Was beinhaltet das große Update? o.O
- Ersteller Zerbich
WhyNotZoidberg?
Vice Admiral
- Aug. 2014
A
AdoK
KnolleJupp
Fleet Admiral
- Juni 2007
Hauro
Fleet Admiral
- Apr. 2010
Jeder der Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 hat. Habe gerade nach Updates gesucht und das Update wird auf meinem Tablet mit Windows 8.1 32-bit angezeigt.
Edit
Erläuterung von Standardbegriffen bei Microsoft-Softwareupdates
Es ist das elfte update rollup in diesem Jahr:
Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: January 2014
Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: February 2014
Windows RT, Windows 8, and Windows Server 2012 update rollup: March 2014
Windows 8 and Windows Server 2012 update rollup: April 2013
May 2014 update rollup for Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2
June 2014 update rollup for Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2
July 2014 update rollup for Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2
August 2014 update Rollup für Windows RT 8.1, Windows 8.1 und Windows Server 2012 R2
September 2014 update rollup for Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2
October 2014 update rollup for Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2
Edit2:
November 2014 update rollup for Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2
Unter 'New features and improvements' ist es aufgelistet:
This update rollup includes the following new features and improvements:
This November update rollup also includes all previous updates since our last image update in April 2014. This is a convenient single step to bring Windows clients and servers up to date. Unlike our April update, the November update rollup is not required to be able to continue to receive security or other updates. However, we strongly recommend that you deploy it to Windows clients and servers to benefit from these new features and improvements as well as to prevent many known issues that have been resolved since April. This update is thoroughly tested to the same quality level as our previous service packs. However, unlike service packs, this update does not change the version number and does not deprecate or change any APIs in a manner that would require recertification.
Im Prinzi ein kleines Service Pack, das es ja seit Windows 8 nicht mehr gibt.
Edit
Updaterollup schrieb:Definition: Eine getestete, kumulative Sammlung von Hotfixes, Sicherheitsupdates, kritischen Updates und Updates, die zur vereinfachten Bereitstellung zusammengefasst wurden. Rollups beziehen sich im Allgemeinen auf einen bestimmten Bereich, wie die Sicherheit oder eine Komponente eines Produkts (z. B. Internetinformationsdienste [IIS]).
Edit2:
- Refreshed language packs
- Defence-in-depth security and Schannel hardening
- Support for newer hardware (boot order allowance, SD card improvements, USB debugging)
- Improved Web Services for Devices (WSD) printer support during network switches
- Performance and reliability improvements in clustered virtual machine mission-critical environments
- Improved manageability
- Additional hardware support (devices that have third-party disk encryption software enabled can now be upgraded to Windows 8.1 more easily)
(Ergänzung; Korrektur)
cumulonimbus8
Fleet Admiral
- Apr. 2012
Dieser KB-Artikel ist im Grunde so wertlos wie die Frage nach demjenigen was dieses Update tut…
Was habe ich von einer Aussage wie: »repariert einen Fehler in XY«? Ich freue mich drüber, dass es repariert wurde. Und wenn ich XY intim genug kennen mag, dann mag ich sogar auch den Bug erlebt haben… …aber war das auch der gefixte Bug? Was defekt war gibt MS nicht bekannt.
Kurz: hier stehe ich, ich armer Tor, und bin so schlau wie nie zuvor…
CN8
Jajaja, bei Goethe klang das etwas anders; ‹als wie zuvor›
CN8
MagicAndre1981
Admiral
- Feb. 2004
hm, auf meinem Encore bricht die Installation ab. Ich muss heute Abend mal in den Logs schauen was da los ist.
M
Micha45
Wieso ist der CB ein solches Ereignis keine News wert?
Nicht reißerisch genug?
Ich bekam die Updates gestern abend angeboten. Eines als "wichtig" und das Große als "optional".
Gab bei der Installation keinerlei Probleme.
Das Große ist für Desktop-Versionen wohl nur eine reine Vorsichtsmaßnahme. Deshalb wird es nur "optional" angeboten.
Bei Server-Versionen wird es offensichtlich als "wichtig" eingestuft.
MagicAndre1981
Admiral
- Feb. 2004
Also die Setup Probleme kamen von Avast. Musste den Schutz beim Setup deaktivieren.
V
versus010919761
Was ms da zur Zeit raushaut ein Witz. Besonders bei 8.1. Was gab es da alleine schon für probs von 8 auf 8.1 upzudaten. Dann das gleiche mit update 1. Das ist ein Witz.
