belbono@linux:~/Kernel/req/isdn4k-utils> rpm --rebuild isdn4k-utils-3.1-62.src.rpm
--rebuild: unknown option
...soviel zum kommando --rebuild
linux:/home/belbono/Kernel/req/module-init-tools-0.9.15-pre4 # ./configure && make
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
configure: Adding gcc options: -g -O2 -Wunused -Wall -Wcast-align
configure: creating ./config.status
config.status: creating Makefile
config.status: executing depfiles commands
if [ "docbook2man" = "docbook2man" ]; then \
docbook2man doc/modprobe.conf.sgml > /dev/null 2>&1; \
else \
docbook2man doc/modprobe.conf.sgml 2>&1 > modprobe.conf.5 | sed 's/^[^:]*://'; \
fi
make: *** [modprobe.conf.5] Fehler 127
das zu den module init tools - denke ma hier is schon der fehler geboren der die make install etwas schief gehen lässt
linux:/home/belbono/Kernel/req/procps/procps-2.0.11 # make install
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -c oldps.c
make -C proc `basename proc/libproc.so.2.0.11` SHARED=1 SHLIBDIR=/lib VERSION=2 SUBVERSION=0 MINORVERSION=11 LIBVERSION=2.0.11
make[1]: Entering directory `/home/belbono/Kernel/req/procps/procps-2.0.11/proc'
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -MM -MG alloc.c compare.c devname.c ksym.c output.c pwcache.c readproc.c signals.c status.c sysinfo.c version.c whattime.c > .depend
make[1]: Leaving directory `/home/belbono/Kernel/req/procps/procps-2.0.11/proc'
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c alloc.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c compare.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c devname.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c ksym.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c output.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c pwcache.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c readproc.c
echo '#include <signal.h>' | gcc -E -dM - | \
sed 's/.*SIGSTKSZ.*//g' | \
tr -s '\t ' ' ' | sort -n +2 | sed \
's:#define SIG\([A-Z]\+[0-9]*\) \([0-9]\+\) *\(\|/\*.*\)$:{\
\2,"\1" },
;d' > signames.h
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c signals.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c status.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c sysinfo.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -DVERSION=\"2\" -DSUBVERSION=\"0\" -DMINORVERSION=\"11\" -c version.c
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -c whattime.c
gcc -Wl,-warn-common -shared -Wl,-soname,libproc.so.2.0.11 -o libproc.so.2.0.11 alloc.o compare.o devname.o ksym.o output.o pwcache.o readproc.o signals.o status.o sysinfo.o version.o whattime.o -lc
ln -sf libproc.so.2.0.11 libproc.so
gcc -Wl,-warn-common -o oldps oldps.o proc/libproc.so.2.0.11
install --strip oldps /usr/bin/oldps
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -c uptime.c
gcc -Wl,-warn-common -o uptime uptime.o proc/libproc.so.2.0.11
install --strip uptime /usr/bin/uptime
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -c tload.c
gcc -Wl,-warn-common -o tload tload.o proc/libproc.so.2.0.11
install --strip tload /usr/bin/tload
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -c free.c
gcc -Wl,-warn-common -o free free.o proc/libproc.so.2.0.11
install --strip free /usr/bin/free
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -DW_SHOWFROM -c w.c
gcc -Wl,-warn-common -o w w.o proc/libproc.so.2.0.11
install --strip w /usr/bin/w
gcc -D_GNU_SOURCE -O3 -Wall -Wstrict-prototypes -Wshadow -I/home/belbono/Kernel/req/procps/procps-2.0.11 -I/usr/include/ncurses -I/usr/X11R6/include -fwritable-strings -c top.c
top.c:102:21: termcap.h: Datei oder Verzeichnis nicht gefunden
top.c: In function `setup_terminal':
top.c:319: Warnung: implicit declaration of function `tgetent'
top.c:325: Warnung: implicit declaration of function `tgetstr'
top.c:325: Warnung: assignment makes pointer from integer without a cast
top.c:326: Warnung: assignment makes pointer from integer without a cast
top.c:327: Warnung: assignment makes pointer from integer without a cast
top.c:328: Warnung: assignment makes pointer from integer without a cast
top.c:329: Warnung: assignment makes pointer from integer without a cast
top.c:330: Warnung: assignment makes pointer from integer without a cast
top.c:331: Warnung: assignment makes pointer from integer without a cast
top.c:332: Warnung: assignment makes pointer from integer without a cast
top.c: In function `error_end':
top.c:594: Warnung: implicit declaration of function `tputs'
top.c:594: Warnung: implicit declaration of function `tgoto'
top.c: In function `window_size':
top.c:646: Warnung: implicit declaration of function `tgetnum'
make: *** [top.o] Fehler 1
procps 2.0.11 ....und zwar nachdem ich eine source rpm installiert hab und dann unter usr/..../sources/ eine procps-2.0.11.tar.bz2 gefunden hab die ich in mein homeverz. entpackt habe und dann eben make install eingegeben hab
linux:/home/belbono/isdn4k-utils # make
make[1]: Entering directory `/home/belbono/isdn4k-utils/scripts/lxdialog'
gcc -O2 -Wall -fomit-frame-pointer -DLOCALE -DCURSES_LOC="<curses.h>" -c -o lxdialog.o lxdialog.c
In file included from lxdialog.c:22:
dialog.h:29:20: curses.h: Datei oder Verzeichnis nicht gefunden
dialog.h:109: error: parse error before "use_colors"
dialog.h:109: Warnung: type defaults to `int' in declaration of `use_colors'
dialog.h:109: Warnung: data definition has no type or storage class
dialog.h:110: error: parse error before "use_shadow"
dialog.h:110: Warnung: type defaults to `int' in declaration of `use_shadow'
dialog.h:110: Warnung: data definition has no type or storage class
dialog.h:112: error: parse error before "attributes"
dialog.h:112: Warnung: type defaults to `int' in declaration of `attributes'
dialog.h:112: Warnung: data definition has no type or storage class
dialog.h:125: error: parse error before '*' token
dialog.h:128: error: parse error before '*' token
dialog.h:129: error: parse error before '*' token
dialog.h:130: error: parse error before '*' token
dialog.h:132: error: parse error before '*' token
lxdialog.c: In function `main':
lxdialog.c:94: Warnung: implicit declaration of function `refresh'
lxdialog.c:128: error: `stdscr' undeclared (first use in this function)
lxdialog.c:128: error: (Each undeclared identifier is reported only once
lxdialog.c:128: error: for each function it appears in.)
lxdialog.c:128: error: `LINES' undeclared (first use in this function)
lxdialog.c:128: error: `COLS' undeclared (first use in this function)
lxdialog.c: In function `Usage':
lxdialog.c:142: Warnung: implicit declaration of function `fprintf'
lxdialog.c:142: error: `stderr' undeclared (first use in this function)
lxdialog.c: In function `j_inputbox':
lxdialog.c:225: Warnung: implicit declaration of function `fputs'
lxdialog.c:225: error: `stderr' undeclared (first use in this function)
/usr/include/bits/string2.h: At top level:
dialog.h:112: Warnung: array `attributes' assumed to have one element
make[1]: *** [lxdialog.o] Fehler 1
make[1]: Leaving directory `/home/belbono/isdn4k-utils/scripts/lxdialog'
make: *** [scripts/lxdialog/lxdialog] Fehler 2
linux:/home/belbono/isdn4k-utils # make install
set -e; for i in `echo `; do make -C $i install; done
(some) ISDN devices already exist, not creating them.
Use scripts/makedev.sh manually if necessary.
hier also die isdntools - die hab ich mit rpm --rebuilddb source.rpm erstmal ja ...eben vom homeverz. ins usr/...sources/ verz. kopiert (was der noch gemacht hat weiss ich nicht) alles andere steht da
das is wohl alles - ich hoffe man kann damit was anfangen
