BlueScreen DRIVER_POWER_STATE_FAILURE
HansDampfHH
Cadet 1st Year
Mai 2013
Hallo, nachfolgend mein Ergebnis der Fehleranalyse.
Kann mir bitte jemand auf die Sprünge helfen?
Bluescreen nach dem Zuklappen meines Laptops (Ruhezustand, Energie sparen).
* Bugcheck Analysis *
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8007115060, Physical Device Object of the stack
Arg3: fffff80000b9c3d8, Functional Device Object of the stack
Arg4: fffffa800ce26010, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IRP_ADDRESS: fffffa800ce26010
DEVICE_OBJECT: fffffa8009bc8050
DRIVER_OBJECT: fffffa80098d4bf0
IMAGE_NAME: NETwNs64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4e39e7aa
MODULE_NAME: NETwNs64
FAULTING_MODULE: fffff88005a48000 NETwNs64
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff800031358c2 to fffff800030c5c00
STACK_TEXT:
fffff800`00b9c388 fffff800`031358c2 : 00000000`0000009f 00000000`00000003 fffffa80`07115060 fffff800`00b9c3d8 : nt!KeBugCheckEx
fffff800`00b9c390 fffff800`030d084c : fffff800`00b9c4c0 fffff800`00b9c4c0 00000000`00000000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x33af0
fffff800`00b9c430 fffff800`030d06e6 : fffffa80`0eb06c58 fffffa80`0eb06c58 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x6c
fffff800`00b9c4a0 fffff800`030d05ce : 000002a8`11223754 fffff800`00b9cb18 00000000`011db22e fffff800`03243848 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9caf0 fffff800`030d03b7 : 000000a5`721dbbc2 000000a5`011db22e 000000a5`721dbbe3 00000000`0000002e : nt!KiTimerExpiration+0x1be
fffff800`00b9cb90 fffff800`030bd90a : fffff800`03240e80 fffff800`0324ecc0 00000000`00000001 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`00b9cc40 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cc00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0x9F_IMAGE_NETwNs64.sys
Followup: MachineOwner
Google hat mir das dazu ausgespuckt
This memory dump blames NETwNs64.sys -
Intel® Wireless WiFi Link 5000 Series Adapter Driver for Windows 7. Please do the following:
- visit the Intel Download Center ( http://downloadcenter.intel.com ) and download the latest version of the drivers for that device
- uninstall the current drivers on your system for that device
- install the freshly downloaded drivers
- monitor for further BSOD's.
Okay, danke vorerst.
Ich werde den Treiber aktualisieren und mich wieder melden !
ich würde vorher den alten Treiber noch deinstallieren um mögliche probleme zu umgehen
Okay, Rückmeldung:
Mit dem ursprünglich neuerem Treiber gab es keine Verbesserung.
Glücklicherweise gab es erneut ein Update des Treibers und eine neue Version.
Installiert und bisher seit Tagen keine Probleme mehr.
Wäre ja toll wenn es so bleibt :-)
Ich habe noch einen HTPC der hin und dann mal Schwierigkeiten macht.
Habt ihr dazu vielleicht auch eine Meinung?
IRQL_GT_ZERO_AT_SYSTEM_SERVICE (4a)
Returning to usermode from a system call at an IRQL > PASSIVE_LEVEL.
Arguments:
Arg1: 81cb0472, Address of system function (system call routine)
Arg2: 00000002, Current IRQL
Arg3: 00000000, 0
Arg4: 00000000, 0
Debugging Details:
PEB is paged out (Peb.Ldr = 7ffd900c). Type ".hh dbgerr001" for details
PROCESS_NAME: TvService.exe
BUGCHECK_STR: RAISED_IRQL_FAULT
FAULTING_IP:
nt!NtDeviceIoControlFile+0
81cb0472 8bff mov edi,edi
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 76f370b4 to 81a7a569
STACK_TEXT:
88333c34 76f370b4 badb0d00 0883e990 00000000 nt!KiServiceExit2+0x160
WARNING: Frame IP not in any known module. Following frames may be wrong.
0883e9e8 00000000 00000000 00000000 00000000 0x76f370b4
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_NAME: nt!NtDeviceIoControlFile+0
MODULE_NAME: nt
IMAGE_NAME: ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4e02a389
FAILURE_BUCKET_ID: RAISED_IRQL_FAULT_TvService.exe_nt!NtDeviceIoControlFile+0
Hm, ja. Der Bluescreen trat beim Channelwechsel auf.
Hätte aber eher gehofft, dass es am Treiber für Ambilight oder der Grafik liegt.
Okay. Passiert ja glücklicherweise nicht oft.
Muss mich dann wohl eher auf den neuen TVServer von MePo 2 freuen.
Okay, es gibt noch einen weiteren Dump mit einer anderen Fehlermeldung, die allerdings auch etwas mit IRQ zu tun hatte. Ich werde versuchen zeitnah die Analyse einzustellen. Wäre natürlich schön wenn das Problem anders behoben werden kann.
@Hanne
Was ist denn neben der Grafikkarte noch eingesetzt ?
Es ist ein Asus P8H67-i mit einer onBoardGrafik .
Als DVB-S Empfänger habe ich eine Tevii USB Box extern am laufen.
Hier eine weitere Auswertung sowie weitere Dumps.
Vielen Dank für eure Unterstützung !
WORKER_THREAD_RETURNED_AT_BAD_IRQL (e1)
Arguments:
Arg1: 81c594b9, address of worker routine (do ln on this to find guilty driver)
Arg2: 00000002, IRQL returned at (should have been 0, but isn't).
Arg3: 86b67cf8, workitem parameter
Arg4: 86b67cf8, workitem address
Debugging Details:
FAULTING_IP:
nt!IopProcessWorkItem+0
81c594b9 8bff mov edi,edi
BUGCHECK_STR: 0xE1
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 81ac2bd6 to 81b23eb4
STACK_TEXT:
8ac93bf0 81ac2bd6 000000e1 81c594b9 00000002 nt!KeBugCheckEx+0x1e
8ac93c50 81c4dfda 00000000 aaecf47e 00000000 nt!ExpWorkerThread+0x278
8ac93c90 81af61d9 81ac295e 00000000 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
SYMBOL_NAME: nt!IopProcessWorkItem+0
MODULE_NAME: nt
FAILURE_BUCKET_ID: 0xE1_nt!IopProcessWorkItem+0
ich glaube du solltest den DriverVerifier mal aktivieren und dann die C:\Memory.dmp hochladen. Die Minis helfen in deinem Fall nicht.
Hui Jungs, ich freu mich über die rege Beteiligung !
Also:
-Ich habe gestern die neue BIOS Version geflasht. Vom 905 auf 907
-Den neuen ASMedia 3.0 Treiber installiert
-Als Ramdisk läuft Gavotte. Nur für TEMP-Zwecke
Ich muss auch gestehen, dass mir dieses Problem erst aufgefallen ist seit dem ich als externe Platte eine neue WD USB3.0 nutze.
Bei der USB2.0 Variante lief es problemlos. Da bei den DUMPS aber IRQ aufgeführt wurde habe ich die Platte immer ausgeschlossen.
Ich habe mir nun auch mal die Mühe gemacht und Windows in der 64bit Variante aufgesetzt, nebst sämtlicher aktueller Treiber.
Schlussendlich gibt es für die WD Platte auch noch eine neue Firmware, die ich noch flashen werde.
