knoppix lang=cn Specify language/keyboard (cn,de,da,es,fr,it,nl,pl,ru,sk,tr,tw or us)
knoppix alsa (or alsa=es1938) Use ALSA sound driver (at your own risk)
knoppix desktop=fluxbox Specify Window Manager (fluxbox,icewm,kde,larswm,twm,wmaker or xfce)
knoppix screen=1280x1024 Use specified Screen resolution for X
knoppix xvrefresh=60 (or vsync=60) Use 60 Hz vertical refresh rate for X
knoppix xhrefresh=80 (or hsync=80) Use 80 kHz horizontal refresh rate for X
knoppix xserver=XFree86 Use specified X-Server ( XFree86 or XF86_SVGA )
knoppix xmodule=ati Use specified XFree4-Module (ati,fbdev,i810,mga,nv,radeon,savage,s3 or svga)
knoppix 2 Boot in runlevel 2 (Textmode)
knoppix floppyconfig Run "knoppix.sh" from a floppy
knoppix myconf=/dev/sda1 Run "knoppix.sh" from a partition
knoppix myconf=scan (or config=scan) Try to find "knoppix.sh" automatically
knoppix home=/dev/sda1/knoppix.img Mount loopback file as /home/knoppix
knoppix home=scan Automatic search for knoppix homedir
knoppix no{apic,agp,apm,audio,ddc} Skip parts of HW-detection (1)
knoppix no{firewire,pcmcia,scsi} Skip parts of HW-detection (2)
knoppix no{swap,usb} Skip parts of HW-detection (3)
failsafe Boot with (almost) no HW-detection
knoppix pci=irqmask=0x0e98 Try this, if PS/2 mouse doesn't work *)
knoppix pci=bios Workaround for bad PCI controllers
knoppix ide2=0x180 nopcmcia Boot from PCMCIA-CD-Rom (some notebooks)
knoppix mem=128M Specify Memory size in MByte
knoppix dma Enable DMA for ALL IDE-Drives
knoppix noeject Do NOT eject CD after halt
knoppix noprompt Do NOT prompt to remove the CD
knoppix vga=normal No-framebuffer mode, but X
knoppix blind Start Braille-Terminal (no X)
knoppix brltty=type,port,table Parameters for Braille device
knoppix wheelmouse Enable IMPS/2 protocol for wheelmice
knoppix nowheelmouse Force plain PS/2 protocol for PS/2-mouse
fb1280x1024 Use fixed framebuffer graphics (1)
fb1024x768 Use fixed framebuffer graphics (2)
fb800x600 Use fixed framebuffer graphics (3)
knoppix keyboard=us xkeyboard=us Use different keyboard (text/X)
knoppix splash Boot with fancy background splashscreen
knoppix toram Copy CD to RAM and run from there
knoppix tohd=/dev/hda1 Copy CD to HD partition and run there
knoppix fromhd=/dev/hda1 Boot from previously copied CD-Image
knoppix testcd Check CD data integrity and md5sums
expert Interactive setup for experts
