NetCrack
- Okt. 2001
Hi Leutz !
Ich hab eben das Pointrelease 1.31 für Q3Arena Installiert, vorher hat ich 1.09. Jedes Mal wenn ich nun Q3 starten will macht er console ändert kurz die auflösung und spingt wieder in die console zurück wo dann
User Interface is version 4, expected 3
rot blinkt.
Wer kann damit was anfangen ? Plz help.
Hier noch mein Console Log falls es hilft :
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
E:\Quake III Arena\baseq3\pak7.pk3 (4 files)
E:\Quake III Arena\baseq3\pak6.pk3 (64 files)
E:\Quake III Arena\baseq3\pak5.pk3 (7 files)
E:\Quake III Arena\baseq3\pak4.pk3 (272 files)
E:\Quake III Arena\baseq3\pak3.pk3 (4 files)
E:\Quake III Arena\baseq3\pak2.pk3 (148 files)
E:\Quake III Arena\baseq3\pak1.pk3 (26 files)
E:\Quake III Arena\baseq3\pak0.pk3 (3539 files)
E:\Quake III Arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: kumpel
IP: 192.168.120.254
IP: 192.168.0.1
Working directory: E:\Quake III Arena
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...41 PFDs found
...hardware acceleration found
...PIXELFORMAT 3 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...using GL_S3_s3tc
...using GL_EXT_texture_env_add
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...WGL_3DFX_gamma_control not found
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce2 GTS/AGP/3DNOW!
GL_VERSION: 1.3.1
GL_EXTENSIONS: GL_ARB_imaging GL_ARB_multitexture GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_transpose_matrix GL_S3_s3tc GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_cube_map GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_vertex_weighting GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_evaluators GL_NV_fence GL_NV_fog_distance GL_NV_li
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_ACTIVE_TEXTURES_ARB: 2
PIXELFORMAT: color(16-bits) Z(16-bit) stencil(0-bits)
MODE: 6, 1024 x 768 fullscreen hz:60
GAMMA: hardware w/ 0 overbright bits
CPU: x86 (P5/Pentium2, MMX)
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
texture bits: 16
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
Initializing Shaders
...loading 'scripts/lightningnew.shader'
...loading 'scripts/explode1.shader'
...loading 'scripts/gfx.shader'
...loading 'scripts/tim.shader'
...loading 'scripts/base.shader'
...loading 'scripts/base_button.shader'
...loading 'scripts/base_floor.shader'
...loading 'scripts/base_light.shader'
...loading 'scripts/base_object.shader'
...loading 'scripts/base_support.shader'
...loading 'scripts/base_trim.shader'
...loading 'scripts/base_wall.shader'
...loading 'scripts/common.shader'
...loading 'scripts/ctf.shader'
...loading 'scripts/eerie.shader'
...loading 'scripts/gothic_block.shader'
...loading 'scripts/gothic_floor.shader'
...loading 'scripts/gothic_light.shader'
...loading 'scripts/gothic_trim.shader'
...loading 'scripts/gothic_wall.shader'
...loading 'scripts/hell.shader'
...loading 'scripts/liquid.shader'
...loading 'scripts/menu.shader'
...loading 'scripts/models.shader'
...loading 'scripts/organics.shader'
...loading 'scripts/sfx.shader'
...loading 'scripts/shrine.shader'
...loading 'scripts/skin.shader'
...loading 'scripts/sky.shader'
...loading 'scripts/test.shader'
----- finished R_Init -----
------- sound initialization -------
Initializing DirectSound
----- Sound Info -----
sound system is muted
1 stereo
32768 samples
16 samplebits
1 submission_chunk
22050 speed
0xc268060 dma buffer
Forcing all sounds to 8 bit
No background file.
Loading dll file ui.
Failed to load dll, looking for qvm.
Loading vm file vm/ui.qvm.
VM file ui compiled to 944496 bytes of code
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
rot blinkt.
execing default.cfg
Winsock Initialized
Hostname: kumpel
IP: 192.168.120.254
IP: 192.168.0.1
----- R_Init -----
...initializing QGL
...calling CDS: ok
...41 PFDs found
...using GL_S3_s3tc
GL_VERSION: 1.3.1
picmip: 1
texture bits: 16
texenv add: enabled
1 stereo
32768 samples
16 samplebits
1 submission_chunk
22050 speed
No background file.
RE_Shutdown( 1 )
