zak999
- März 2010
Hallo Leute heute ist der NIVDIA CUDA Version 6.5.11 mit NIVDIA Treiber 340.46 erscheinen. Wer es Downloaden will muss sich bei NVIDIA Developer Registrieren.
Info:
We’re pleased to announce the CUDA® 6.5 Release Candidate (RC) is now available to all CUDA Registered Developers. As a member of the CUDA Registered Developer program, you can now download this preview of the CUDA Toolkit before it becomes available to the public.
Your existing applications can run faster simply by recompiling with this latest version of the CUDA Toolkit. Give it a try and share your experience via the Feedback link on the downloads page. And, as always, if you encounter any problems please file a bug!
Check out the Release Notes for a complete list of new features and platforms supported in this release. Highlights include support for:
• 64–bit ARM–based systems
• Microsoft Visual Studio 2013 (VC12)
• Using cuFFT callbacks for higher performance custom processing on input or output data
• Improved debugging for CUDA FORTRAN applications
• BSR sparse matrix format in cuSPARSE routines
• Application Replay mode in both the Visual Profiler and command line cudaprof
• Updated CUDA Occupancy Calculator API provides optimal kernel launch configurations
• New “nvprune” utility to remove portions of object files for specified GPU architectures
Download the CUDA 6.5 RC today at https://developer.nvidia.com/rdp/cuda-65-rc-toolkit-download
Andere Seite:
http://www.geeks3d.com/forums/index.php/topic,3661.0.html
comes also with PhysX 9.14.0610 System Software
Info:
Andere Seite:
