Nginx Dateien cachen
ClocxHD
Aug. 2014
ich möchte die Caching-Funktion von Nginx verwenden.
Allerdings funktioniert meine Konfiguration nicht.
Bekomme beim Neustart von Nginx folgende Meldung:
Code:
nginx: [warn] duplicate MIME type "text/html" in /etc/nginx/nginx.conf:38
nginx: [emerg] the size 10485760 of shared memory zone "microcache" conflicts with already declared size 0 in /etc/nginx/nginx.conf:41
nginx: configuration file /etc/nginx/nginx.conf test failed
Nginx.conf:
Code:
user              nginx;
worker_processes  1;
error_log  /var/log/nginx/error.log;
#error_log  /var/log/nginx/error.log  notice;
#error_log  /var/log/nginx/error.log  info;
pid        /var/run/nginx.pid;
events {
    worker_connections  1024;
http {
        server_tokens off;
        include       /etc/nginx/mime.types;
        include /etc/nginx/sites-enabled/*;
        default_type  application/octet-stream;
        log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                '$status $body_bytes_sent "$http_referer" '
        '"$http_user_agent" "$http_x_forwarded_for"';
        access_log  /var/log/nginx/access.log  main;
        sendfile        on;
        #tcp_nopush     on;
        #keepalive_timeout  0;
        keepalive_timeout  65;
        gzip on;
        gzip_disable "MSIE [1-6]\.(?!.*SV1)";
        gzip_proxied any;
        gzip_buffers 16 8k;
        gzip_types text/plain text/html text/css text/xml application/x-javascript application/xml application/xml+rss text/javascript;
        gzip_vary on;
        fastcgi_cache_path /var/cache/nginx levels=1:2 keys_zone=microcache:10m max_size=1000m inactive=60m;
        include /etc/nginx/conf.d/*.conf;
vHost:
Code:
server {
        listen 80;
        server_name fabian-thielen.de;
        #server_name "~^(?!www\.).*" ;
        return 301 $scheme://www.$host$request_uri;
server {
        server_tokens off;
        server_name www.fabian-thielen.de;
        listen 80;
        location / {
                root /var/sites/Foundation;
                index index.html index.php;
        location ~* \.php$ {
                fastcgi_pass 127.0.0.1:9000;
                include fastcgi_params;
                fastcgi_index index.php;
                fastcgi_param SCRIPT_FILENAME   $document_root$fastcgi_script_name;
                #Cache start
                # Setup var defaults
                set $no_cache "";
                # If non GET/HEAD, don't cache & mark user as uncacheable for 1 second via cookie
                if ($request_method !~ ^(GET|HEAD)$) {
                    set $no_cache "1";
                # Drop no cache cookie if need be
                # (for some reason, add_header fails if included in prior if-block)
                if ($no_cache = "1") {
                    add_header Set-Cookie "_mcnc=1; Max-Age=2; Path=/";
                    add_header X-Microcachable "0";
                # Bypass cache if no-cache cookie is set
                if ($http_cookie ~* "_mcnc") {
                            set $no_cache "1";
                # Bypass cache if flag is set
                fastcgi_no_cache $no_cache;
                fastcgi_cache_bypass $no_cache;
                fastcgi_cache microcache;
                fastcgi_cache_key $scheme$host$request_uri$request_method;
                fastcgi_cache_valid 200 301 302 10m;
                fastcgi_cache_use_stale updating error timeout invalid_header http_500;
                fastcgi_pass_header Set-Cookie;
                fastcgi_pass_header Cookie;
                fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
                #Cache ende
Woran liegt das?
LG,
ClocxHD
Versuch mal, in der nginx.conf die Zeile "include /etc/nginx/sites-enabled/*;" ans Ende zu schieben, so dass sie erst nach "fastcgi_cache_path ..." ausgeführt wird.
