CoD:Modern Warfare CoD4 Speilabsturz im Introbildschirm
re_spawn
Banned
Dez. 2007
Moinsen!
habe ein doch größeres Problem mit meinem CoD4 MW.
Habe es grade deinstalliert, da ich die map vacant nicht mehr zocken konnte. (Den fehler hatte ich schonmal)
Also, alles wie beim letzten mal gemacht, deinstalliert, registry von allen einträgen mit namen "Call of Duty 4" bereinigt und wieder installiert.
Also starte ich den SP Modus und nach ~5-10 Sekunden kommt ein Spielabsturz.
Fehlerlog:
Code:
Fastfile for zone 'common' appears corrupt or unreadable (code 107.)
Code:
----- Initializing Renderer ----
----- Client Initialization Complete -----
Attempting 44 kHz 16 bit [Windows default] sound
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 3.0
Vertex shader version is 3.0
Shader model 2.0 code path is available.
Shader model 3.0 code path is available.
Using Shader model 3.0 code path because it is the best available path on this hardware.
Attempting 640 x 480 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Using 2x anti-aliasing
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Loading fastfile code_post_gfx
Loading fastfile ui
Loading fastfile common
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Setting initial state...
DirectX reports 128 MB of video memory and 446 MB of available texture memory.
Using video memory size to cap used texture memory at 112 MB.
Texture detail is set automatically.
Using picmip 1 on most textures, 1 on normal maps, and 3 on specular maps
Waited 73 msec for asset '$white' of type 'image'.
Waited 615 msec for asset '$default' of type 'material'.
Waited 2 msec for asset '$additive' of type 'material'.
Waited 2 msec for asset 'shadowcookieblur' of type 'material'.
Waited 237 msec for asset 'shadowcaster' of type 'material'.
Waited 2 msec for asset 'stencilshadow' of type 'material'.
Waited 184 msec for asset 'cinematic' of type 'material'.
------- sound system initialization -------
Loaded zone 'code_post_gfx'
Waited 148 msec for asset 'soundaliases/channels.def' of type 'rawfile'.
------- sound system successfully initialized -------
end $init 4262 ms
--- Common Initialization Complete ---
Waited 1013 msec for asset 'ui/menus.txt' of type 'menufile'.
Working directory: E:\Games\Activision\Call of Duty 4 - Modern Warfare
Loaded zone 'ui'
Ich hoffe jemand kann da was sinnvolles rauslesen und mir antworten geben.
Meineswissens bin ich ja nicht der einzige mit solchen Mysteriösen fehlern lt. google.
Habe schon die Registry mit Registry Cleaner bearbeitet, alles was CoD4 betrifft von der platte gelöscht usw. usw.
Danke schonmal für eure hoffentlich schnellen antworten!
LG
re_spawn
Die Datei common.ff ist defekt, hast du eine Möglichkeit dir die von nen Kumpel zu besorgen?
würd sie dir ja gern hochladen aber mein upload ist grausam^^
Der Tipp wird ihm nicht viel bringen! Deinstallieren und nochmal verursachen!
Ich will dir nichts unterstellen oder so, aber lass mich raten -
gebrannte Version?
Uploadgeschwindigkeit: 33.11 KB/Sek, 38.27 Minuten übrig.
stelle dann den Link hier rein (denke nicht, dass es gegen die Regeln verstößt, oder?)
Tipps die ihm sagen neuinstallieren werden ihm auch nichts bringen, es scheint nicht an dem PC zu liegen, sondern an der Version beziehungsweise an der CD / DVD
Verweise hier auf Threads im Internet bei denen der Fehlercode 107 behoben wurde, indem Dateien hochgeladen wurden.
@ re_spawn hoffe das wird die Einzige Datei sein ;) und brenn dir die Dateien bitte auf CD o.Ä., damit du sie auch schön hast, falls du das nächste mal installierst
Habs jetzt schon das 4. Mal Probiert - geht nicht...
Ich habs das letzte mal vor ~ 1 Woche Installiert, komischerweise gings da noch...
Jetzt ebend nicht mehr, die frage ist nur warum?
@ Poseidon:
Kannst du oder wer anders mal die common.ff hochladen? Wäre echt nais. Kannst ja den rapidshare upload im hintergrund laufen lassen, dauert ja ned sonderlich lange bei 72,1 MB.
Achja die Datei "common.ff" ist genau 72,1 MB Groß
Größe: 75.665.529 Bytes
Größe auf Datenträger: 75.669.504 Bytes
Deine ist irgendwie größer als meine und ich kündigte eins höher doch schon an, dass ich es hochlade :D
- noch 20 min -
und (!) es liegt definitiv an der beschädigung der Datei, hab jetz das Internet durchforstet und naja, es scheinen viele zu haben
Das ding ist nur warum das so is ?!:freak:
Die DVD schrumpft ja nicht einfach so nur weil sie vielleicht nicht mit der verpesteten Berliner Luft klarkommt oO
Ich mein das Game is ja geil, aber warum so verbuggt?
Die sollten erstmal nen stabilen patch liefern oder das Game gleich in allen einzelteilen auf ihren FTP stellen (wenns da nicht auch auf mysteriöse weise anfängt zu schrumpfen) ~.~
Danke dir schonma für den Upload!
Nur mal so, mittlerweile gibt es Patch 1.5 und 1.6 steht in den Startlöchern..
Danke dir viele 1000x :D
funzt!
** Edit ** Ist das die Englische Version der common.ff? hab auf einmal englische untertitel =/
Suche jetzt die deutsche "common.ff" wenn die wer hat und uppen kann!
Danke euch schonmal!
Hat sich erledigt.
Das game hat sich i-wie grade komplett geschrottet. Sobald ich mit LvL 2 (die sequenz mit dem präsidenten) beginne gibts nen error. genauso im multiplayer auf mehreren maps.
/afk umtauschen oder image vom kumpel ziehen -.-
Kannst mit nem funzenden CD Key eh online spielen (btw :P hab noch einen, spiels eh nich /pn )
Hallo ihr,
ich hab die selbe Fehlermeldung und habe mir diese Common File grade eben auch runtergeladen. Geht nicht habs auch schon zigstausende male neuinstalliert alle neuen patches draufgebrettert etc aber immerwieder selbe fehlermeldung oder manchmal kommt auch gar nicht. ich kann meistens das lvl mit der Trainingsmission machen also das aller erste. Einmal kam ich bis zum Ende der zweiten Mission und danach wurd ich rausgeworfen. Der multiplayer modus läuft einwandfrei es ruckelt nicht alles perfekt keine fehlermeldungen etc.
wisst ihr irgendwie was man noch machen könnte? finde es scheiße wenn ich geld rausschmeiße und die hälfte vom spiel funktioniert nicht einmal -.-
ja habe ich als aller erstes probiert, habe die patches einmal über das internet runtergeladen und einmal von cd einer spielezeitschrift genommen.
Antworten
8
Aufrufe
3.572
Antworten
3
Aufrufe
6.239
F
