses Themas
- Dabei seit
- Sep 2002
- Ort
- hainewalde.de
Problem gefunden!
Grund für die Probleme ist die neue "verbesserte firewall" selinux
diese einfach in /etc/selinux/config von SELINUX=enforcing auf
SELINUX=permissive (warnt nur noch) oder
SELINUX=disabled setzen.
Soviel zur verbesserten Sicherheit
sry für Doppelpost - aber geht sonst im langen 1. post evtl. unter.E-Commerce, Wawi-Schnittstellen, PHP-Entwicklung, Online-Marketing @pcwehle.de
Zitieren
