KingLM97
- Mai 2012
ich würde gerne meine Flüssigkeit Oil, generieren lassen. Genauso wie Wasser, nur mit Modloader Aber wie geht das?
Geht das wie hier?
Hier die mod_Oil:
BlockFlowingOil:
BlockStationaryOil:
Danke für Hilfe.
Geht das wie hier?
Code:
public void GenerateSurface(World world, Random rand, int chunkX, int chunkZ)
for(int i = 0; i < 10; i++)
int randPosX = chunkX + rand.nextInt(16);
int randPosY = rand.nextInt(64);
int randPosZ = chunkZ + rand.nextInt(16);
(new WorldGenMinable(mod_XXX.XXX, 50)).generate(world, rand, randPosX, randPosY, randPosZ);
Hier die mod_Oil:
Code:
package net.minecraft.src;
import java.util.Random;
public class mod_Oil extends BaseMod{
@Override
public String getVersion() {
return "1.2.5";
final Block OilFlowing = new BlockFlowingOil(150, Material.water).setHardness(100.0F).setBlockName("Oil").disableStats().setRequiresSelfNotify();
final Block OilStationary = new BlockStationaryOil(151, Material.water).setHardness(100.0F).setBlockName("Oil").disableStats().setRequiresSelfNotify();
@Override
public void load() {
ModLoader.registerBlock(OilFlowing);
ModLoader.registerBlock(OilStationary);
ModLoader.addName(OilFlowing, "Oil");
ModLoader.addName(OilStationary, "Oil");
ModLoader.addRecipe(new ItemStack(OilFlowing, 1), new Object[]{
"X", Character.valueOf('X'), Block.dirt
BlockFlowingOil:
Code:
public class BlockFlowingOil extends BlockFluid
* Number of horizontally adjacent liquid source blocks. Diagonal doesn't count. Only source blocks of the same
* liquid as the block using the field are counted.
int numAdjacentSources;
boolean isOptimalFlowDirection[];
int flowCost[];
protected BlockFlowingOil(int par1, Material par2Material)
super(par1, par2Material);
numAdjacentSources = 0;
isOptimalFlowDirection = new boolean[4];
flowCost = new int[4];
public int colorMultiplier(IBlockAccess iblockaccess, int i, int j, int k){
return 0x000000;
* Updates the flow for the BlockFlowing object.
private void updateFlow(World par1World, int par2, int par3, int par4)
int i = par1World.getBlockMetadata(par2, par3, par4);
par1World.setBlockAndMetadata(par2, par3, par4, blockID + 1, i);
par1World.markBlocksDirty(par2, par3, par4, par2, par3, par4);
par1World.markBlockNeedsUpdate(par2, par3, par4);
public boolean getBlocksMovement(IBlockAccess par1IBlockAccess, int par2, int par3, int par4)
return blockMaterial != Material.lava;
* Ticks the block if it's been scheduled
public void updateTick(World par1World, int par2, int par3, int par4, Random par5Random)
int i = getFlowDecay(par1World, par2, par3, par4);
byte byte0 = 1;
if (blockMaterial == Material.lava && !par1World.worldProvider.isHellWorld)
byte0 = 2;
boolean flag = true;
if (i > 0)
int j = -100;
j = getSmallestFlowDecay(par1World, par2 - 1, par3, par4, j);
j = getSmallestFlowDecay(par1World, par2 + 1, par3, par4, j);
j = getSmallestFlowDecay(par1World, par2, par3, par4 - 1, j);
j = getSmallestFlowDecay(par1World, par2, par3, par4 + 1, j);
int k = j + byte0;
if (k >= 8 || j < 0)
k = -1;
if (getFlowDecay(par1World, par2, par3 + 1, par4) >= 0)
int i1 = getFlowDecay(par1World, par2, par3 + 1, par4);
if (i1 >= 8)
k = i1;
else
k = i1 + 8;
if (numAdjacentSources >= 2 && blockMaterial == Material.water)
if (par1World.getBlockMaterial(par2, par3 - 1, par4).isSolid())
k = 0;
else if (par1World.getBlockMaterial(par2, par3 - 1, par4) == blockMaterial && par1World.getBlockMetadata(par2, par3, par4) == 0)
k = 0;
if (blockMaterial == Material.lava && i < 8 && k < 8 && k > i && par5Random.nextInt(4) != 0)
k = i;
flag = false;
if (k != i)
i = k;
if (i < 0)
par1World.setBlockWithNotify(par2, par3, par4, 0);
else
par1World.setBlockMetadataWithNotify(par2, par3, par4, i);
par1World.scheduleBlockUpdate(par2, par3, par4, blockID, tickRate());
par1World.notifyBlocksOfNeighborChange(par2, par3, par4, blockID);
else if (flag)
updateFlow(par1World, par2, par3, par4);
else
if (liquidCanDisplaceBlock(par1World, par2, par3 - 1, par4))
if (blockMaterial == Material.lava && par1World.getBlockMaterial(par2, par3 - 1, par4) == Material.water)
par1World.setBlockWithNotify(par2, par3 - 1, par4, Block.stone.blockID);
triggerLavaMixEffects(par1World, par2, par3 - 1, par4);
return;
if (i >= 8)
par1World.setBlockAndMetadataWithNotify(par2, par3 - 1, par4, blockID, i);
else
par1World.setBlockAndMetadataWithNotify(par2, par3 - 1, par4, blockID, i + 8);
else if (i >= 0 && (i == 0 || blockBlocksFlow(par1World, par2, par3 - 1, par4)))
boolean aflag[] = getOptimalFlowDirections(par1World, par2, par3, par4);
int l = i + byte0;
if (i >= 8)
l = 1;
if (l >= 8)
return;
if (aflag[0])
flowIntoBlock(par1World, par2 - 1, par3, par4, l);
if (aflag[1])
flowIntoBlock(par1World, par2 + 1, par3, par4, l);
if (aflag[2])
flowIntoBlock(par1World, par2, par3, par4 - 1, l);
if (aflag[3])
flowIntoBlock(par1World, par2, par3, par4 + 1, l);
* flowIntoBlock(World world, int x, int y, int z, int newFlowDecay) - Flows into the block at the coordinates and
* changes the block type to the liquid.
private void flowIntoBlock(World par1World, int par2, int par3, int par4, int par5)
if (liquidCanDisplaceBlock(par1World, par2, par3, par4))
int i = par1World.getBlockId(par2, par3, par4);
if (i > 0)
if (blockMaterial == Material.lava)
triggerLavaMixEffects(par1World, par2, par3, par4);
else
Block.blocksList[i].dropBlockAsItem(par1World, par2, par3, par4, par1World.getBlockMetadata(par2, par3, par4), 0);
par1World.setBlockAndMetadataWithNotify(par2, par3, par4, blockID, par5);
* calculateFlowCost(World world, int x, int y, int z, int accumulatedCost, int previousDirectionOfFlow) - Used to
* determine the path of least resistance, this method returns the lowest possible flow cost for the direction of
* flow indicated. Each necessary horizontal flow adds to the flow cost.
private int calculateFlowCost(World par1World, int par2, int par3, int par4, int par5, int par6)
int i = 1000;
for (int j = 0; j < 4; j++)
if (j == 0 && par6 == 1 || j == 1 && par6 == 0 || j == 2 && par6 == 3 || j == 3 && par6 == 2)
continue;
int k = par2;
int l = par3;
int i1 = par4;
if (j == 0)
k--;
if (j == 1)
k++;
if (j == 2)
i1--;
if (j == 3)
i1++;
if (blockBlocksFlow(par1World, k, l, i1) || par1World.getBlockMaterial(k, l, i1) == blockMaterial && par1World.getBlockMetadata(k, l, i1) == 0)
continue;
if (!blockBlocksFlow(par1World, k, l - 1, i1))
return par5;
if (par5 >= 4)
continue;
int j1 = calculateFlowCost(par1World, k, l, i1, par5 + 1, j);
if (j1 < i)
i = j1;
return i;
* Returns a boolean array indicating which flow directions are optimal based on each direction's calculated flow
* cost. Each array index corresponds to one of the four cardinal directions. A value of true indicates the
* direction is optimal.
private boolean[] getOptimalFlowDirections(World par1World, int par2, int par3, int par4)
for (int i = 0; i < 4; i++)
flowCost[i] = 1000;
int k = par2;
int j1 = par3;
int k1 = par4;
if (i == 0)
k--;
if (i == 1)
k++;
if (i == 2)
k1--;
if (i == 3)
k1++;
if (blockBlocksFlow(par1World, k, j1, k1) || par1World.getBlockMaterial(k, j1, k1) == blockMaterial && par1World.getBlockMetadata(k, j1, k1) == 0)
continue;
if (!blockBlocksFlow(par1World, k, j1 - 1, k1))
flowCost[i] = 0;
else
flowCost[i] = calculateFlowCost(par1World, k, j1, k1, 1, i);
int j = flowCost[0];
for (int l = 1; l < 4; l++)
if (flowCost[l] < j)
j = flowCost[l];
for (int i1 = 0; i1 < 4; i1++)
isOptimalFlowDirection[i1] = flowCost[i1] == j;
return isOptimalFlowDirection;
* Returns true if block at coords blocks fluids
private boolean blockBlocksFlow(World par1World, int par2, int par3, int par4)
if (i == Block.doorWood.blockID || i == Block.doorSteel.blockID || i == Block.signPost.blockID || i == Block.ladder.blockID || i == Block.reed.blockID)
return true;
if (i == 0)
return false;
Material material = Block.blocksList[i].blockMaterial;
if (material == Material.portal)
return true;
return material.blocksMovement();
* getSmallestFlowDecay(World world, intx, int y, int z, int currentSmallestFlowDecay) - Looks up the flow decay at
* the coordinates given and returns the smaller of this value or the provided currentSmallestFlowDecay. If one
* value is valid and the other isn't, the valid value will be returned. Valid values are >= 0. Flow decay is the
* amount that a liquid has dissipated. 0 indicates a source block.
protected int getSmallestFlowDecay(World par1World, int par2, int par3, int par4, int par5)
if (i < 0)
return par5;
if (i == 0)
numAdjacentSources++;
if (i >= 8)
i = 0;
return par5 >= 0 && i >= par5 ? par5 : i;
* Returns true if the block at the coordinates can be displaced by the liquid.
private boolean liquidCanDisplaceBlock(World par1World, int par2, int par3, int par4)
Material material = par1World.getBlockMaterial(par2, par3, par4);
if (material == blockMaterial)
return false;
if (material == Material.lava)
return false;
else
return !blockBlocksFlow(par1World, par2, par3, par4);
* Called whenever the block is added into the world. Args: world, x, y, z
public void onBlockAdded(World par1World, int par2, int par3, int par4)
super.onBlockAdded(par1World, par2, par3, par4);
if (par1World.getBlockId(par2, par3, par4) == blockID)
BlockStationaryOil:
Code:
public class BlockStationaryOil extends BlockFluid
protected BlockStationaryOil(int par1, Material par2Material)
setTickRandomly(false);
if (par2Material == Material.lava)
setTickRandomly(true);
* Lets the block know when one of its neighbor changes. Doesn't know which neighbor changed (coordinates passed are
* their own) Args: x, y, z, neighbor blockID
public void onNeighborBlockChange(World par1World, int par2, int par3, int par4, int par5)
super.onNeighborBlockChange(par1World, par2, par3, par4, par5);
setNotStationary(par1World, par2, par3, par4);
return 0x000000;
* Changes the block ID to that of an updating fluid.
private void setNotStationary(World par1World, int par2, int par3, int par4)
par1World.editingBlocks = true;
par1World.setBlockAndMetadata(par2, par3, par4, blockID - 1, i);
par1World.scheduleBlockUpdate(par2, par3, par4, blockID - 1, tickRate());
par1World.editingBlocks = false;
int i = par5Random.nextInt(3);
for (int j = 0; j < i; j++)
par2 += par5Random.nextInt(3) - 1;
par3++;
par4 += par5Random.nextInt(3) - 1;
int l = par1World.getBlockId(par2, par3, par4);
if (l == 0)
if (isFlammable(par1World, par2 - 1, par3, par4) || isFlammable(par1World, par2 + 1, par3, par4) || isFlammable(par1World, par2, par3, par4 - 1) || isFlammable(par1World, par2, par3, par4 + 1) || isFlammable(par1World, par2, par3 - 1, par4) || isFlammable(par1World, par2, par3 + 1, par4))
par1World.setBlockWithNotify(par2, par3, par4, Block.fire.blockID);
return;
continue;
if (Block.blocksList[l].blockMaterial.blocksMovement())
return;
if (i == 0)
int k = par2;
int i1 = par4;
for (int j1 = 0; j1 < 3; j1++)
par2 = (k + par5Random.nextInt(3)) - 1;
par4 = (i1 + par5Random.nextInt(3)) - 1;
if (par1World.isAirBlock(par2, par3 + 1, par4) && isFlammable(par1World, par2, par3, par4))
par1World.setBlockWithNotify(par2, par3 + 1, par4, Block.fire.blockID);
* Checks to see if the block is flammable.
private boolean isFlammable(World par1World, int par2, int par3, int par4)
return par1World.getBlockMaterial(par2, par3, par4).getCanBurn();
Danke für Hilfe.
