using System;
using System.IO;
class Program {
static void Info(string ErrorMsg)
if (ErrorMsg != null)
Console.WriteLine("Fehler: {0}", ErrorMsg);
Console.WriteLine();
string sExecutable = Environment.CommandLine;
int p = sExecutable.IndexOf(" ");
if (p > 0) {
sExecutable = sExecutable.Substring(0, p);
Console.WriteLine("Aufruf: {0} [-s] [Verzeichnis]", sExecutable);
Console.WriteLine(" [-s] Es werden auch Unterverzeichnisse angezeigt, welche zwar keine");
Console.WriteLine(" Dateien, aber weitere Unterverzeichnisse enthalten");
Console.WriteLine(" [Verzeichnis] Wurzelverzeichnis");
static void Main(string[] args)
string sRootDirectory = null;
bool bFindWithoutSubdirectories = true;
foreach (string arg in args)
if (arg.StartsWith("-") || arg.StartsWith("/"))
string argl = arg.Substring(1).ToLower();
if (argl == "s")
bFindWithoutSubdirectories = false;
else
Info("Falscher Parameter: " + arg);
return;
else
if (sRootDirectory != null)
return;
sRootDirectory = arg;
if (sRootDirectory == null)
sRootDirectory = Environment.CurrentDirectory;
string[] DirectoryList = Directory.GetDirectories(sRootDirectory, "*.*", SearchOption.AllDirectories);
foreach (string sDirectory in DirectoryList)
if (Directory.GetFiles(sDirectory).Length > 0) continue; // Dateien gefunden
if (bFindWithoutSubdirectories)
if (Directory.GetDirectories(sDirectory).Length > 0) continue; // Unterverzeichnisse gefunden
Console.WriteLine(sDirectory);
