AthlonXP
- Apr. 2003
ATI TREIBER
ATI CATALYST ORIG TREIBER V 4.9
Homepage
http://www.ati.com
Changelog
# XIII: Light map artifacts are no longer noticed in the game when loading a saved game under Windows XP with an ATI RADEON™ 9200 installed
# FarCry v1.2: Playing the game under Windows XP with an ATI RADEON X800 series installed no longer results in texture corruption being seen on the ground
# IL2 Forgotten Battles: Playing the game under Windows XP with an ATI RADEON™ X800 series installed no longer results in the display corruption and the game failing to respond when FSAA is enabled and display is set to either 1200x960 or 1600x1200
# Indiana Jones and the Emperors Tomb: Display corruption and missing polygons are no longer noticed in the game
# PainKiller: missing textures are no longer noticed on the ground and light artifacts are noticed when moving around within the game or when moving in and out of the light.
# Serious Sam SE: Running the game under Windows XP with an ATI RADEON™ X800 PRO installed no longer results in lens flares showing through solid objects within the game
# Star Wars: Knights of the Old Republic: An access violation error no longer occurs when using the function Alt-Tab to get out of the game and then using the function Alt-Tab to get back into the game
# Tabula Rasa: Video rendering issues are no longer noticed playing the game under Windows XP with an ATI RADEON™ 9700 PRO installed
# Tony Hawk 4: playing the game under Windows XP with an ATI RADEON™ 9100 installed no longer results in white pixels being seen around the edges of objects
# Connecting an HDTV 7pin dongle to the video card no longer results in TV detection issues when both the TV and YPbPr (HDTV) are active
# Playing a DVD with PowerDVD on the primary display and playing an MPEG clip with Windows Media Player on the secondary display device no longer results in flickering and corruption being seen
Download
Komplettpaket mit CCC
http://www2.ati.com/drivers/wxp-w2k-ccc-8-051-040825a-017633c.exe
Komplettpaket mit CP
http://www2.ati.com/drivers/wxp-w2k-catalyst-8-051-040825a-017633c.exe
ATI OMEGA MOD TREIBER V 2.04.9
Homepage
http://www.omegadrivers.net/
Changelog
What's New? (2k/XP 2.5.76)
* Based on the official Catalyst 4.9 drivers.
* Removed ATITool from the package, it had many bugs and disabled a lot of
stuff, like DVI support and DDC. If you have it installed, I recommend that
you uninstall it before installing this set of drivers.
* Re-Enabled Overclocking Anti-Protection, it was missing from last release, sorry.
* Modified the ATI CP, now the Omega Drivers will use a built-in, special RadLinker
version with the following features: (some new, some old)
> Uses NO resources.
> Some new settings for both D3D and OGL.
> Can set Automatic Per-application profiles for OGL & D3D applications.
> Desktop Gamma is working and NOT resetting to default after exiting a game.
> Integrated Overclocking.
> No need for Gamma Hotkeys anymore since you can now set an individual Gamma value
for each game in their profile and done.
> This new CP was made in conjunction with ChrisW, maker of Radlinker, as an
exclusive feature for the Omega Drivers and we will keep adding features in
future releases.
* Modified driver installation/uninstall procedure with several new automatic features.
* Since RadLinker is now a vital part of the Omega Drivers, it will not be an option
to select during setup anymore, it will now automatically look for and uninstall ANY
previous version and replace it with the new one.
* Now, when uninstalling the Setup tools from the Omega options in the Start Menu, you
will also have the option to uninstall the Display drivers in one pass.
Known bugs:
* Laptop video playback problem still here, see notes.
* Hibernation and Standby are not working properly, I'm working on a fix.
Download
http://www.newgenerationorder.org/rad_w2kxp_omega_2576_7z.exe
ATI DNA MOD TREIBER V 3.0.4.9
Homepage
http://www.dna-drivers.nl
Changelog
VERSION:: DNA-drivers 3.0.4.9
* Based on the Official CATALYST 4.9 release
* Updated Installation package logo's
* ATIOverclockingAntiprotection is removed by default (special thanks
- goes out to Unwinder for this)
* Updated the FireGL OpenGL file to driver ver 8.023
* Updated Driver/CP installation background
* Updated support for:
-:ALL-IN-WONDER 9200 SERIES
* Added support for:
-:ECS RADEON 9550 REX 128MB
-:ASUS Extreme AX300SE/T 128MB
-:ASUS Extreme AX600XT-TD 128M
-:C.P. Technologies Inc. RADEON 9250
-:FIC RADEON 9550 128M
-:GeCube RADEON 9550
-:Celestica "Gold Edition" RADEON X300
* Fixed & Updated the DNA-drivers OpenGL Changer to Version 1.1
* Updated the DNA-drivers Theme Changer to version 1.1
Dowload
ftp://ftp.sweclockers.com/pub/Drivrutiner/Grafikkort/ATi/DNA/DNA_3.0.4.9.exe
UniAN Catalyst Unified Driver v1.1.49
Homepage
http://www.atimania.com/unian/
Changelog
leider keine !
Download
http://atimania.com/mboard/mboard.a...search=&b_cat=0&order_c=idx_num&order_da=desc
Treiber TweakTools
PowerStrip V 3.53
Homepage
http://www.entechtaiwan.com
Changelog
08/16/2004 - 3.53.460
- Revised Parhelia PLL phase changes
- Fixed Radeon 7500 head 2 support
- Added additional compatibility switches
- Made uninstaller silent switch optional
- Accelerated hotplug device detection
- Removed floor on Texas Instruments pclk
- Tightened up NV40 PLL constraints
Download
http://www.entechtaiwan.com/files/pstrip-i.exe
ATI TrayTool V 1.01.371
Homepage
http://www.radeon2.ru/atitray
Changelog
1.0.1.371
+ Reverted 3D detection code for OpenGL application to old one.
Because build 370 of ATI Tray Tools and FRAPS use same procedures to detect OpenGL activity, there are known bugs when 3d applications doesn't start. I have decided to revert my code to old detection procedure, which has no conflict with fraps.
Download
http://www.radeon2.ru/atitray/attsetup.exe
Rage3D Tweak V 3.9c
Homepage
http://www.rage3d.com/index.php?node=r3dtweak
Changelog
* Added support for X800 series and other new cards
* New Overclocking updates
* New GameUtil support - Now some clock-locked cards can be overclocked without a bios flash.
Download
http://www.rage3d.com/r3dtweak/dload/R3Dtweak39c.zip
ATI Tool V 0.0.22
Homepage
http://www.techpowerup.com/atitool/
Changelog
* Fixes to card detection on some ATI chipsets
* Fixed "When setting the speed in the log the selected speed is shown not the actual speed it is set to." (#38)
* Added infobox about possible problems when FRAPS is running
* Removed fan control tab for 9600.
* Some fixes to "try to keep gpu temp at". It will only work while ATITool is running. If you close ATITool fan speeds are set to ATI's defaults
* Fixed temp. reading error which showed 20° on 9800s with high load sometimes
* Disabled creation of file C:\Atitool detection log.txt
* Fixed excessive log entries generated during Find Max (#29)
* Fixed 3D detection for XP SP2 + AMD64 (#25)
* Forced 3D detection on for all executables starting with "bf_vietnam" (Battlefield: Vietname) until a proper fix is found
* Forced 3D detection on for all executables starting with "nwmain" (Neverwinter Nights) until a proper fix is found
* Fixed rounding error in fan speed settings (#16)
* Fixed rounding error in font size display in temp. settings (#23)
* Added current fan speed display to fan speed settings (#22)
* Memory timings editor is active now - values are not permanent and are reset at reboot. USE AT YOUR OWN RISK.
* Gamma settings are reapplied when display mode is changed (#14)
* Gamma settings panel shows numbers (#14)
* Added fan control option "Try to keep GPU temp. at xx°C" - this option is only available if temp. monitoring is enabled
* Added mini stats to temp. monitoring settings page
* Several speed optimized artifact detection code
* Dump bios button disabled on 9200 until a fix is found
* Replace temp. remote / local by "GPU" / "GPU environment"
* Fixed cosmetic bug in temp. settings panel (#15)
* Fixed bug with log file max. size .. the value was interpreted as Bytes (#13)
* Added include list for 3D detection
* No "scan running" message to log file right after start
* Fixed crash in 3D detection for 3dmark2001 and probably other apps
* Gamma hotkeys are disabled when gamma control is disabled
* Lots of fixes based on the great feedback after the 0.0.21 release, critical fixes are already incorporated into the 0.0.21 download
* Added option to scanning settings: "disable screensaver while scanning"
* Fixed ATI fan control. for some reason ATI defaults result in fan speeds > 100% to be programmed. This means that any fan speed >75% is actually 100% (can't run the fan faster than 100%). ATITool fixes this by setting the right register on the temp. chip.
* Moved fan speed registry key so its not lost every time you reinstall ATITool
Download
http://www.techpowerup.com/atitool/ATITool_0.0.22.exe
RadLinker V1.014
Homepage
http://www28.brinkster.com/chrisww1942/
Changelog
Re-enabled the game gamma setting as it is working again.
Download
http://users.adelphia.net/~webspace/RadLinker1014.zip
RadClocker V 2.012
Homepage
Changelog
leider keine !
Downlaod
http://users.adelphia.net/~webspace/RadClocker2012.zip
spz
Homepage
http://www.ati.com
Changelog
Download
Homepage
Changelog
> Uses NO resources.
future releases.
Known bugs:
Download
Homepage
Changelog
Dowload
Homepage
Changelog
leider keine !
Download
Treiber TweakTools
PowerStrip V 3.53
Homepage
Changelog
Download
Homepage
Changelog
1.0.1.371
Download
Rage3D Tweak V 3.9c
Homepage
Changelog
Download
ATI Tool V 0.0.22
Homepage
Changelog
Download
RadLinker V1.014
Homepage
Changelog
Download
RadClocker V 2.012
Homepage
Changelog
leider keine !
Downlaod
spz
