mein system:
CPU Info
Physical Processors 1
Logical Processors 2
CPU 1/1
Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
Manufacturer Intel
Family Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
Architecture 64-bit
Internal Clock 2.7 GHz
Internal Clock Maximum 2.7 GHz
External Clock 333.0 MHz
Socket Designation Socket 775
Upgrade ZIF Socket
MultiCore 2 Processor Cores
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, SSE, SSE2, SSE3, PAE, NX
Version Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
Caches
Level 1 32 KB
Level 2 4 MB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.5512
Primary Device NVIDIA GeForce 9800 GTX/9800 GTX+
Linked Display Adapters false
Display Device 1/1
NVIDIA GeForce 9800 GTX/9800 GTX+ Driver 6.14.11.7779
Description NVIDIA GeForce 9800 GTX/9800 GTX+
Manufacturer NVIDIA
Total Local Video Memory 512 MB
Total Local Texture Memory 689 MB
AGP Aperture Size 0 B
Driver File nv4_disp.dll
Driver Version 6.14.11.7779
Driver Date 7-26-2008
Driver WHQL Certified false
Max Texture Width 8192 px
Max Texture Height 8192 px
Max User Clipping Planes 8
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3.0
Pixel Shader Version 3.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 1.1 GHz
VGA Core Clock 740.0 MHz
Max VGA Memory Clock 0.0 Hz
Max VGA Core Clock 0.0 Hz
PCI
Name NVIDIA GeForce 9800 GTX/9800 GTX+
Vendor ID 0x10de
Device ID 0x0612
SubSystem ID 0x059210de
Revision ID 0x00a2
Bus
Type PCI Express
Revision 2.0
Enabled true
Rate 16
Sideband Addressing Not Supported
Fast Write Not Supported
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
DirectShow
Version 9.0c
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
BDA MPEG2 Transport Information Filter
BDA Slip De-Framer
Color Space Converter
Creative AC3 Source Filter
Creative CDDA Source Filter
Creative Internet Source Filter
Creative LiveRecording Filter SxS
Creative MLP Source Filter
Creative NVF Filter
Creative Recording Wav_Asio Filter
Creative WMA Source Filter
DV Muxer
DV Source Filter
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Indeo audio software
Indeo video 4.4 Decompression Filter
Indeo video 5.10 Decompression Filter
Internal Script Command Renderer
Line 21 Decoder
Line 21 Decoder 2
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
Nero Audio Decoder 2
Nero DVD Decoder
Nero DVD Navigator
Nero FLV Splitter
Nero File Source (Async.)
Nero InteractiveGraphics Decoder
Nero MP4 Splitter
Nero Ogg Splitter
Nero PresentationGraphics Decoder
Nero QuickTime(tm) Audio Decoder
Nero QuickTime(tm) Video Decoder
Nero Resize
Nero Splitter
Nero Thumbnail Decoder
Nero Vcd Navigator
Nero Video Decoder
Overlay Mixer2
PreviewRenderer
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
DirectSound
Version 5.3.2600.5512
Speaker Configuration Stereo
Speaker Geometry Wide
Primary Device SB X-Fi Audio [7C00]
Sound Device 1/2
Creative X-Fi Audio Processor (WDM) Driver 5.12.8.1201
Capabilities
Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
Sound Device 2/2
Realtek High Definition Audio Driver 5.10.0.5497
Description Realtek HD Audio output
Manufacturer Realtek
PCI Devices
Texas Instruments OHCI-konformer IEEE 1394-Hostcontroller
Manufacturer Texas Instruments
Location PCI-Bus 5, Gert 7, Funktion 0
PCI Standard-ISA-Brcke
Manufacturer (Standardsystemgerte)
Location PCI-Bus 0, Gert 10, Funktion 0
NVIDIA nForce PCI System Management
Manufacturer NVIDIA
Location PCI-Bus 0, Gert 10, Funktion 1
PCI Standard-RAM-Controller
Location PCI-Bus 0, Gert 9, Funktion 0
Standard OpenHCD USB-Hostcontroller
Manufacturer (Standard-USB-Hostcontroller)
Location PCI-Bus 0, Gert 11, Funktion 0
Standard erweiterter PCI-zu-USB universeller Hostcontroller
Location PCI-Bus 0, Gert 11, Funktion 1
Standard-Zweikanal-PCI-IDE-Controller
Manufacturer (Standard-IDE-ATA/ATAPI-Controller)
Location PCI-Bus 0, Gert 13, Funktion 0
PCI Standard-PCI-zu-PCI-Brcke
Location PCI-Bus 0, Gert 15, Funktion 0
Microsoft UAA-Bustreiber fr High Definition Audio
Manufacturer Microsoft
Location PCI-Bus 0, Gert 15, Funktion 1
NVIDIA Network Bus Enumerator
Manufacturer NVIDIA
Location PCI-Bus 0, Gert 17, Funktion 0
Manufacturer NVIDIA
Location PCI-Bus 0, Gert 18, Funktion 0
Location PCI-Bus 0, Gert 19, Funktion 0
NVIDIA nForce Serial ATA Controller
Manufacturer NVIDIA Corporation
Location PCI-Bus 0, Gert 14, Funktion 0
Location PCI-Bus 0, Gert 14, Funktion 1
Location PCI-Bus 0, Gert 14, Funktion 2
PCI Standard-Host-CPU-Brcke
Location PCI-Bus 0, Gert 0, Funktion 0
Location PCI-Bus 0, Gert 0, Funktion 5
Location PCI-Bus 0, Gert 0, Funktion 3
Location PCI-Bus 0, Gert 0, Funktion 2
Location PCI-Bus 0, Gert 0, Funktion 4
Location PCI-Bus 0, Gert 0, Funktion 1
Location PCI-Bus 0, Gert 1, Funktion 0
Location PCI-Bus 0, Gert 1, Funktion 1
Location PCI-Bus 0, Gert 1, Funktion 2
Location PCI-Bus 0, Gert 1, Funktion 3
Location PCI-Bus 0, Gert 1, Funktion 4
Location PCI-Bus 0, Gert 1, Funktion 5
Location PCI-Bus 0, Gert 1, Funktion 6
Location PCI-Bus 0, Gert 0, Funktion 7
Location PCI-Bus 0, Gert 0, Funktion 6
Location PCI-Bus 0, Gert 2, Funktion 0
Location PCI-Bus 0, Gert 3, Funktion 0
Location PCI-Bus 0, Gert 2, Funktion 2
Location PCI-Bus 0, Gert 2, Funktion 1
Location PCI-Bus 1, Gert 0, Funktion 0
Location PCI-Bus 2, Gert 0, Funktion 0
Location PCI-Bus 2, Gert 2, Funktion 0
Manufacturer NVIDIA
Location PCI-Bus 3, Gert 0, Funktion 0
Manufacturer NVIDIA
Location PCI-Bus 4, Gert 0, Funktion 0
Manufacturer Creative Technology, Ltd.
Location PCI-Bus 5, Gert 9, Funktion 0
Card Slots
PCI Slot
Order 1
Designation PCI0
Type PCI
Characteristics 5.0V, PME Signal
Data Bus Width 32 b
Details Available, Long
IRQ 0
PCI Slot
Order 2
Designation PCI1
Type PCI
Data Bus Width 32 b
Details In Use, Long
IRQ 0
System Devices
Name PCI Standard-ISA-Brcke
Name NVIDIA nForce PCI System Management
Manufacturer NVIDIA
Name PCI Standard-RAM-Controller
Name PCI Standard-PCI-zu-PCI-Brcke
Name Microsoft UAA-Bustreiber fr High Definition Audio
Name PCI Standard-Host-CPU-Brcke
USB Devices
Description USB-Root-Hub
Driver Date 7-1-2001
Driver Version 5.1.2600.2180
Device Class Universal Serial Bus Controller
Description USB-HID (Human Interface Device)
Driver Version 5.1.2600.5512
Device Class Human Interface Device
Description Microsoft SideWinder Precision 2
Driver Version 5.1.2600.0
Description USB-Verbundgert
Description VGA SoC PC-Camer@
Driver Date 6-19-2006
Driver Version 1.0.2.4
Device Class Imaging Device
Description USB-Audiogert
Driver Version 5.1.2535.0
Device Class Sound, Video or Game Controller
FireWire Devices
Description 1394-Netzwerkadapter
Device Class Network Adapter
Monitor Info
Monitor 1/2
Name (Standardmonitor)
Manufacturer (Standardmonitortypen)
Max Width 0.000000000 px
Max Height 0.000000000 px
Monitor 2/2
Name SyncMaster 245B/245BW/245BPlus(Digital)
Manufacturer Samsung
Max Width 1920 px
Max Height 1200 px
Operating System Info
Name Microsoft Windows XP
Version 5.1.2600
PlatformId 2
Service Pack Service Pack 3 (v3.0)
Suite 256
Product Type 1
Media Center false
Windows Environment 32-bit
Locale DE
Desktop Width 1920 px
Desktop Height 1200 px
Desktop BPP 32 b
Internet Explorer Version 75730
DEP
Hardware Support true
Applications Protected true
Drivers Protected true
User Option On for essential Windows programs and services only
Open Processes
Name PID Memory Usage
3DMark06.exe 704 14 MB
alg.exe 3332 4 MB
csrss.exe 1108 3 MB
ctfmon.exe 1580 4 MB
CtHelper.exe 1092 4 MB
CTSVCCDA.EXE 560 1 MB
Ctxfihlp.exe 332 5 MB
CTxfispi.exe 1460 5 MB
DLLML.exe 896 7 MB
explorer.exe 736 23 MB
firefox.exe 3704 74 MB
GoogleToolbarNotifier.exe 1600 868 KB
ICQ.exe 1616 29 MB
IoctlSvc.exe 1272 2 MB
jusched.exe 1524 2 MB
lsass.exe 1196 2 MB
NBService.exe 2004 6 MB
NMSAccessU.exe 1056 2 MB
nSvcAppFlt.exe 956 5 MB
nSvcIp.exe 2096 6 MB
nTuneService.exe 1084 18 MB
nvsvc32.exe 1096 4 MB
PAStiSvc.exe 1712 1 MB
PnkBstrA.exe 1332 3 MB
PnkBstrB.exe 1496 3 MB
RTHDCPL.exe 860 22 MB
rundll32.exe 1508 4 MB
searchindexer.exe 2144 8 MB
services.exe 1184 3 MB
Skype.exe 1564 44 MB
skypePM.exe 3080 21 MB
smss.exe 1040 388 KB
spoolsv.exe 384 5 MB
svchost.exe 1372 5 MB
svchost.exe 1420 4 MB
svchost.exe 1772 29 MB
svchost.exe 1952 4 MB
svchost.exe 184 7 MB
svchost.exe 2032 4 MB
svchost.exe 1532 3 MB
System 4 240 KB
System Idle Process 0 28 KB
VolPanlu.exe 880 9 MB
winlogon.exe 1140 4 MB
wmiapsrv.exe 3052 4 MB
wmiprvse.exe 1296 5 MB
wmiprvse.exe 952 6 MB
Open Applications
__oxFrame.class__
3DMark06
ForumBase - Neues Thema erstellen - Mozilla Firefox
Logical Drives
Letter Label Type Capacity Available
A: Floppy 0 B 0 B
C: LOKALER SERVER Hard Disk 153.37 GB 109.07 GB
D: CD-ROM 0 B 0 B
Storage Devices
Storage Device 1/2
Hitachi HDS721616PLA SCSI Disk Device
Device Drive Type Hard Disk
Name Hitachi HDS721616PLA SCSI Disk Device
Manufacturer (Standardlaufwerke)
Model Hitachi HDS721616PLA SCSI Disk Device
Vendor ID String Hitachi
Product ID String HDS721616PLA
Product Revision String P22O
Interface Type IDE
Device Bus Type SCSI
Capacity 153.38 GB
Drive Letters C:
CD Max Read Speed 0
CD Read Capabilities -
CD Write Capabilities -
DVD Read Capabilities -
DVD Write Capabilities -
SMART Not Supported
Acoustic Management Not Supported
Storage Device 2/2
<unknown>
Device Drive Type DVD
Name <unknown>
Manufacturer <unknown>
Model <unknown>
Vendor ID String HL-DT-ST
Product ID String DVDRAM GSA-H66N
Product Revision String CB00
Interface Type <unknown>
Capacity 0 B
CD Max Read Speed 48
DVD Read Capabilities +R, -RW, +RW
DVD Write Capabilities -R, +R, -RW, +RW
SMART Not Supported
mein pc hängt sich immer in unregelmäsigen abstenden auf als ich das dvd laufwerk was bei diesen ataken immer kurz sich meldete ausgeschaltet habe war alles in ordnung woran kann das liegen weil das dvd laufwerk ja bootet schreibt und list ?
CPU Info
CPU 1/1
Manufacturer Intel
Architecture 64-bit
Upgrade ZIF Socket
Caches
Level 1 32 KB
Level 2 4 MB
DirectX Info
Version 9.0c
DirectDraw
Display Device 1/1
Manufacturer NVIDIA
PCI
Vendor ID 0x10de
Device ID 0x0612
Revision ID 0x00a2
Bus
Type PCI Express
Revision 2.0
Enabled true
Rate 16
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
DirectShow
Version 9.0c
.RAM file Parser
AC3 Parser Filter
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
BDA Slip De-Framer
Creative NVF Filter
DV Muxer
DV Source Filter
DV Splitter
DV Video Decoder
Decrypt/Tag
File Source (URL)
Line 21 Decoder
Line 21 Decoder 2
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Video Decoder
MPEG-2 Splitter
Multi-file Parser
NSC file Parser
Nero DVD Decoder
Nero DVD Navigator
Nero FLV Splitter
Nero MP4 Splitter
Nero Ogg Splitter
Nero Resize
Nero Splitter
Nero Vcd Navigator
Nero Video Decoder
Overlay Mixer2
PreviewRenderer
QT Decompressor
SAMI (CC) Parser
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
XML Playlist
DirectSound
Sound Device 1/2
Capabilities
Sound Device 2/2
PCI Devices
Manufacturer NVIDIA
Manufacturer NVIDIA
Manufacturer NVIDIA
Manufacturer NVIDIA
Manufacturer NVIDIA
Card Slots
PCI Slot
Order 1
Designation PCI0
Type PCI
Data Bus Width 32 b
IRQ 0
PCI Slot
Order 2
Designation PCI1
Type PCI
Data Bus Width 32 b
IRQ 0
System Devices
Manufacturer NVIDIA
USB Devices
FireWire Devices
Monitor Info
Monitor 1/2
Monitor 2/2
Max Width 1920 px
Max Height 1200 px
Version 5.1.2600
PlatformId 2
Suite 256
Product Type 1
Media Center false
Locale DE
Desktop BPP 32 b
DEP
Open Processes
alg.exe 3332 4 MB
csrss.exe 1108 3 MB
DLLML.exe 896 7 MB
ICQ.exe 1616 29 MB
lsass.exe 1196 2 MB
System 4 240 KB
Open Applications
__oxFrame.class__
3DMark06
Logical Drives
A: Floppy 0 B 0 B
D: CD-ROM 0 B 0 B
Storage Devices
Storage Device 1/2
Interface Type IDE
Capacity 153.38 GB
Drive Letters C:
CD Max Read Speed 0
SMART Not Supported
Storage Device 2/2
<unknown>
Name <unknown>
Model <unknown>
Capacity 0 B
SMART Not Supported
