magjar
- Mai 2016
ich sehe grad bei comodo Einstellungen dass man die Wahl zwischen diesen beiden Varianten hat. Welche ist besser bzw was ist der Unterschied?
ab nur das hier auf der Comodo Homepage gefunden aber das hilft mir nicht weiter:
COMODO - Internet Security - This configuration is activated by default, when both Antivirus and Firewall components are installed, i.e. the complete installation. Firewall is always set to Safe mode. But according to the malware scanning results performed during the setup process, if no malware is found, Defense+ is set to Clean PC mode. Otherwise, the default is Safe mode. In this mode,
Image Execution Control is disabled.
Computer Monitor/Disk/Keyboard/DNS Client access/Window Messages are NOT monitored.
Only commonly infected files/folders are protected against infection.
Only commonly exploited COM interfaces are protected.
Defense+ is tuned to prevent infection of the system.
If you wish to switch to Internet Security option, you can select the option using My Configurations interface.
COMODO - Proactive Security - This configuration turns CIS into the ultimate protection machine. All possible protections are activated and all critical COM interfaces and files are protected. During the setup, if only Comodo Firewall installation option is selected, the next screen allows users to select this configuration as default CIS configuration. If selected, Firewall is always set to Safe mode. But according to the malware scanning results performed during the setup process, if no malware is found, Defense+ is set to Clean PC mode. Otherwise, the default is Safe mode.
