orion@localhost orion $ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGIS_multisample, GLX_SGIX_fbconfig
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float,
GLX_ATI_render_texture
GLX extensions:
GLX_ARB_multisample
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON 9800 SE Generic
OpenGL version string: 1.3.5010 (X4.3.0-8.12.10)
OpenGL extensions:
GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array,
GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_multisample, GL_ARB_occlusion_query, GL_ARB_point_parameters,
GL_ARB_point_sprite, GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix,
GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program,
GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ATI_draw_buffers,
GL_ATI_element_array, GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader,
GL_ATI_map_object_buffer, GL_ATI_separate_stencil,
GL_ATI_texture_env_combine3, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_ATI_vertex_array_object,
GL_ATI_vertex_attrib_array_object, GL_ATI_vertex_streams,
GL_ATIX_texture_env_combine3, GL_ATIX_texture_env_route,
GL_ATIX_vertex_shader_output_point_size, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_texgen_reflection,
GL_EXT_texture3D, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_EXT_vertex_shader,
GL_HP_occlusion_test, GL_NV_blend_square, GL_NV_occlusion_query,
GL_NV_texgen_reflection, GL_SGI_color_matrix, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x2b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x2c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x2d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x2e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x2f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x30 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x31 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x32 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x33 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x34 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x35 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x36 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x37 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x38 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x39 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x3a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x3b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x3c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x3d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x3e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x3f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x40 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x41 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 6 1 None
0x42 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 6 1 None
0x43 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x44 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x45 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x46 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x47 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x48 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x49 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x4a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x4b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x4c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x4d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x4e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x4f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x50 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x51 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x52 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x53 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x54 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x55 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x56 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x57 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x58 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x59 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x5a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x5b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x5c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x5d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x5e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x5f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x60 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x61 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 6 1 None
0x62 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 6 1 None
