Catalyst 14.9 WHQL erschienen
Status
horn 29
Juli 2005
Heute ist endlich der 14.9 WHQL Treiber erschienen,
nach knapp 5 Monatiger Durststrecke!
Performancemäßig hat sich so ziemlich einiges getan.
Hoffe der baldige Beta Treiber legt da noch einen drauf, bzw. nochmals ordentlich zu!
https://www.computerbase.de/downloads/treiber/grafikkarten/amd-adrenalin-treiber/
Release Notes:
Performance improvements (comparing AMD Catalyst 14.9 vs. AMD Catalyst 14.4)
3DMark Sky Diver improvements
AMD A4 6300 – improves up to 4%
Enables AMD Dual Graphics / AMD CrossFire support
3DMark Fire Strike
AMD Radeon R9 290 Series - improves up to 5% in Performance Preset
3DMark11
AMD Radeon R9 290 Series / R9 270 Series - improves up to 4% in Entry and Performance Preset
BioShock Infinite
AMD Radeon R9 290 Series – 1920x1080 - improves up to 5%
Company of Heroes 2
AMD Radeon R9 290 Series - improves up to 8%
Crysis 3
AMD Radeon R9 290 Series / R9 270 Series – improves up to 10%
Grid Auto Sport
AMD CrossFire profile
Murdered Soul Suspect
AMD Radeon R9 290X (2560x1440, 4x MSAA, 16x AF) – improves up to 50%
AMD Radeon R9 290 Series / R9 270 Series – improves up to 6%
CrossFire configurations improve scaling up to 75%
Plants vs. Zombies (Direct3D performance improvements)
AMD Radeon R9 290X - 1920x1080 Ultra – improves up to 11%
AMD Radeon R9290X - 2560x1600 Ultra – improves up to 15%
AMD Radeon R9290X CrossFire configuration (3840x2160 Ultra) - 92% scaling
Batman Arkham Origins:
AMD Radeon R9 290X (4x MSAA) – improves up to 20%
CrossFire configurations see up to a 70% gain in scaling
Wildstar
Power Xpress profile
Performance improvements to improve smoothness of application
Performance improves up to 30% on the AMD Radeon R9 and R7 Series of products for both single GPU and Multi-GPU configurations
Tomb Raider
AMD Radeon R9 290 Series – improves up to 5%
Watch Dogs
AMD Radeon R9 290 Series / R9 270 Series – improves up to 9%
AMD CrossFire – Frame pacing improvement
Improved CrossFire performance – up to 20%
Assassin's Creed IV
Improves CrossFire scaling (3840x2160 High Settings) up to 93% (CrossFire scaling improvement of 25% compared to AMD Catalyst 14.4)
Lichdom
Improves performance for single GPU and Multi-GPU configurations
Star Craft II
AMD Radeon R9 290X (2560x1440, AA, 16x AF) – improves up to 20%
AMD Eyefinity enhancements
Mixed Resolution Support
A new architecture providing brand new capabilities
Display groups can be created with monitors of different resolution (including difference sizes and shapes)
Users have a choice of how surface is created over the display group
Fill – legacy mode, best for identical monitors
Fit – create the Eyefinity surface using best available rectangular area with attached displays
Expand – create a virtual Eyefinity surface using desktops as viewports onto the surface
Eyefinity Display Alignment
Enables control over alignment between adjacent monitors
One-Click Setup
Driver detects layout of extended desktop
Can create Eyefinity display group using this layout in one click!
New user controls for video color and display settings
Greater control over Video Color Management:
Controls have been expanded from a single slider for controlling Boost and Hue to per color axis
Color depth control for Digital Flat Panels (available on supported HDMI and DP displays)
Allows users to select different color depths per resolution and display
AMD Mantle enhancements
Mantle now supports AMD Mobile products with Enduro technology
Battlefield 4: AMD Radeon HD 8970M (1366x768; high settings) – 21% gain
Thief: AMD Radeon HD 8970M (1920x1080; high settings) – 14% gain
Star Swarm: AMD Radeon HD 8970M (1920x1080; medium settings) – 274% gain
Enables support for Multi-GPU configurations with Thief (requires the latest Thief update)
AMD AM1 JPEG decoding acceleration
JPEG decoding acceleration was first enabled on the A10 APU Series in AMD Catalyst 14.1 beta, and has now been extended to the AMD AM1 Platform
Provides fast JPEG decompression
Provides Power Efficiency for JPEG decompression
Resolved Issues
60Hz SST flickering has been identified as an issue with non-standard display timings exhibited by the AOC U2868PQU panel on certain AMD Radeon™ graphics cards. A software workaround has been implemented in the AMD Catalyst 14.9 driver to resolve the display timing issues with this display
Users seeing flickering issues in 60Hz SST mode are further encouraged to obtain newer display firmware from their monitor vendor that will resolve flickering at its origin.
Users are additionally advised to utilize DisplayPort-certified cables to ensure the integrity of the DisplayPort data connection.
4K panel flickering issues found on the AMD Radeon R9 290 Series and AMD Radeon HD 7800 Series
Screen tearing observed on AMD CrossFire systems with Eyefinity portrait display configurations
Instability issues for Grid Autosport when running in 2x1 or 1x2 Eyefinity configurations
Geometry corruption in State of Decay
Known Issues
[404829]: Horizontal flashing lines on second screen in a clone mode with V-Sync on using AMD Mobility Graphics with Switchable Intel Graphics
[404508]: Display takes a long time to redraw the screen after an S4 cycle
[405432]: Mantle driver will TDR when running Star Swarm on the loading screen
[404660]: GPU gets stuck in a low power state after it was previously stressed to max power
[403032]: Severe flickering observed on default launch of SimCity 4
[403449]: Playing any media sample in full screen in the 2x1/1x2 Fill SLS configuration leads to TDR
[400573]: Intermittent application hang observed while launching Aliens vs. Predator
[400693]: While running performance test, crash is observed with fault module atidxx32.dll
[401386]: Severe corruption and flashing light observed with specific game settings in Grid 2
[401289]: Flashing lights in Batman Arkham Origins game main menu
horn 29 schrieb:
Known Issues
Extrem uncool
Also wie immer, überwiegend nur die R9 290 [X] optimiert, hier und da noch für die R9 270 aber alles andere bleibt wieder auf der Strecke. Der Treiber ist zwar auch für meine HD7870 GHz jedoch bringt er keine Leistungssteigerung. Bei Thief ist es mit Mantle von den FPS her etwas besser, allerdings ruckelt es nach wie vor im Thief Benchmark, zwar nicht mehr so heftig wie bei den anderen Treibern aber zwei drei richtige "Hänger" sind noch drin. Das wird dann wohl nichts mehr mit Thief und Mantle bei Grafikkarten mit 2.GB Vram.
Ob die Techniker von AMD die den Treiber optimieren, wissen das es auch noch andere Grafikkarten von AMD gibt außer der R9 290 [X], die man optimieren könnte. Ach ist ja auch egal, ich steige Dezember/Januar wieder bei den Grünen ein mit einer GTX 970. Was soll ich mich hier noch aufregen, AMD hat seine Versprechen schon nicht bei den CPU`s einglöst [deswegen bin ich auf Intel umgestiegen] und bei den Grafikkarten ist es genauso, deswegen gehts wieder zu Nvidia. :rolleyes:
mfg Zotac2012
Es gibt doch den News-Artikel, warum nochmal der hier?
...weil Zotac2012 gerne 2x dasselbe posten wollte....:freak:
Status
