ich wollte eigentlich "nur" die smart werte meiner festplatten unter linux auslesen. google brachte mich auf smartmontools. ich hab versucht, diese mit sudo apt-get install smartmontools zu installieren...kriege allerdings eine fehlermeldung
Sudo apt-get update half auch nicht....
wie krieg ich linux dazu, smartmontools zu installieren?
ich benutze ubuntu 12.10
edit: sudo apt-get install smartmontools --fix-missing hilft auch nicht wirklich es kommt ganze zeit:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
libhal-storage1 libhal1 libtiff4 openjdk-7-jre-lib swig swig2.0
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
heirloom-mailx
Suggested packages:
exim4 mail-transport-agent gsmartcontrol smart-notifier
Recommended packages:
mailx mailutils
The following NEW packages will be installed:
heirloom-mailx smartmontools
0 upgraded, 2 newly installed, 0 to remove and 5 not upgraded.
Need to get 459 kB/695 kB of archives.
After this operation, 1,743 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
WARNING: The following packages cannot be authenticated!
Install these packages without verification [y/N]? y
Err http://de.archive.ubuntu.com/ubuntu/ quantal/main smartmontools i386 5.43-0ubuntu1
404 Not Found [IP: 141.30.13.10 80]
Failed to fetch http://de.archive.ubuntu.com/ubuntu/pool/main/s/smartmontools/smartmontools_5.43-0ubuntu1_i386.deb 404 Not Found [IP: 141.30.13.10 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
404 Not Found [IP: 141.30.13.20 80]
Failed to fetch http://de.archive.ubuntu.com/ubuntu/pool/main/s/smartmontools/smartmontools_5.43-0ubuntu1_i386.deb 404 Not Found [IP: 141.30.13.20 80]
